My Italeri 1/35 S-100 Schnellboot Build
    May 2011
Posted by koelschwolf on Wednesday, November 9, 2011 12:09 AM
Any idea how to mount the motors? I conceived some motormounts as a bulkhead but the motor's vibration  transmitted themselves to the hull making an awful racket. Any ideas on shock absorbers?
    May 2011
Posted by koelschwolf on Wednesday, November 9, 2011 12:13 AM
you are right, the S-Boot was never painted red under water, but at the shipyard was painted with a black anti fouling paint. My uncle served on a S-Boot and took part in operation Cerberus and other actions.
    May 2011
Posted by koelschwolf on Wednesday, November 9, 2011 12:21 AM
Hi, would you share your way of  how you mounted the motors? Did you use some shock absorbers to cut down on the vibration noise?
Greetings from Dallas, Texas, thanks Koelschwolf
    December 2011
Posted by Kapt Wolf on Friday, December 2, 2011 6:12 PM
Hallo Koelschwolf,
I'm in the process of collecting materials for my R/C build of the Italeri Schnellboot S-100 1/35. I certainly would appreciate any advice and a list of material you bought for the conversion etc. since you seem to be slightly ahead on your build. Are you planning on giving your rudders the "Luerssen Effekt" ?
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 10:39 PM
There is  a lot to pass on, if you wish to send me yr email address (confidentially) I'd be happy to reply.
Regards Koelschwolf
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 10:46 PM
Hi Julian, I thought the models of the German mines were a bit too expensive. Looking in Google I found a whole picture series of them from different angles. So I will make mine from the proper size ball shaped buttons.
Koelschwolf
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 10:50 PM
Hi, I found lots of pix on Google of those mines, from all angles and close ups. Using ball-shaped buttons I will make my own mines with wires, winch and all.
Koelschwolf
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 10:57 PM
NOOOOOOO. Do not paint the hull below the waterline red. That part of the hull was painted with black anti fouling paint. According to my uncle who served on one of these boats (fourth flotilla), that paint did not stand up to the rushing water at high speed and had to be repainted over and over.
Koelschwolf
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 11:07 PM
you ask: "what's next from Italieri"? I wish they would produce a 35 kit of a so-called KFK, that stands for in German "KRIEGSFISCHKUTTER"  or armed fishing trawler.. they were built in large numbers in occupied countries and armed with "Beutewaffen" that's captured weapons, like Russian 72mm cannons or french guns, sometimes also with the great 20mm Vierling, a german quad AA gun. You can find pix of  some KFK on Youtube. Ideal to use is the Graupner fishing cutter ELKE. These ships were used in various roles, Escort vessels, mine layers, mine sweepers, sub chasers. They make a great model, I built two.
Regards Koelschwolf
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 11:13 PM
I thought the Bofors gun was built by the enterprising Swedes who sold that gun to both sides of the war?
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 11:19 PM
why buy if you can make those mines by hand? I found the right size ball shaped coat buttons and made the undercarriage from scrap styrene. Can't beat the price for buttons, brass wire etc.
koelschwolf
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 11:22 PM
Hi, what would be intrigueing would be an addition of a FLATTENR Girocopter on the aft deck. You know the type that was towed by U-boats to increase the radius of vision?
Koelschwolf
    May 2011
Posted by koelschwolf on Friday, December 2, 2011 11:28 PM
To RC the Italieri  35scale Schnellboot is not difficult at all. Just  remember to locate the receiver as far ass possible from the motors, solder noise suppressors over  the terminals, place the heavy battery  midships a bit aft. keep the rudder pushrods short, place the antenna all the way aft stuck into a small brass tube so you call remove it when displayed and decide how many of the AA guns you want to operate (one servo per gun)
Koelschwolf
    May 2011
Posted by koelschwolf on Saturday, December 3, 2011 1:05 PM
Hi, Kapt. Wolf. Glad to pass on any info I have gathered. I found the kit in very good condition upon arrival, nothing was broken and all parts fit together extremely well. The assembly of the two hull halves was a bit tricky due to its size. I used a lot of clips to hold them together at the keel. I used those little paperclips that you squeeze together to open. FYI they come in various sizes. After assembling the hull I put a bead of silicon caulk over the seams. Before you go beyond the hull assembly decide what you want to make functional: rotating guns, opening torpedo tubes, ejecting torpedos, lit up running lights (red/green) electric searchlight, rotating RDF antenna, a siren? How many motors, all three props to be powered? RC or not to RC?  If you want to Rd the model, make a sketch where to locate the RC components.
I designed a mechanism to rotate the midships AA gun and will in the future so the same with the AFT gun. I used extra servos hooked into the rudder servo via a Y cable. So when I activate the rudder the gun turns. In my model I only powered the two outboard engines. Care must be given to drill out the two shaft housings and to open the hull. For the prop shaft housings I used K&S brass tubing, but a lubricating system is needed to prevent overheating of the shafts. I am sorry I cannot send you with this  reply the drawings of my concept of a prop shaft bearing with lubricating tubes. If you reply to my email address (wdevallette@prodigi.net) I'll send it you as an attachment. Locate the RC receiver as far away from the motors as possible same with the RC antenna. The heavy battery is located midships, just a bit aft, motors just forward of the battery and the speed control ditto.
The Lürssen effect can be achieved via the rudder pushrods. I did not buy the crew members from Italieri, but I cannibalized an old model of a KFK armed trawler with Tamiya guns and repainted those gunners.
LED's in red & green can be had from Radioshack and be installed on the bridge replacing the plastic running lights. An RDF antenna I made from fine brass wire. I also replaced some of the fine plastic wiring on deck with brass. The railings are covered with "canvas" dodgers (covers) made from one inch wide cotton tape out of my wife sewing box.
I used a two channel Futaba RC unit and was able to buy for just a few dollars a couple of extra servos and extension cables on Ebay.  Originally I used a Pro-Boat speed control (with reverse) but it was designed for only one motor and put out a lot of chatter. So I replaced the unit with an older Futaba speed control that can handle multiple e-motors. For a battery I am using a small 6volt 1.3AH Intestate battery, about 3.5 x 2 x 1. They hold a charge much longer than those multi cell jobs designed for RC.
One final advise, those Schnellboote were not painted  red under the waterline, The dockyard painted the underwater part of the hull with a black anti fouling paint, some boats had a narrow Red waterline, for which I used red racing stripes. I also added some spots of "rust" on the hull to make the model look somewhat worn.
Of course there is no evidence but I thought about building a Flatner Girocopter and have it replace the mine racks. You know those Flatners were towed by a U-boot to increase their circle of vision.  With the high speed of the model it might even fly????  Oh, I forgot I am using Speed 400 6 volt motors with 0.1 microFarad suppressors over the terminals.
Well as a "by the way" item: my uncle served on one of those boats with the 4th, Schnellboot Flotilla in the channel and later in the Med. he had some interesting anecdotes to tell like when his boat boarded a Royal Navy navy torpedo boat in the channell. Not knowing what to do with their prisoners the Germans dumped all their weaponry, ammo, small arms, torps, took all their tea and chocolate and send them home, since the Britisher's life rafts were shot up. My uncle also took part of Operation Cerberus, the break out of the German fleet from Brest. His boat stayed with the mined battleship Scharnhorst until it could proceed.
Good luck with your project. It's up to you if you want  to use the flag supplied with the kit, but to be correct  the swastika should be part of the flag, after all that's the flag the crews served under and also died under.
Kind regards Koelschwolf In Dallas, Texas
