M3 Lee (Work in Progress)...PART 3 (4/17/2009)
    October 2005
Posted by usmc1371 on Wednesday, April 8, 2009 10:51 PM
Hi all,
I've started work on Academy's M3 Lee.
So far I've completed the hull (for the most part).
You'll notice the tan colored running gear. That's the replacement running gear from MRC. Unfortunately, now the tracks are too long. I took out a link from the tracks and now they're too short. I've decided to use AFV Club "workable" tracks instead.
The tool boxes on the rear are scratchbuilt. The boxes included in the kit are too small. These were made with sheet styrene and brass strips for hinges and latches.
The headlight guards are scratchbuilt using brass and strip styrene. The kit guards are just too thick.
The gray on the transmission cover and manlet is brushed on Tamiya Surface Primer. I used this to represent the cast nature of these pieces. The kit pieces are too smooth as is.
I also added post to support the front visor cover (or whatever it's called). I used styrene rod for this.
Thanks for looking.  Comments are always welcome.
-Jesse
Posted by T26E4 on Wednesday, April 8, 2009 11:45 PM
Looking good Jesse. Nice to see your efforts at making the Acad kit more accurate.  One thing you might want to do is fill in the gap below the 75mm mantlet and the horizontal triangular fillet below it.  Look here:
You'll see how it was one large integral casting.  Hope this helps.  Keep up the good work
Roy Chow
Join AMPS!
http://www.amps-armor.org
    October 2005
Posted by usmc1371 on Thursday, April 9, 2009 6:42 AM
T26E4,
Thanks, I hadn't notice that.  I actually haven't attached the upper hull to the lower hull yet but when I do, I'll fill that area in.
Thanks,
Jesse
    April 2008
Posted by smeagol the vile on Thursday, April 9, 2009 8:42 AM
I had to shelve this kit because of all the seams on the hull near the rivets, how did you go about fixing them without killing the detail?
    October 2005
Posted by usmc1371 on Thursday, April 9, 2009 9:08 AM
Smeagol,
Yeah, I hear ya.  The seams on this kit are kind of lousy.  I was really disappointed with the fit of the kit especially since it's a new release.  I recently did Academy's CH-46 and that fit great.
Anyway, here is what I did to fix those seems.  First, I loaded each seam with Tamiya's Liquid Surface Primer.  Sometimes it took 3 or 4 applications.  After it dried, I used Testors Easy Lift Off Paint and Decal Remover to smooth out and remove excess primer.  There's still a slight seam there but I guess this is ok since the plates were riveted together.  If you look at my pictures, you'll see a gray tinge in some areas.  That's the residual primer.
It seems like Academy made this kit unnecessarily complicated.  Maybe they're trying to compete with Dragon in terms of complexity.  Just a thought...
I know this kit is more accurate than Tamiya's offering, but I feel like I'm "polishing a piece of poo" here.  This is kind of funny.  I was working on the kit at the kitchen table and my wife said she was going grocery shopping and asked if I needed anything.  I said "Yeah, some poo polish".  She just looked at me with that special "wife-look".
-Jesse
    December 2007
Posted by mg.mikael on Thursday, April 9, 2009 9:30 AM
Look's like this kit is proving to be quite a beast to put together. Nevertheless, it seems your overcoming the problems one by one.Thumbs Up [tup] Lookin' forward to your next update!
"A good plan executed now is better than a perfect plan next week." - George S. Patton
  Photobucket
    January 2007
Posted by the doog on Thursday, April 9, 2009 9:44 AM
WOW, Jesse, looks like your' going whole-hog on this one!
The boxes look great!
That casting-texture is a great idea too!
If you can't work with those tracks, I have lots of Sherman rubbber band tracks here that I can forward to you if you need them! (Just checked to be sure--I have some "Square Rubber block" type, and some "metal chevron" styles!) Big Smile [:D]
    October 2005
Posted by usmc1371 on Thursday, April 9, 2009 9:58 AM
Karl,
Thanks for the offer but I already have the AFV Club tracks.  I've never really been a fan of the rubber band tracks.  I kind of enjoy the torture of filing and sanding 504 pieces to make two runs of tracks.  Since baseball session has started, I can watch a game and work on those mundane items in this kit.  (The Orioles are looking to sweep the Yankees today.  Go O's!!)
Have you guys seen all the individual rounds with this kit?  Yeah, they're fun to clean up too.
-Jesse
    April 2008
Posted by smeagol the vile on Thursday, April 9, 2009 9:12 PM
What is this testors easy lift off paint, and how did you use it with the decal softener to remove the primer?  I really want to do this kit, M3s are my favorite design.
