FW-190 Reich Defender III 5/10-2/11
    January 2009
Posted by sk3tch on Sunday, May 9, 2010 12:50 AM
Great detail on the instrument panel Clebode!
    September 2003
Posted by Daywalker on Sunday, May 9, 2010 7:29 AM
Looking good there Karl, you're really zipping along with this one!
Clebode- Great work on the office, especially that IP! Toast
Frank
    January 2007
Posted by Clebode on Sunday, May 9, 2010 9:16 AM
Thanks for the encouragement everyone.
Soulcrusher - You are now my official coach.  Thanks for the great tip for mating the fuselage halves.  Seams are not my forte but I am getting better with practice.  Your advice should be just the ticket for this project.  As practice for tackling the fuselage I glued the halves of the big right side air scoop last night and after about 30 min had a seemless beauty. Big Smile I am using a new glue that is thin and lightening fast as opposed to the Testors I had always used before.  It really softens and thoroughly welds the styrene making an initial scrape of the seam much more effective.  That allows minimal use of gap filling CA which I have always had trouble sanding down completely.  I have also switched to wet sanding from dry.  Big diference.  I should get the fuselage toghether today and start on the seams..  The actual fit is not too bad.  The major problems seem to be around the openings to the pit, tail wheel and lower wing.
Frank - Thanks for the link to the other site.
Clebode
Hugh
    November 2006
Posted by dupes on Sunday, May 9, 2010 12:39 PM
Clebode - that pit looks great!
Hoping to have something to look at for you fellas tomorrow. Big Smile
    December 2005
  • From: back seat of your car with duct tape streched out
Posted by soulcrusher on Sunday, May 9, 2010 1:08 PM
Clebode I only use super glue to fill a seem that it going to need to be rescribed later or to repair and accidental scratch when rescribing. It dries much to hard and is very resistant to sanding. Have you tried Squadron putty. It dries fast and sands nicely. Wet sanding is the way to go no doubt even when you are doing rough sanding. It has sveral advantages. The first is less dust all over your bench and the second is you sanding sticks will not clog up and will usally last longer too. Glad to hear the fuselage is almost ready to get glued. I'm going to be glueing mine up tonight.
Frank I did see the first pictures you posted I just wanted more!:stups:
        Soulcrusher:wall:
    September 2006
Posted by raptordriver on Sunday, May 9, 2010 7:11 PM
Glad to see some progress, I am not going to start soon, because I am working on a Monogram Monster, but I thought I would post some pics from my model contest trip.
Ipms4.jpg picture by Raptor94
Ipms6.jpg picture by Raptor94
Ipms7.jpg picture by Raptor94
Ipms8.jpg picture by Raptor94
Whoops Blurry
These are other builds I saw at the contest-- not mine.  I hope this is not too off topic, but I thought it was interesting.
Andrew
    March 2006
Posted by simpilot34 on Monday, May 10, 2010 6:13 AM
How can pics of the guestbe off topic????? Beutiful shots!!! Love the decal/paint work on them!!!!Toast
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    March 2010
Posted by Julez72 on Monday, May 10, 2010 7:22 AM
Ditto Very nice Builds......
Well i have my Eduard A-5 and i'm impressed, it has everything so i'm showing everything, engine cowls open and gunbay panels open.....
    September 2003
Posted by Daywalker on Monday, May 10, 2010 7:35 AM
Thanks for those pics Andrew, great inspiration!
Frank
    July 2004
Posted by mucker on Monday, May 10, 2010 7:47 AM
Nice start, Karl! You're moving along at a pace Guy would be proud of!
Andrew..great inspirational pics!!!
    January 2007
Posted by Clebode on Monday, May 10, 2010 7:44 PM
Soulcrusher,
Where are your photos?
I am going to prime the fuselage now.  Seams look good after a silver Sharpie drag.  Stuck with the CA fill as your tip on gluing tabs made the fit quite good.  Big Smile  Only tiny gaps to fill.  I have the Squadron putty but I have only used it for big gaps.
