Three strikes, you’re out!
    July 2014
Posted by Bakster on Sunday, January 9, 2022 9:40 PM
goldhammer88
Don't know if they carry what you want/need, but take a look at Spraygunner.  Been using them recently, decent prices and usually ships in 24-36 hours.  They bent over backwards to fix an order that I screwed up on,and got it done.
Hey GH, they had it. The odd thing was they didn't have the gray. Kind of how all these places played out. They have one but not the other. Anyway, it was a little more expensive at 6.25 each but that is not a deal breaker by any stretch. I think the freight was less though, so it probably comes out in the wash.
Since they had it, I ordered two bottles and I ordered the thinner too. I have used their leveling thinner before and it works very very well, though it's a bit caustic.
Thanks for the tip!
    August 2021
Posted by goldhammer88 on Sunday, January 9, 2022 9:44 PM
Cool, glad to help out, glad you found what you needed.
    March 2013
Posted by patrick206 on Monday, January 10, 2022 9:36 AM
Hi Steve -
Bummer to read of your primer issue, I can think of nothing that makes it work so well for me, and not for you. Here is what I do, first ensure the contents are up to room temp, then a good mix with metal paddle to stir up the solids from the bottom. Next a thorough blending with electric mixer, then transfer into mixing cup, add thinner, blend again and have at it.
I have used X20A, Tamiya Lacquer thinner, MC Leveling Thinner and iso alc, all with about the same results. I thin heavily, usually 50/50 to start, then maybe end up at 70% or more thinner. I rely on multiple coats for good coverage, laying on enough for it to actually work as a primer, for filling and sanding.
If you have not already binned it all, maybe give it one last go????? For reference, I use Badger and Iwata gravity brushes, and shoot at 15-20psi. All work as intended, one bit of info from me, I use only the gray primer, the white is problematic for me, and the black is less than great for my use. Seems sort of chalky or slightly gritty.
However it ends up, I hope you can source a supply that works well for you, agrivation is an unwelcome visitor on any guys or girls hobby bench.
Patrick
    November 2018
Posted by oldermodelguy on Monday, January 10, 2022 12:15 PM
Like Patrick I use a powered mixer when it separates. I doubt one could even get it truly back together with a mixing stick, never mind shaking.
I'm not here to try and talk anyone into a product though. Before Stynylrez I shot decades worth of solvent based paints and primers, we know they work.
    September 2006
Posted by the Baron on Monday, January 10, 2022 12:56 PM
Bakster
...It looks like I have to go back to decanting Tamiya....
Tamiya's Fine Surface Primer is available in jars, too:
https://www.tamiyausa.com/shop/finishing/liquid-surface-primer-40ml-2/
The light grey shows currently as sold out on Tamiya USA's website, but it's worth looking for either product elsewhere on line, too.
Posted by Tojo72 on Monday, January 10, 2022 1:05 PM
the Baron
Bakster
I wonder how long that lasts compared to a spray can, but I do like the convenience of not firing up the airbrush to prime something.
    July 2014
Posted by Bakster on Monday, January 10, 2022 1:44 PM
patrick206
Hi Steve -
Patrick
Hey Patrick, thanks for chiming in. It is always good to hear your thoughts.
I am glad to hear you confirm what thinners you have used, and the processes. I could already imagine a potential shooting gallery touting that the issue is in my trying to thin it. You have confirmed not only the same thinners that I have used and to some success, but the mix ratio, the mixing, and even the air pressure setting. All are spot on with how I approach this primer. And just to reaffirm. I indeed do use Badgers mixer and I whole heartedly agree that for this paint, it is a must have. With this primer, it gets a good beating before I attempt to spray it.
The sucess that I have had has been with the gray primer. And I think that if I'd determine to stick with it, I might make it work with copious amounts of mixing, and maybe some filtering. The white primer on the other hand, this was a different animal. I am convinced there is something very wrong with it. I say that by how the paint fragmented in the color jar and how the paint turned into a gel inside my airbrush.
As much as I love the idea of using a less caustic paint, I can no longer accept the products unreliability. I just don't have the time for it. It's a bummer!
    July 2014
Posted by Bakster on Monday, January 10, 2022 1:48 PM
goldhammer88
Hey GH. I received an email from Spray Gunner that my order is in the mail. Wow! How is that for quick shipping?
    August 2021
Posted by goldhammer88 on Monday, January 10, 2022 1:59 PM
Seems to be par for the course for them, at least on my orders so far.  Should arrive in a couple days.  My stuff comes USPS first class, 2-3 days, FL to OR.
