(A)SW GBII - CLOSING
    March 2011
Posted by de havilland canada on Sunday, April 17, 2011 2:38 PM
I put lead shot around nose gear bay,aft of cockpit bulkhead,and forward of main gear behind engines....probably 60+grams....oh well.
Gannet should not be as hard to weigh down.
Cheers
http://i756.photobucket.com/albums/xx202/kermit77/ASWgb2/ASWgb2Badge.jpg
    October 2008
Posted by bsyamato on Sunday, April 17, 2011 5:31 PM
wow!! and this not enough!!!!   .. then, you're wrong, never in the gannet is so simple Tongue Tied
Photobucket
Photobucket
the little bird is drammatically seated on the tail after the lead cure Crying
i finished the space to put other weight!
Photobucket
unfortunately with the engine mod i cannot use the large zone after the propellers complex.
The only way to resolve the problem is to fill the engines with lead pieces Angel
Weight developments in the future.
Continuing on the seats , started the seat belts
Photobucket
Copper wires and the cheapest tape on the earth! 2 cents
Photobucket
need again some pieces ... and two seats Indifferent
My damned obsession for details put me in too troubled and long times works. Snail... for this reason i glued the front and center IP on the cockpit, so i cannot add others details inside Zip it!
atthenexxxt
    March 2011
Posted by de havilland canada on Sunday, April 17, 2011 11:34 PM
It is starting to look like a Gannet now Yamato!
I will be curious to see if you end up as a tail dragger or not.
Good luck and keep up the good work
cheers
martin
    June 2009
Posted by kermit on Sunday, April 17, 2011 11:57 PM
Wonderful work everyone!YesYes
Bsyamato,
If all else failes you could always put it on a base and glue it on...? Just a suggestionSmile
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    October 2008
Posted by bsyamato on Monday, April 18, 2011 4:45 AM
de havilland canada
cheers
martin
I hope this problem will be resolved with engines plumbing Smile
Eventually i can put more weight on the wings front, but is too close at the main gear to make the difference
kermit
Bsyamato,
Richard
A diorama was an option, but generally i hate to glue down my planes, in this case because i'll put some extra detail in the torpedos bay....
another solution is to put the gannet tail on a display with an air spray .
finally i found the sprues pictures
Photobucket
... as i said at the start, there's a lot of pieces ..
    March 2010
Posted by Julez72 on Monday, April 18, 2011 6:47 PM
DeHav, your Tracker is looking awesome, looking forward to those finished pics....
Yamato, looks like your making some real progress on the Gannet now, looking good...
hey i should have some finished Biber pics up in 2 or 3 days....Just finishing off the torpedos..
    July 2008
Posted by vetteman42 on Saturday, April 23, 2011 3:27 PM
Bsyamato great detail work on the Gannet man !! I love the seat belts and the IP wiring you have done  YesYes
Julez the Biber is looking top notch buddy, that base really adds to it in a huge way. Cant wait for finished pictures.
De Havilland the Tracker is lookin superb
Kermit I have my model on the way for this build, well one of them anyways. A 1/700 Tamiya DD445 Fletcher Destroyer, I am still going to do a sub for this one too, gotta have sumpthin to drop depth charges on in the bath tub ya know Propeller
Randy So many to build.......So little time
    March 2011
Posted by de havilland canada on Wednesday, April 27, 2011 7:33 PM
I've decided on your advice Kermit.I will build a 1/48 scale Bonaventure aircraft carrier to glue the Tracker on,better than messing around with lead............LOL
    October 2008
Posted by bsyamato on Thursday, April 28, 2011 4:51 AM
Julez72
Big Smile it's just a dry fitting, before to finish seats i cannot glue the fuselage Crying
probably i'll finish my build for last SnailSnail
thanx Vetterman
de havilland canada
great! Yes
    July 2004
Posted by stikpusher on Thursday, April 28, 2011 2:39 PM
I resumed work on USS Ramsey last night, made enough progress to where I can begins some painting. At least the hull, main deck, and some superstructure areas. Pics once that has started.Wink
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by VanceCrozier on Thursday, April 28, 2011 3:10 PM
Hey Kermit - with this GB running into next year I may be able to add my name at a later time. I just wanted to reply so I can keep an eye on the thread
Catch you later,
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    July 2004
Posted by stikpusher on Thursday, April 28, 2011 6:36 PM
I applied a coat of Neutral Gray for Haze Gray on the hull and superstructuer and I used Gunship Gray for Deck Gray on decks...
