WW. Finally got to see your pics. You picked an unusual scheme for painting, but it looks quite effective - I like it.
Ron's site is not working at present, so I have posted some pics of the painted interior of my Ausf D on my web site. Can't link pics, so page is:
http://www.geocities.com/petbat1961/panther03.html?1076900959000
Forgot to paint the brass shell cases up to the projectile head before I took the pics
. I scratched the paint off whilst sticking them into the completed rack, so had to touch up the black and brass. Was going to put stencilling on them, but you can barely see the projectiles with the hull roof on.
Theme for the dio is to be of a newly commisioned Ausf D broken down on the side of the road, so minimal wear and tear would be visible on the interior - hence very little chipping.
As I said in a past post, I had to redo the Driver's panel as the original I made ended up being wrong for the D.
Tried some stuff called Humbrol 'Clear fix' on the gauge faces. The label says to use it to fix clear parts to kits and for making windows in airliners.....yeah right. It shrinks like blazes and dries uneven. The light reflects badly off the face in the pic, but is much better when viewed inside the model when the roof is on. Guess I'll just use it to glue lenses in headlights in future.
The routing of the cabling for the radios to the right was a guess on my part , based on pics of the command radios, which have the extra reciever on top. I figured the junction boxes would be down there with the aerial connection box, away from the hatch area to prevent damage by the operator going in and out. You can't see that end of the radios through the hatch, so it doesn't really matter.
Roof is now glued on. Have thinned all the kit track and tool racks ready for assembly. I agree with (?) that the PE ones look good, but do seem a little thin. The DML ones are not bad aside from ejector pin marks on the face.
Tool clasps are being shaved off in prep for the eduard replacements today.
Woo Hoo, light at the end of the tunnel; this will be the first kit I have actually finished since I started modelling again just over a year ago.
