Originally I had thought that I would get everything completed this weekend on this particular project but, as it turned out, I didn't quite make it as far as I'd hoped. The first order of business was to add the last detail in the form of the radio antenna and get it painted up and installed. I applied a sealing coat of Future by airbrush and let it thoroughly dry for 1 hour before applying the kit-supplied decal markings. The markings were treated with Solvset and then a second sealing coat of Future applied. The second coat was allowed to cure overnight before the weathering process began. The markings were pretty straightforward, just the balkenkreuze on the superstructure sides and hull rear along with the LAH insignia front and back.
The first step was to apply an overall light wash of enamel Raw Umber using a #1 round sable brush.
That laid the foundation for the next round, the application of dot filters. The arsenal for that consisting of enamel Panzer Olivegrun, Deep Yellow, Flat White, and Military Brown, and a mixing bottle of clean thinner.
The first dot filter used the Olivegrun, Deep Yellow, and Flat White to introduce some color variation and fading to the underlying paint scheme. Small dots of paint were applied in sections, working slowly around the vehicle one section at a time, and the dots blended in and away with a flat tipped brush dampened with clean thinner.
This was followed by the second dot filter using the Military Brown. This was applied with fewer dots and the initial blending done the same way as with the previous filter. To introduce/simulate dust/dirt streaking due to rain and prolonged exposure, I turned the flat tip brush 90 degrees and used repeated strokes to produce the desired amount of streaking.
Because all of this work involves working with thinner, I wore a paint breather mask the entire time even with the excellent air circulation at my work bench as a standard precaution.
Once that was complete, a pin wash of enamel Burnt Umber was applied to all the raised detail using a pointed 3/10 brush. Excess wash was carefully removed using the same brush and clean thinner to tighten things up. The Burnt Umber was was also applied to the road wheels and running gear in anticipation of the application of pigments, something that was scheduled for today but I didn't quite get to.
I will let this sit for a few days and then come back to it with a fresh set of eyes to evaluate if additional adjustments are needed before sealing it up with a flat coat and starting in on the final pigment weathering.
Total Session Time: 7.25 hours
Total Time to Date: 71.25 hours