Frank,
I am in contact with Jerry Rutman.   His upgrade parts look beyond anything I have tackled so far but I am giving it a go on the main wheel wells.
Karl,
I wish I had gone your route on a 1:72.  Looks good so far.
Hugh
    December 2005
Posted by soulcrusher on Monday, May 10, 2010 8:43 PM
Sorry Clebode. I was a bit under the weather yeasterday so I did not get the fuselage closed up I'm heading to the bench right now to finish up the IP and close her up.
I also got my EagleCals decals today. Man its going to be hard to pick on scheme. One late war bird even has a non standard  Blue green underside with NMF wing panel on tne bottom of the wings.
Off to the bench I go!
                                                          Soulcrusher:banana:
    December 2005
Posted by soulcrusher on Monday, May 10, 2010 10:37 PM
Ok Clebode here are the pics I promised. I told you I was heading off to the bench! Did'nt believe me did ya!  I decided to wait until tomorrow to close everything up because some of the glue is no dry and some paint is still a bit tacky. I also tacked in the main wing spar. and glued some wheel havles together.
Where is our fearless leader? Oh my he's been in the rum agian!:1244: I'm gonna have to tell Capt. Bondo to cut back on your rum rations Frank!
Soulcrusher:wiggle:
    September 2003
Posted by Daywalker on Monday, May 10, 2010 11:16 PM
Great looking progress pics Crusher!  Looks like you're a mile ahead of me already.
soulcrusher
Promise you won't tell?
M1A2 Abrams
Whistling
Frank
    December 2005
Posted by soulcrusher on Tuesday, May 11, 2010 12:12 AM
Oh I'm telling everyone! Seriuosly I checked out your work and it is top notch. I love WWII armor and I hava about 20 1/35 scale WWII armor subjects stashed away. I have a good idea Frank for the next GB. Wingnuts building armor! Any scale any subject goes. Mabye this fall?
Soulcrusher:wizard:
    March 2010
Posted by Julez72 on Tuesday, May 11, 2010 3:26 AM
Soulcrusher, nice work on the interior and engine plug, looks greatYesYes
Frank, Some armour eh.....Too many wheels buddy....
    January 2007
Posted by Clebode on Tuesday, May 11, 2010 7:02 AM
Soulcrusher,
Your office and engine plug look fantastic.  Your dials look real crisp.  Yes  What was your technique for painting them?
I didn't get to prime last night as there were a few small seam imperfections and sanding scratches to fix.  I have also decided to install the pit before priming.  That may push things back a bit.  The IP fit is a bit dodgy.
Hugh
    December 2005
Posted by soulcrusher on Tuesday, May 11, 2010 12:22 PM
Thanks Julez I'm pretty happy with the IP and plug.
Clebode the IP is the kit piece sanded flat with a film for the dials and then a photo-etch peice over the top in a sandwich type of arangement. It is not perfect but it looks ok. The real instument panel had some of the guages actually prodrude quite a bit so the flat look ot this type arrangment is not 100% accurate but it will look ok hidden deep under the cockpit dash.
I am sure you IP needs a bit of fiddling to get a good fit. Thats just the nature of the beast. Looking foward to your next pictures.
Soulcrusher:wiggle:
    July 2004
Posted by mucker on Tuesday, May 11, 2010 12:42 PM
Soulcrusher....looking good on the 'pit!
I'm begining to think Opti-visors create internal cranial hemorrhaging...look what it's done to Frank...he's building targets!!!
    July 2003
Posted by KJ200 on Tuesday, May 11, 2010 1:27 PM
Clebode, nice work on the IP.Yes
SC, that engine plug and pit look spot on.
Looking forward to seeing that one finished.
Progress
Not a lot on the lil' 190, as the big 262 is back on the bench.
