Spector & Kenneth,
i think they could be done either way.
also, someone here mentioned that the kit links have
the pin ends molded in, even tho thereis no actual pin in the one end.
of course, if you look THAT closely at my Panther, you will find worse mistakes!
well, i fiddled w/ some concepts to anchor the cable end.
Kenneth's picture is excellent, but when i went to fabricate that i ran into problems.
a scale clamp of that size would mighty delicate.
i was going to use the left over fret from my Tamiya Zim rakes,
but when i tried to drill it w/ my pin vise, it smacked me and took my lunch money!
so i eyed my enormous styrene collection and got out my calculator.
i thought 1/2" would be a reasonable thickness for the steel plate used.
but at 1/35, that is a bit over .015
i had the feeling this was not going to work out, as the cable WOULD
actually be connected to this.
so i punted.
i took some styrene rod that matched the diameter of the rod that holds
the front eye, drilled two holes in the rear deck, inserted the rod w/ a
bit of CA, painted the rod to blend in w/ the camo that surrounds it
(one red, one green) and called it 'good'.
or 'good enough'.
now i just have to figure out how to get this styrene cable to drape
more convincingly. i have put it in recently boiled water,
but that has not helped much.
i am afraid to use flame, but i might.
if i had some decent string, i would steal the ends from the kit piece
and soak the string w/ Elmers to form it.
then paint it.
suggestions?
ed.
or just let it hang.
