With the StuG done and a full Sunday ahead of me, it was the perfect time to start up a new one. This time it's DML's Sdkfz 250/1 Neu Premium.
Work began where it usually does, at Step 1! This step is a very simple step, it installs the sprocket drive housings, parts H3/H6, to the hull tub.
![](http://www.bpmodels.net/Model/250Neu/Step1.jpg)
I skipped Step 2 since that deals with the installation of the suspension arms and the idler arm. Test fits showed just a little bit of play in the arms so to avoid issues when the tracks are constructed, they will be installed later.
Step 3 deals with all of the road wheels and the sprockets. The sprockets are 3 part assemblies and each part has 4 connection points, so care is needed when removing from the sprues. The insert, G3, needs to be installed to H2 first to avoid problems and I used locking tweezers to slowly clamp each of the rollers together 2 at a time using liquid glue. The idler pair, parts G20/G4, are different from the standard road wheel pair in that G20 has a larger hole, so I marked these on the back with a Sharpie to insure I don't get them mixed up later on. The contact pins for the road wheel halves are tiny and not very helpful in keeping alignment, so I went slow through this part and made sure each wheel set was aligned properly before moving on to the next one.
![](http://www.bpmodels.net/Model/250Neu/Step2.jpg)
Steps 4 and 5 deal with the installation of the wheels and the tracks, both of which were skipped. However the base for the steering rod, A8, was installed. Step 6 deals with the main part of the front wheel suspension and consists of 4 parts. All of these are from the older mold and need a bit more clean-up on seam lines as a result. The suspension is not workable/positionable without alteration, so I assembled parts A1, A4, and A5 together first and then glued them into the lower hull before attaching the Y-shaped brace part A6.
![](http://www.bpmodels.net/Model/250Neu/Step3.jpg)
Step 7 adds some additional suspension details in the form of the steering linkage and the tow hooks.
![](http://www.bpmodels.net/Model/250Neu/Step4.jpg)
This step also deals with the construction of the front tires and wheel hubs. Each tire is constructed from 5 slices plus the wheel hub and the instructions are misleading a bit here in terms of when the hub needs to be added to the "stack" of slices. It's not possible to keep the wheel hub separate for painting and still construct the wheel since the first two slices need to be attached first.
![](http://www.bpmodels.net/Model/250Neu/Step5.jpg)
Then the rest of the slices can be added on top of that to construct a very detailed tread pattern. Once all the slices were in place, I ran some liquid glue carefully around the lip of the rim to secure the hub in place.
![](http://www.bpmodels.net/Model/250Neu/Step6.jpg)
This was repeated for the second tire to complete the step. Later on I'll use a sharp knife point to modify the U on the "Continentau" and see about adding a piece of stretched sprue or something for the missing valve stem for the tires.
![](http://www.bpmodels.net/Model/250Neu/Step7.jpg)
Next up will start work on the interior.