    July 2014
Posted by Bakster on Monday, January 10, 2022 4:37 PM
the Baron
Bakster
Hey Baron, thanks. Good to know... Yes
    November 2018
Posted by oldermodelguy on Tuesday, January 11, 2022 8:59 AM
With Stynylrez I buy black and white, then mix the shade of gray I want from those. Yesterday I mixed a batch with white and two drops of black to get something a touch darker than platinum grey. I thinned that 50-50 with 70% IPA and it shot beautiful. Now that black about a year ago had separated out with a big glob in the bottom and I mixed that back together twice since then with the Badger power mixer. Works fine. I shot in the H at 25 psi.All fwiw, I know the thread has moved on to lacquer primers. But I do believe many here would have tossed that black bottle a long time ago. No question Styn separates though and it needs power mixing back together if to use it. I've shot a few chassis  and a body or two in black but more volume is generally white with me and just drops of black or a little shot used, thus the black gets old by about two or even three whites to one black.
By the way lacquer primer in bottles can separate too. Course with lacquer the lacquer thinner kind of melts it out.I'm not trying to change anyones mind, I like lacquer primer and used it for 35 years in 1/1 and who knows how long with models but we have a mystery here that I'm just thinking on.
    February 2021
Posted by MJY65 on Tuesday, January 11, 2022 10:05 AM
oldermodelguy
My guess is very inconsistent quality control in manufacturing and shipping.   I don't think anyone here is lying about their good or bad experiences.
    July 2014
Posted by Bakster on Tuesday, January 11, 2022 11:44 AM
MJY65
oldermodelguy
Agreed. And no worries Oldermodelguy. It is a mystery as you say, and I encourage the dialog about it. Yes
Here is something I might add to the conversation. When I was searching the forum about this primer I came across another post where the person describes the problem that they had, and it sounds eerily like mine where the primer gummed up the brush. Very odd indeed. I don't think they stated what color primer it was though.
I don't know. Maybe I should dig the bottles from the garbage and experiment more. I hate a mystery.
Update: If I do, not for this build. But some place in time in the future when I am twiddling my thumbs.
    July 2014
Posted by Bakster on Thursday, January 13, 2022 10:57 AM
Just a heads up. Since I can't let sleeping dogs lie, I pulled the white primer and gave it another whirl. I have to say that of the several bottles of Stynlrez I have had, the white came new with a more watery consistency and less sperated. The gray has always been thick. So, this time, I tried spraying it with just a tad of water added. Oh-- and not before giving it another major power mixing.
The result was this: I was able to get a few passes when I started to notice paint buildup on the tip. I wiped it and it wasn't long when paint output began to drop. I had to pull back on the throttle more and more, then suddenly, paint would flow again. This happened several times. Not too much later I noticed paint splattering on the test piece and at this point, the trigger is being pulled back pretty far.
That was it, the test is over, and it was another epic failure. That bottle is unusable.
I should mention this too. I had a heck of a time cleaning the head, body, and cup. Lacquer thinner was struggling to cut through this stuff. Eventually, and after a few attempts, it seemed to win the war.
So-- that is that.  I will keep the gray bottle and try that another time. Not holding my breath for a good outcome.
Thanks Guys.
    February 2021
Posted by MJY65 on Thursday, January 13, 2022 11:27 AM
Bakster
I wouldn't bother.  Even if that one bottle sprays well this month, what's the point?   If you start using it as your go-to primer, it is very likely to clump up somewhere down the road and ruin your model.  The next bottle is just as likely to be bad from the start.  The AB cleaning problem doesn't get any better, either.
    November 2018
Posted by oldermodelguy on Thursday, January 13, 2022 1:46 PM
If it's thick I wouldn't thin it a tad but enough to make it spray right with either lacquer thinner or ipa. I'm not a fan of water in it. Some guys have gone two parts thinner. I go 20% to 50-50. Sometimes I use no thinner but if the consistency is thicker than I like, I always thin it in that case. As I think I mentioned I've never bought the grey but mix my own from white and black, then I get the shade of grey I want.
It does take some cleaning even thinned right and windex and the 91% ipa will do better at that than lacquer thinner. And good really hot water rinses and back flushes.
Course you could always send it back and get your money returned if you think it's no good....