    August 2005
Posted by Phil_H on Thursday, April 9, 2009 9:20 PM
Hey Jesse,
Denatured alcohol works great for doing this (at least the Australian equivalent, methylated spirits, which is >90% ethyl alcohol, does). Doesn't harm the styrene and you can wash your brushes out with it. I'll hazard a guess and say it's much cheaper than the Testors product too.. Smile,Wink, & Grin [swg]
    July 2006
Posted by constructor on Friday, April 10, 2009 1:15 AM
The problems I encountered with this kit is basically with the interior. The pump or motor beside the left door interferes with the turn of the turret basket. The ring that wraps around the lower part of the basket is too tight.
    October 2005
Posted by usmc1371 on Friday, April 10, 2009 6:56 AM
Smeago,
This is the product I'm referring too:
It's used to remove paint and decals.  I have never tried the Denatured alcohol that Phil mentioned but if he says it works, I'm sure he's right.  I've used ELO to remove lacquer, enamel and acrylic based paints with no damage to the plastic.  I use just a little bit on the end of a cotton swab and rub the area gently.
Phil_H,
Thanks for the info on the denatured alcohol.  I might give a try after I'm out of ELO.  I still have most a container left.
Constuctor,
Thanks for the heads up.  I haven't built the turret yet but I did start painting the interior.  Maybe now I'll finish the interior painting after I build the turret.  I've looking around online and I haven't found anyone who's completed this kit yet, interior and all.  I know Steve Zaloga built it but I don't think he added the interior.  He gave the a kit a B- rating.  I'd give it a C.  It's a real shame.  I really like the M3 also.  Oh well, just gotta keep on "keeping-on".
-Jesse
    October 2005
Posted by usmc1371 on Tuesday, April 14, 2009 4:32 PM
OK everyone.  I finished the inside of the lower hull.  I found the 37mm ready rounds don't all fit.  The rack holds 14 rounds, but the rounds are too fat to fit all 14 in there.  Interesting, Eduard's detail set replaces the rack with 9 slots.
Thanks for looking and comments are always welcome.
-Jesse
    July 2004
Posted by wbill76 on Tuesday, April 14, 2009 5:15 PM
Very nice work on the interior, looks like you found a good solution to the fat 37mm round problem. Makes you wonder who had it right...Eduard at 9 or Academy with 14 but Academy got the round sizes wrong.
    October 2005
Posted by usmc1371 on Wednesday, April 15, 2009 6:41 AM
Thanks, wbill76.  What do mean by "Academy got the round sizes wrong"?  You mean the scale dimensions of the rounds or the caliber of the rounds used in the kit.  I thought it might be a little silly to have 37mm rounds in the hull instead of the 75mm.  Plus, I can figure out how the crews got those rounds off the rack with it being behind the turret.  Must of been a tight fit.
-Jesse
    July 2004
Posted by wbill76 on Wednesday, April 15, 2009 9:28 AM
Jesse,
I was referring to the scale dimensions based on your description that they wouldn't fit in the racks. There wasn't a lot of space in the turret for ammo so I guess they stuck it as close as they could!
    January 2007
Posted by the doog on Wednesday, April 15, 2009 12:11 PM
WOW, Jesse! This looks awesome!! What a great interior!
You might not want to "go there", but I'd give the pristine white angles and edges a bit of drybrushing with some metallic grey, to show the natural wear that would occur--here's a pictureof how I did it on my Hetzer interior....
Just might give it a little more "used" look? Wink [;)]
    October 2005
Posted by usmc1371 on Wednesday, April 15, 2009 12:58 PM
Thanks, Karl.  I actually used Model Master Steel, I just didn't do the dry brushing as heavily as you did.  The M3 wasn't in service very long, so wear and tear wouldn't be very heavy.  If you look in my pictures, you'll see the heaviest steel dry brushing on the transmission casing and the turret drive motor (I think that's what it is).  Also, the MM Steel is lighter than the Metallic Grey you used.
I do think I'll do some more dry brushing on the corners of the bulkheads though.
-Jesse
    January 2007
Posted by the doog on Wednesday, April 15, 2009 1:33 PM
OH, ok, Jesse--you're right; I see it there!
Yup--that looks great! I must need glasses or something!? Laugh [(-D]
    July 2006
Posted by constructor on Wednesday, April 15, 2009 5:13 PM
I encountered the same problem with my Lee. I think the ammo racks holder are too close to each other it is impossible to fit all the shells in. The part the I am referring to regarding the part that gets in the way of the turret basket when it turns is the pump-looking part directly atop the fire extinguishers.
Dre
    June 2007
Posted by Dre on Wednesday, April 15, 2009 5:44 PM
Beautifully done interior!  To my eyes, it has just the right amount of wear for that "lived in" look without it looking trashed.