Karl
    December 2005
Posted by soulcrusher on Tuesday, May 11, 2010 1:30 PM
Thanks mucker. I am pretty happy with my efforts though as always I think I could have done better.
Actually mucker I think it is Franks key to his super powers. A closely guarded secret though he did let me in on the exact powers of his optivisor during a secret phone conversation as long as I agreed to keep the exact detail a secret.
Soulcrusher:shocked:
    November 2003
Posted by tempestjohnny on Tuesday, May 11, 2010 2:31 PM
Frank I'm in of course.  I have an A-5 and an A-6 in the stash both Hasegawa 48th.  I am going to have to finish the Mistel first.  JOHN
    December 2005
Posted by soulcrusher on Tuesday, May 11, 2010 7:07 PM
Ok I checked out the decals I bought from EagalCal closely and I found one option that is really cool. "Black 10" the third from the top is painted in a non standard blue green on the fuselage with NMF panels on the bottom of the wings. This one is really screaming out to me build me! The first two choices are actually the same plane and the third production model of the D-9 series. It somehow managed to survive the war till the end. Here is a better scan of the color plates.
SoulcrusherPirate
    July 2008
Posted by vetteman42 on Tuesday, May 11, 2010 9:51 PM
Wowzers !!!! You guys are all doing beautiful work Toast Its making me want to get a move on so I can start mine.
Randy So many to build.......So little time
    December 2005
Posted by soulcrusher on Tuesday, May 11, 2010 10:17 PM
So come on Randy! Clebode and me are the only two right now going full steam ahead on our builds. Frank said he is giving out free Me 109 kits to the first two people that finish their builds :You_Rock_Emoticon:1/72 scale not included sorry Karl!
I glued up the two fuselage halves tonight and everything fit very nice in between the two halves. I also finished glueing in the wheel well-wing spar assemble to the lower wing. The lower wing is a little flimsy due to the way it is broken down so the spar is needed. I glued it in sections for the best fit. I have not decided what to tacke next.
Soulcrusher:wiggle:
    September 2003
Posted by Daywalker on Tuesday, May 11, 2010 10:45 PM
soulcrusher
Oh boy... I can just see it now!  The mantlet of a Sherman with a spiral on the end of it, a mottled Abrams and a Tiger II in NMF! Dunce  LOL... still- sounds very intriguing!  Yeah, and you better keep that optivisor thing a secret!  Otherwise, no more 109's in the mail for you!  I like the idea of the third plane on that sheet, after you mentioned the blue-green and NMF undersides!  I have always liked the looks of those very late war A/C, with the patched together appearance.  Go for it!
Free 109 kits in the mail, YIKES!
Charles- Good plan!  I'll blame it on the optivisor!  Don't worry, I shall always stay true to aircraft, just need to build something different once in a while.  One of these days, I am even going to try building a ship! Surprise
John- You got it my friend, both kits added to the list!
Frank
    March 2010
Posted by Julez72 on Wednesday, May 12, 2010 5:56 AM
Soulcrusher, nice choice that one, black 10 should come up real nice...Keep it comingYes
    March 2006
Posted by simpilot34 on Thursday, May 13, 2010 5:19 AM
ToastSC that looks great mate!! The IP came out very well!!! Nice choice on the decals too!!!!!!!
Frank that M1 looks awesome!!!
    September 2003
Posted by Daywalker on Thursday, May 13, 2010 7:35 AM
Thanks Richie! Propeller
Small update on my F-8...
Opened up the shell ejection ports on the bottom of the wings, and boxed in the chutes with some scrap styrene.
I also cleaned up the fuselage, and painted the dash a very dark gray...
The kit came with a bomb loading cart and two figures, thinking about adding them to a small dio.  Here's the loading cart i have been working on as a side project just in case-
Frank
    March 2006
Posted by simpilot34 on Thursday, May 13, 2010 9:22 AM
Looking good Frank!!! Looking forward to seeing color!!!!
