Hey Tojo, thanks for looking in and taking time to comment again!
Well, after much PE wrangling and much stress over this build, I've finally got the hull basically finished as far as all the detailing and PE. Man, what a PITA! I've realized that the PE set I have is actually for the OLD Wirbelwind kit--the original issue--and the PE is, in many instances, designed to fit the older tools which are different dimensions. The relatively NEWER kit which I have has that "New tools" sprue, which seem to be different, dimensionally.
The first pic I have to show is the new fender hinges I made; The Eduard set has a piece that is designed to fit over the zimmerit piece, but it rather gets lost in it. I used a piece of .009 guitar string--man, is that hard wire to shape!--and laid that over the correct spot. I made hinges out of metal foil, and cut bolts out of .040 sprue rod.
In the rear, I drilled out the cable stays and added some music wire to form new ones. I put a "chain" of twisted wires on the bottom circular crank cover. Since I lost the first rear light and reflector, I stole some from an extra Pz IV Aber set I had laying around.Ignore that idler--its just falling off.
And now the fenders and tools. Ugh--I spent days wrestling with the arrangements and PE details, replacing or modifying some, ditching others, and just deciding not to use some pieces that were just unusable--such as the front spare track holder PE piece--it was just way too long to fit in the space between the shackles.
You can see that, despite my best efforts, the light is a little bit too far forward on the fender. I'm hoping that it gets lost in the finish and is not too much of a distraction. What precipitated this was a too-large fire extinguisher piece that I even shortened, but was still too long. Also, I had to rebuild the stays for the opposing track wrenches below the jack block.
On the other fender, I couldn't fit the axe; I had to leave it off, as it wouldn't fit with the other parts. Even then, the arrangement of this fender is different than called for by the instructions, which are inaccurate. You can see in this photo that the axe is clearly on the fender in this position.
I won't be adding the second track over the glacis. Here's the overview; I added in the shovel as per reference photo placement.
Oh god, but it's going to be good to move on from the hull! Onto the tracks and gun now. Kinda wish I had a detail set for the gun, but actually.....glad I"m done with the majority of the PE! NOT my favorite aspect of modeling!
I'm curious what the German armor modelers think about the tools placement? Does it pass inspection guys?
