Hi guys,
Here's the usual Saturday afternoon update:
Apart from painting the mufflers with a rusty colour prior to pigments and darkening the lower hull walls located behind the running gear I'll be leaving the build alone now until the running gear is on.
So, the Friuls are about 10 links short of being complete and the wheels are mounted on spikes stuck in the foam block primed and ready to be airbrushed with my rubber mix - I'll paint the hubs by hand as they are tiny.
I'm actually going to get a chance to try my 'Track Black' which I bought from a buddy on a UK forum at Christmas but I've just not used it as I haven't used Friuls for ages!
It comes in three bottles: Immerse tracks in solution one which is the degreaser then immerse in water and then immerse in solution 2 then finally into three for a great natural effect (apparently)! It's good for two to three uses depending on the size of tracks.
I've made the Friul runs about 5 links longer than the supplied vinyl kit tracks which should give a nice sag but I've plenty spare in the bag if needed.
You'll also see a photo of my Labrador Purdey who chomped my original StuG III not that long ago - I've been promising this photo to Andy Deafpanzer for ages. She's grown up a bit now and doesn't chew now and is doing very well in her career as my Dad's gun dog!
Todays work - I'm nearly there:
One completed run of Friuls ( the other is in the box) along with some more which I'll be using as a spare track run to be mounted on the front of the build - much better than the kit spare track run!
The three bottles that make up the 'Black Track':
Finally, this is 'StuG Dog', otherwise known as Purdey
Thanks for looking in guys
It's May Day Bank Holiday in the UK on Monday so I hope to have the tracks fitted by the end of Monday - I'll dip them tomorrow and paint the wheels.
Take care,
ATVB
Ben