    July 2014
Posted by Bakster on Thursday, January 13, 2022 2:45 PM
oldermodelguy
The thing is-- it was not thick. This was the closest to milk consistency I have seen from this product. I appreciate your help but there is soemthing wrong with this stuff. And if it's not defunct, then it's not for me either. I don't want to work this hard to make a product work. I really appreciate you guys trying to back me away from the ledge on this stuff but, for me, it's time to move on. I am glad it works for you guys though. Truely.
    July 2014
Posted by Bakster on Thursday, January 13, 2022 2:59 PM
MJY65
That is no joke. That alone would make me not want to use this. Cleaning the AB was a fight. Frankly-- I am concerned about what crud is sitting deep insde the brush. Sigh.
Ok enough said. I don't like bashing and I am walking that line.  I tried to like it, it's not working for me, time to move on.
People shouldn't take my word for it though. Maybe they will fare better than I did.
    September 2006
Posted by the Baron on Friday, January 14, 2022 2:58 PM
Don't sweat it, Bakster, it's good to share your experience with a product, whether a kit, or paint, or tools, etc.
I have to say, I use Tamiya's Fine Surface Primer pretty much as my main primer.
But regarding Stynylrez primer, though many people use it and post how much they like it, posts like yours and from other modelers who have had trouble with it, make me not want to try it.  Such feedback tells me that it's not worth the potential trouble, to switch brands.
    November 2018
Posted by oldermodelguy on Friday, January 14, 2022 3:18 PM
Well as I stated already someplace in the thread, nothing wrong with lacquer primer. I used it and may again. I shot lacquer in 1/1 and models for decades. It's the mystery that gets me lol. But if Stynylrez blows up in my face I'll do the same as you, soo I get where you're at.
I tend not to shoot hot lacquer on models but also if I did do that I'd also use lacquer primer in that case as well.
    July 2014
Posted by Bakster on Friday, January 14, 2022 8:00 PM
oldermodelguy
Here as well, sir. Maybe one day the answer will reveal itself. Yes
    July 2014
Posted by Bakster on Friday, January 14, 2022 8:01 PM
the Baron
Thanks, Baron. Sometimes I need to hear that.
    July 2014
Posted by Bakster on Friday, January 14, 2022 8:26 PM
Eaglecash867
Bakster
Maybe I will try it. I think the local Hobbytown stocks it. I will check with them. Short of that I will decant.
I used to use the Mr. Surfacer 1500 also.  I thinned mine with MEK and it was pretty much exactly like decanted Tamiya primer when thinned the same way and shot through a #1 needle and cap on my Paasche H.  I went with decanting Tamiya because I have a really efficient, mess free/fume free decanting process and you get quite a bit more primer for the same cost.  I get several months worth of priming every part out of a single can.  Also had problems with the plastic lids on the Mr. Surfacer bottles getting cracked in shipping, which was my only option for getting my hands on it.  Can't get it locally around here.  The Tamiya rattle cans handle the journey better.  Either one will serve you quite well though.
So, I received my order from Spray Gunner. I am very pleased with their quick turn. It probably came on Wednesday, but I didn't notice it on the stoop until Thursday. Btw. I ordered something else from them and they shipped it on the very next day as well. Awesome service indeed.
Below: I am pleased with the size of the primer. I was visualizing something smaller. I should be good to go for awhile. I will try spraying it tomorrow.
I made a trip to Dollar General and I found some things. I purchased some shoebox sized containers that should be a good size to either store a finished car kit or, to temporarily store a freshly painted kit keeping it from dust.
On top of the box are some glass jars. I thought these would be good for making Eaglecashes decanting system. The one lid has holes that might work well for degassing, and l like too that these have handles to them. Not shown in the image are several bags of plastics spoons that I can use for test sprays. I also bought things like chocolates, napkins, floss, and all of this for only $11 and change. Such a deal.
Anyhow, tomorrow I test the new primer.
Eaglecashes system:
    March 2013
Posted by patrick206 on Saturday, January 15, 2022 12:15 PM
Hey, Steve -
Ya know, there's a lot of good info winding it's way through this post, it's been very informative for me, thanks go to you and the responses from so many others. Just for the sake of keeping up with the newer developments in paint products, I'll check on Spray Gunners site and order some of the surfacer you bought.
One bit of info about something I read a very long time ago, that I use to this day, is called "induction," regarding preparation of paint for spraying. That specifies a period of time after thinning and mixing, 20-30 minutes, prior to actually painting the subject. Whatever that word "induction" means relative to a mixed paint blend I don't really know, but I'll say it does make a difference for me. After it sits for those few minutes, I re-stir the mix so the surface doesn't have the chance to form a little skim layer.
