Its been a couple of weeks, so time for an update. A few people have said they have the same Griffon set, so i am going to start with a few issues i have found with it, mainly down to the instructions.
First one is on the main deck. You have to remove the raised area, greyed out in the instructions. And it clearly shows that the vertical sides are to be left.
Which leaves you with this.
But the 2 peices that go over the hole look like this underneath.
Clearly the cross piece with not allow it to fit with the sides of the kit in place. So, the sides had to be removed, here the rear has been done but not the front.
Next issue is the rear section of the torpedo tubes. Before adding AM, they should fit like this.
There is a PE piece for each side which going off the instructions fit like this.
Clearly thats not right, in the instructions, the top of the PE run along the plastic piece. Whjat they miss out is the the sides of the vertical plastic bulkhead have to be taken back.
This also means that the torpedo tubes won't fit and have to be cut back, again this is not mentioned.
Those isues caused me some head scratching, though really it should have been clear what to do. I only realised when i look at the Griffon models website and the page on this AM set had a lot of images which included this area without the bridge fitted.
Unfortunatly, the link to different products does not seem to be working at the moment, at least on my computer. The product is a little way down on the right side, BPN 72001.
http://www.griffonmodel.com/
So once those issues where dealt with, this is how the rear deck looked.
I waisted a couple of evenings trying to sort that out, but it got there. So i was able to fit the deck and put the hull together.
I then did some work on the raised front deck including around the forward gun mount and the hatch, this was then fitted. Towards the rear, there are 2 raised circles just behind the small raised deck section. There were 4 of these, the other 2 being on the outside edge. These are the bases for the smoke generators. The instructions tell you to remove the inner ones. But the pics of my boat clearly show the generators on these inner positions, so i removed the other ones.
The prop shafts were also fitted, i left out the rudders.
And i got one of the rear sections of the torpedo tubes donw. Lots of tricky PE on there. You can see the front has been cut back. I did a bit to much so had to add some styrene strip.
And finally, those props we were speaking about. In the ship craft book there are a couple of pics of an S-38 prop which show them well. They also show that the centre prop attaches to the main rudder. The kit has this right, but i thought it must have been wrong when i saw the instructions, but what do i know about ships.
When i checked the Shapways site, it did not show one of the propeller like this, so will have to see when they get here. And thats going to be sooner than i expected. They are due to arrive tomorrow, i was not expecing them until the end of the month.
More soon.