 A couple over all shots with the superstructure sides held in place and the deck placed on the hull.
a close up of the 5" turret and the sonar dome after I sanded the putty smooth
close up of the 5" turret and ASROC launcher....neither are painted yet as I am still gonna add some detailing to each... I have drilled out the bore of the 5" gun.
close up of the Mack assembly and the gun director... I hollowed out the radar dish abit and am still gonna add some details there... the Mack will be dressed with some detailing up a bit before painting...
and a close up of the Tarter/Standard MR launcher and the fire control radar... again I bored out the radar dish, but still need to add more detail to that one as well...
       - Plankton
LSM
    March 2011
Posted by de havilland canada on Friday, April 29, 2011 12:11 PM
Lookin good Stik!!!
    July 2004
Posted by stikpusher on Friday, April 29, 2011 1:37 PM
Thanks DH!
I did a bit more work on her late last nite... my first ship PE...Toast Well nothing major, just a couple vertical ladders added on to the Mack assembly, but they are my first. I am sure under a coat of paint the will look good..
And not one to let some time go to waste, I scribed some detail onto the top of the ASROC launcher to match what I have seen in photos...
And then I did some work on the Sea Sprite helo: fuselage seam clean up, thin down the rotor blades some (not quite the right size for some PE one I have,, dang) and the main landing gear wheels were molded as a solid rod all the way across. I changed that to give two distinct (somewhat) wheels..
       - Plankton
LSM
Posted by VanceCrozier on Friday, April 29, 2011 1:42 PM
Looking good Stik, I've actually built this one myself, probably when I was still in high school + long-gone now. I was never a "blow it up" kinda guy, so I can only assume it ended up in a tiny little scrapyard somewhere!
    July 2004
Posted by stikpusher on Friday, April 29, 2011 2:08 PM
Thanks Vance. My original build of this went in to garbage as well. Unlike the USS Halsey which became a range target for my BB gun...
My next challenge is to scratch a new Air Search radar for her. The one that come with the kit is an older incorrect type.
       - Plankton
LSM
    October 2008
Posted by bsyamato on Friday, April 29, 2011 2:53 PM
stikpusher
Thanks DH!
http://i72.photobucket.com/albums/i181/stikpusher/models/Model%20WIPs/002-38.jpg
http://i72.photobucket.com/albums/i181/stikpusher/models/Model%20WIPs/003-25.jpg
http://i72.photobucket.com/albums/i181/stikpusher/models/Model%20WIPs/006-39.jpg
Great improvement Stickpusher!! now pieces looks better Yes .. Eye of jeweller on the kaman!!
    March 2011
Posted by de havilland canada on Friday, April 29, 2011 6:07 PM
Any little bit of extra detail helps huge.Those ladders look great!The seasprite looks really good too.The blades you have look nice too.I remember doing a small Seahawk ,and the blades were too thick and chunky so i used .006" brass shim stock which worked very well especially when I drooped them.Just a thought if you are not happy with the kit ones.
Cheers
Martin
    July 2004
Posted by stikpusher on Saturday, April 30, 2011 1:29 PM
"... but once you start down that path, forever will it dominate your destiny. Consume you it will!"- Yoda
Was he talking about the force or AMS???Surprise
Well painting for today is out due to windy weather (15-20 blowing straight into my garage where I paint and have the door open) So I decide I am gonna do more add on to the Mack. The molded exhast ventts were pretty weak, so I drilled them out. But then the openings did not look right... what to do???Hmm Some aluminum tubing to the rescue! I was able to get some to fit that I had, cut and filedthem to proper length, then bored out the edges to proper shape and now, some proper machinery exhaust vents... now to tackle that SPS-52 air search radar...Whistling
Thanks for the idea on the rotor blades Martin. I have brass shim stock in the drawerToast
       - Plankton
LSM
    October 2008
Posted by bsyamato on Sunday, May 1, 2011 8:16 AM
stikpusher
what's AMS? (learnirg Abbreviations mode i am)
little updtss
probeller sub-assemblies
Photobucket
finally started engines!
some refining on the nose
Photobucket
propeller gearbox
PhotobucketPhotobucket
(and anothe piece of lea added)
Photobucket
Hmm i predict great insanity problems to shape all pieces good
    July 2004
Posted by stikpusher on Sunday, May 1, 2011 1:54 PM
AMS- Advanced Modeler's Syndrome. The urge to continuously modify/detail any kit you are building, beacuase OOB (Out Of Box) is never right, good enough, etc. Be it purchased after market or scratch built gizmology it starts to consume your building style.