I do hope you'll keep us posted about your use of the new products you received, I'm really interested. Thanks again.
Patrick
    November 2018
Posted by oldermodelguy on Saturday, January 15, 2022 1:57 PM
Bakster
Awesome, let us know how it goes for you !
    July 2014
Posted by Bakster on Saturday, January 15, 2022 4:14 PM
patrick206
Hey, Steve -
Patrick
Hey Patrick, thanks for the encouragement. Also, thanks for the info about induction. I  never heard that term with regard to paint and I'd like to know more. I am assuming that the waiting period allows the paint/thinner mix to fully assimilate? Would that be your understanding? Secondly, you say it makes a difference. Can you quantify the difference you are seeing? Very interested.
Lastly, it is great to hear that you ordered some of this primer. If you don't already have it, and/or, if you didn't order it, I encourage you to get some of their leveling thinner. I have used it before and it does make a difference leveling paint. Btw. I have used their leveling thinner with enamels and even acrylics. In all three cases, it allows you to put the paint on wet. That translates to less orange peel. For enamels, its huge, because it allows your to draw out a high shine.
How did the primer perform today? Awesomely! It sprayed like silk! The paint hit the model wet, it dries fast, and it had fairly good coverage. I might have over thinned it reducing coverage but I am not sure. I thinned close to a 50/50 mix. In any event, it was a pleasure to use. The primer atomised beautifully, and I didn't have to wipe the tip once. There was a little buildup towards the back of the tip, and it had no affect on the spray. I can not speak to sandibility yet, nor durabiliy, but I have no reason to think it won't perform. And with the leveling thinner, the paint went on very smooth. There will be minimal sanding. Cleanup was straight forward. I used hardware store lacquer for that and I had no issues.
In short, it worked very well! Thanks to those in this thread that recommended it.
I guess if there is a drawback to it, it would be the fuming. But that comes with the territory.
Oh, I should mention that I used my Badger 155 siphon dual action for today's paint session. So for my project, I will do a once over looking for issues, then hit it with enamel. I will use the leveler for that.
    July 2014
Posted by Bakster on Saturday, January 15, 2022 4:18 PM
oldermodelguy
Just did! Thanks my friend.
    April 2020
Posted by Eaglecash867 on Saturday, January 15, 2022 4:54 PM
Glad to see you're happy with your new primer, Bakster!  I started using that Mr. Surfacer stuff after finally getting fed up with the Model Master lacquer primer that I was using at the time.  When I shot a lacquer primer from my airbrush for the first time and saw the consistent results and super thin primer layer that preserved even the most delicate of details, I was hooked.  You'll love how decanted Tamiya shoots as well.
The sandability of both is great.  Mr. Surfacer makes a really good filler/putty for areas that are surrounded by fine details you don't want to lose.  You just use a brush and dab it into the areas you want to fill, wait a couple of hours, and then gently sand it smooth...or smooth it with a q-tip just barely damp with their Leveling Thinner.  I have also used Tamiya primer just recently in my airbrush to level out an area that I had accidentally chipped the paint on.  Took the paint all the way to the bare plastic in that one little spot with that screw-up.  Just gave it quick little spurts of primer to build it up, sanded it smooth, and painted.  Can't even see the repair.  Otherwise it would have broken my heart...all the time I spent masking, undercoating, Alcladding, masking, and painting my F-4B stabilator almost wrecked by the slip of a tool.  Tamiya primer to the rescue with its awesome filling and sanding properties!
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    August 2021
Posted by goldhammer88 on Saturday, January 15, 2022 5:20 PM
Good to know it's working for you.
As for areas that need minimal sanding or scuffing up prior to colors going on, go to most any auto parts store and get a couple of grey scotchbrite pads.  Puts just enough "tooth" in the primer to get better paint adhesion, especially if you are doing multiple colors and have had any pull-up on the prior color.
Can be cut into narrow strips with the pair of scissors or an old #11 blade that's Lost enough edge to nothing be used on a kit anymore. Can get into tight corners as well.
    February 2021
Posted by MJY65 on Saturday, January 15, 2022 5:50 PM
patrick206
I don't think it would serve quite the same purpose for our paints that dry by evaporation of solvent vs automotive paint where you mix a base with an accelerator/catalyst.
