Tamiya StuG III Ausf B 1/35 - Now onto the base! (14/05/11)
    June 2009
Posted by kermit on Wednesday, May 18, 2011 11:56 PM
Hinksy,
Been reading and looking through your buildlog and i must agree with what has been said sofar: absolutely top notch work!YesYes. Love the dust effects on the top especially; very realistic and lifelike. Can't wait to see what you do with your base. Still struggling to get mine to look like i want itSmile
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    September 2009
Posted by Hinksy on Thursday, May 19, 2011 5:47 AM
Cheers Richard,
I must admit she really exceeded expectations and the real bonus for me was to have the pre-shade work. That showed through to the end and made a real difference imo.
The pigments (apart from the pigment work on the lower hull walls behind the running gear) has all been applied dry over a matt coat and no fixer has been used. I found the best way to get her looking good was to apply tiny amounts of different MIG pigments via the tip of a paintbrush and work in using a stiffer-bristled brush. I'd then go over the areas that I'd worked on with and old toothbrush which loosened any excess which I'd blow away then I'd repeat this step if needed.
I've struggled with pigments in the past in as far as applying them over a flat surface goes but have found that the only way to really get them to work well is to build up the pigments adding VERY small amounts at a time as they go such a long way!
As for the base - I have only made one before and really want this one to look the business. I haven't started it yet and hope to do it this weekend. I think I know how I want it to look but as it's pretty small and I'll be using Pollyfiller as a fixer for the scenery then it has to be right first time!
I'm looking forward to seeing how yours turns out!
ATVB
Ben Toast
On the Bench - Dragon Pz. IV Ausf. G (L.A.H.) Yes
Your image is loading...