       - Plankton
LSM
    October 2008
Posted by bsyamato on Sunday, May 1, 2011 4:55 PM
stikpusher
..  feels like i'm infected Dead last years tried to do oob but even failed
    July 2004
Posted by stikpusher on Sunday, May 1, 2011 5:08 PM
You and I both my friend! I keep adding more PE to the Mack assembly. I will have a progress pic or two later this evening. Right now I need to pack for my island getaway that starts tomorrow...ParadiseCool
       - Plankton
LSM
    July 2004
Posted by stikpusher on Sunday, May 1, 2011 9:37 PM
Here is close up view of one of the new exhaust  vents. A big improvement!
well then I had to add vertical ladders to the mast, I off and re positioned the top portion from fore/aft to side to side, based off some pics I found. I also scratch built and added the cap for the top of the mast, added some PE railing to the yardarm, some anemometers, made and attached the SPS-10 Surface search radar. That little two piece item took me the longest time to get glued together properly...
front view
rear view
and a close up including the stack vents
Then I built a new SPS-52 Air Search radar. I superglued some Starbuck's Green Tea teabag mesh (a very fine nylon mesh perfect for this sort of stuff) to the main piece of sheet plastic for the texture, then added the side panels and lower bar from strip styrene. I attached it to the original kit radar piece base for mounting. It is not 100% accurate or perfect, but it is a big improvement over the kit part.
front view
rear view
and then placed on the Mack assembly
I am loving this first experience with this PE stuff here! More to follow next weekWink
       - Plankton
LSM
    March 2011
Posted by de havilland canada on Sunday, May 1, 2011 11:45 PM
Very nice indeed Stik.
That is a great idea for mesh...I will remember that one.
Can't wait to see some color on it!
Cheers
    July 2004
Posted by stikpusher on Monday, May 2, 2011 12:00 AM
I discovered that mesh by accident while Christmas shopping this past year. Had some green tea to perk me up and saw that the bag was a fine mesh... the modeler's eye said it would be useful. I am sure folks must have wondered why I put that thing in my pocket if anyone was watching...Confused It works excellent for 1/35 helmet nets too.
       - Plankton
LSM
    October 2008
Posted by bsyamato on Monday, May 2, 2011 1:07 PM
stikpusher
front view
http://i72.photobucket.com/albums/i181/stikpusher/models/Model%20WIPs/001-23.jpg
rear view
http://i72.photobucket.com/albums/i181/stikpusher/models/Model%20WIPs/002-39.jpg
that's great ! Yes not easy to see in the picture but i stand how's the mesh
    October 2009
Posted by Medicman71 on Friday, May 6, 2011 3:21 PM
Hey all,
Some nice builds going on in here. I think i'd like to jump in here on this one. I have the Italeri 1/48 S-3B Viking that i'd like to add. I'm going to do it in the Cenntenial colors.
Hey Stik, is that ship a early version of the Oliver Hazard Perry Class of ships. They look a lot alike.
Yamato- Nice Gannet. Nice to see one of those being built.
Julez and Kermit- Great looking subs.
de havilland canada- Cool looking Tracker. I wanted to see that kit built. Very nice paint job.
Here's a pic of the Viking i'm gonna do.
Building- (All 1/48) F-14A Tomcat, F-16C Blk 30, He 129
    July 2004
Posted by stikpusher on Friday, May 6, 2011 7:14 PM
Medic, she is the forerunner to the OHP Class. The Brooke Class were the first FFGs and served from the mid 60s onward. I really like your choice of subject material, that Viking is a great tribute to the old Scout/Observation Squadrons in early WWII!
Yamato, I took another pic of the scratchbuilt radar here, you can get a better idea of the mesh giving the grid pattern/texture on the radar faceplate.
Well, I spent much of yesterday before work adding PE to the Mack assembly and I began removal of the molded on stairs and adding on PE inclined ladders. Here are some pics of up to where I left off yesterday...
front and rear 1/4 views of Mack
superstructure sides- one with molded on stairs removed and PE inclined ladders added, one as molded...
and the molded on stairs on the superstructure that would be removed today and replaced by PE
then came today's work- molded on stairs removed and an opening made in catwalk for PE inclined ladder
PE inclined and vertical ladders added to superstructure
PE inclined ladders added to superstructure topsides after molded on stairs were removed
and final bits of PE railing added to Mack, as well as support beams for yardarm
and since weather conditions were good this afternoon, it was off to the paint shop for the hull. Lower hull was painted in MM Acryl Marine Colors Anti Fouling Red
and of course, then it was time for the place everything on the hull and take some shots pics...Stick out tongue
time to take a break...Whistling
       - Plankton
LSM
    March 2011
Posted by de havilland canada on Friday, May 6, 2011 7:26 PM
Stik...again looking very nice!!!!!
Medic welcome and funny you should say you wanted to see the Tracker built up because I wanted to see the Viking built before I got one so def. looking forward to it.Thanks for the compliments ,I am still waiting decals and final touches but you guys will see it here first.
I just got the AZ model Firefly in 1/48 so being that we have  till 2012 I think I will throw it in the build as well!!
Cheers all
Martin