What are those steel tobacco tin-looking things on the right side?? Drums for a Thompson?
    October 2005
Posted by usmc1371 on Wednesday, April 15, 2009 6:14 PM
Constuctor,
Yeah, I'm worried about the turret basket fitting.  I haven't assembled it yet.  I already had to snap off and reglue the ammo basket on the right side.  It was getting in the way of the upper hull.  I'm beginning to really not like this kit.
Dre,
Thanks.  I believe those are for the Thompsons.
-Jesse
    January 2012
Posted by I make stuff on Wednesday, April 15, 2009 7:21 PM
Wow, that's what I thoguht they were, too, that's 1000 rounds of .45 acp ready to go.  Quite the load.
    June 2008
Posted by Hans von Hammer on Thursday, April 16, 2009 12:28 AM
I don't think they're Thompson mags, although I could be wrong.. But... Why would there be that many drum-mags for Thompsons and no ammo-cans (so far at least) for the 30-cals?
    October 2005
Posted by usmc1371 on Thursday, April 16, 2009 7:21 AM
Judging by interior pictures, I believe extra ammo cans would be carried under the bow gunner/radio operator's seat.  Makes sense. The kit area is modeled solid but interior pics show shelves.  You can't see this area on the model once the hull is together.  Here's a pic of the bow gunner/radio operator's seat.  The seat in the middle is the driver's seat.  The shelves would have a seat on top of them for the radio operator: http://data3.primeportal.net/tanks/david_lueck/m3_lee/images/m3_lee_57_of_86.jpg
There are some stowage boxes Academy missed.  I didn't bother scratchbuilding them since most of the interior won't be visible anyway.  For the same reason, I'm not worried about really detailing the interior.  I'll only have two hatches open, one side hatch and the drivers hatch.
-Jesse
    June 2008
Posted by Hans von Hammer on Thursday, April 16, 2009 7:55 AM
Well, that's where the confusion sets in fer me, pard... There isn't a bowgunner in a Lee, in the classic sense like a Sherman, meaning a ball-mounted .30 cal, just the coax and commander's .30s...
Been lookin' over this build...
http://www.ipmslivonia.org/ipms/Gallery/M3-Lee/KitRM3Lee.htm
And this interior
http://depothobbies.com/Verlinden/VER%201807%20M3%20Lee%20Interior.jpg
For my Tamiya Lees, plus various stuff to do a Lee AVLB scratch-build down the road..
    October 2005
Posted by usmc1371 on Thursday, April 16, 2009 8:25 AM
Ok.  Maybe where stuck on something here because my references show two forward firing .30 cal machine guns mounted in the hull to left of the driver.  My reference is Steve Zaloga's book on the M3.  Here's the ports welded over:
http://data3.primeportal.net/tanks/david_lueck/m3_lee/images/m3_lee_03_of_86.jpg
There are 3 .30 cals on the Lee.  Two in the hull and one in the cupola.  In terms of the coxial, there is no .30 cal lined up next to the .37mm.  That tube you see in pictures is the stabilization counterweight for the .37mm.
Steve Zaloga also states that the tank carried 1,200 .45 cal rounds.  That rack on the model would hold 1,000 rounds in 50 round drums.  Remember, the M3 carried a crew of 6-7 men.  That's about 200 rounds a man.  Makes sense.
I sent you an email with pictures.  Just don't post them due to copywrite restrictions.
-Jesse
    June 2008
Posted by Hans von Hammer on Thursday, April 16, 2009 10:26 AM
Looks like a coax in this one to me... To the right of the 37mm...
I did see a pic earlier of one crewman dismounting witha Thompson, but another one was totin' an Ought-3, lol...
At any rate, I ain't saying you're wrong bud... I'm just saying that the storage doesn't make a lot of sense... 9200 rds of 30-cal vs 1200 rds of .45... Lotta 30-cal ammo cans..
    October 2005
Posted by usmc1371 on Thursday, April 16, 2009 11:15 AM
Yup, your right.  When we started talking about this, I thought I read there was a coaxial .30 cal.  But the picture I emailed you didn't show it.  It kind of through me off.  Here's Steve Zaloga's M3 clearly showing the coaxial .30:
http://www.missing-lynx.com/gallery/usa/images/m3acadsz_c.jpg
But there are 2 .30 cals in the hull.  That makes 4 .30 cals carried in the Lee.
In regards to the ammo carried, I think we should remember that the US didn't know "jack" about mechanzied warfare when the M3 was designed, hence the "more machine guns, the better" concept.
-Jesse
    June 2008
Posted by Hans von Hammer on Thursday, April 16, 2009 11:53 AM
Still... I can't figure out how they're even aimed & fired in that kinda mount... Ah well... Gonna build an AVLB anyway...
