troublemaker66:
randypandy831:
i'll give it a try since i got two untouched bottles of tams lacquer.
anyone know how to mix up gull gray?
sorry for all the questions. i got it in MM enamel but im out of their thinner and got two fresh bottles of X-20.
I`m not trying to rock the boat here but, I use plain old laquer thinner with my MM paints and NEVER have trouble. The name on the can is Klean strip...got it at walmart or Home Despot, forget which. It`s a half gallon can I think and I transfer it with an old turkey baster. It cost around 14 bucks and lasts a pretty long time. They sell it in pints and quarts if you wanted to try it.
Sorry about questions? That`s what this place is all about...
Indeed. I've still manage to make many mistakes on my models since coming back to the hobby that I read about here before making them (seems experience may still be the best teacher), but I've also avoided a fair number due to forum advice!
Tamiya acrylics aren't water based (like Vallejo, for example.) X-20 is alcohol based with a retarder and flow aid built in. Tam acylics therefore thin really well with lacquer thinner. The store based stuff is a bit harsher than the hobby lacquer thinner, but works the same way. I don't have any experience with Tamiya lacquer thinner, but use Gunze Mr Leveling Thinner all the time now, and I've read they're pretty much interchangeable. The Gunze product has a pretty strong retarder. I've sprayed XF-59 and XF-23 with Mr Leveling, and the finish was superb even with my low airbrush experience. I use the Klean Strip green can to clean the airbrush.
If you're going to go to the trouble of spraying lacquer thinner, though, then I'd point out that Tamiya acrylics and their lack of availability don't matter nearly as much. Mr Color paints spray just as well, have a much larger color selection, and are readily available. I'd even say the gloss finish on Mr Color gloss paints is superior to Tamiya (can't tell any difference at all with semi or flat).
