Death Star 2 Port Attack Diorama
    August 2012
Posted by JimNTENN on Sunday, October 27, 2013 5:47 PM
This is simply awesome. Can't wait to see more. I'm truly inspired to take my modeling to the next level.
Current project(s): Hobby Boss: 1/72 F9F-2 Panther
                                  Midwest Products: Skiff(wood model)
Posted by VanceCrozier on Sunday, October 27, 2013 7:44 PM
Just catching up on this now Kevin, as I don't spend a lot of time in the Sci-fi zone. This is just spectacular!!!!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    September 2007
Posted by OTnROTSfan on Sunday, November 10, 2013 9:31 PM
Thanks.  Yeah, might be the slowest build ever with the three-month breaks ever so often, but it will get there eventually... lol.
My large rough-cut piece of ABS was ready Fri, so I got some work done on the new surface base... new piece of MDF and got the embedded grid piece roughed in.
Kevin
Inspire onto others as you would have them inspire onto you... or something like that...
    September 2007
Posted by OTnROTSfan on Wednesday, November 13, 2013 11:00 AM
Added a thick metal edging with some angles and flats.  Will also make a nice lip for the eventual acrylic cover...  next to cutting the hole in the MDF and reading the mounting points.
Kevin
    January 2003
Posted by leemitcheltree on Sunday, November 17, 2013 8:22 PM
Kevin....there is something seriously wrong with you....lol.....and I love that model!
The concept....and the execution....is pretty darned inspiring.
Mate - I can't wait to see more.  Very nicely done.
Cheers, LeeTree
Remember, Safety Fast!!!
    August 2003
Posted by RoyFokker on Monday, November 18, 2013 2:42 AM
Woah! Looking alot more like the set every time I see it!
"Untill That Board of Inquirey, I'm Still Captain! First, Find Cyrano Jones! And Second. Close That Door!"
    September 2007
Posted by OTnROTSfan on Monday, November 18, 2013 9:10 PM
Thanks guys.  Starting to look like something... Yes
Past the scary part...  I used the edge of the ABS circle to cut the new circle out of the MDF.  I thought about using a router, but haven't used one in years... didn't want to chance it.  Forgot how much fine sawdust MDF makes.  Got it cut out and drum-sanded smooth and even with the ABS edge.  Did a test fit over the lower port.  Also taped in a piece of edging that I'm thinking of putting around the inside edge for a nice uniform edge.  Epoxying the ABS to the MDF, final sanding, then a test fit for the red port.
Kevin
    September 2007
Posted by OTnROTSfan on Thursday, November 21, 2013 8:19 PM
Mounted the top... hinges along the back that I can pull the pins on to remove it. Going to want to move this around the house and maybe some shows, so decided not to epoxy, but instead try lots of permanent double-stick tabs to mount the ABS. Had done some previous tests and works well. Should also absorb minor vibrations for all those surface parts. Also got the inner hole cowling installed. A little bit of sanding and primer... then onto the port test.
Kevin
    June 2010
Posted by OctaneOrange on Thursday, November 21, 2013 10:03 PM
more awesome work. i like how you caught the SW poster in the reflection. So are you turning the 'table top' into a death star surface to tie in with the port?
    September 2007
Posted by OTnROTSfan on Friday, November 22, 2013 8:22 AM
Yep.  Check out the previous pages... I laid out the whole surface for that area, with a partial-built laser turret tower.  Lots of cleanup and assembly coming soon on those...
Kevin
    September 2007
Posted by OTnROTSfan on Saturday, November 30, 2013 6:34 PM
Had an abnormal week of single-digit temps and snow... even too cold in the garage to lay down the surface... got back to 40 degrees today so got 'er done.  Glad I did the inner hole ring, too...
Kevin
    September 2007
Posted by OTnROTSfan on Sunday, January 12, 2014 4:51 PM
Gone for the holidays then two week sinus infection so been away from the glue and resin for a bit.  Decided to finally make some space in the display room.  Made a little workshop and year-round paint station out of the old basement laundry room.  Good timing since the garage was below zero for like two weeks.  Finally have some room to finish this.
Kevin
    August 2012
Posted by JimNTENN on Sunday, January 12, 2014 4:58 PM
I'm impressed by your Star Wars collection.
    September 2007
Posted by OTnROTSfan on Friday, January 17, 2014 3:16 PM
Thanks.  That's about the 20% of it that I have room to display... rest is all binned or boxed up in the basement or storage until I make more room.  At least the majority of building will now take place in another room and I've been working on getting dust cases for the stuff that's out, so less work displaying and less maintenance.
Kevin
    May 2014
Posted by Kafziel on Tuesday, May 20, 2014 10:15 AM
Amazing build! Any updates?
    January 2014
Posted by Rob S. on Wednesday, June 18, 2014 8:36 PM
Holy wow, very cool. As a big SW fan (see avatar) this is wicked original and very cool!! Thanks!!
______________________________________________________________________________
On the Bench: Nothing on the go ATM
