That's Amore (Italian GB) Jan 1-June 30 2012
    October 2009
Posted by PANZERWAFFE on Thursday, March 22, 2012 5:25 PM
Nice work in here guys Beer
Those are some crazy schemes on the aircraft, NICE!
TD4438 - Roma is really looking good.  Nice work with all the PE and camo - looks tedious.  Like those red stripes Yes
JACK - That is some really beautiful work on that CV3/33.  Excellent construction with that tiny fellow and the finish is very convincing.  I love it !!BeerBeer
ERIC - Fine jog thus far on your Semovente!  That barrel makes a big difference and looks great.  Have to tell you, I'm jealous of your groups GB badge Stick out tongue
Rob
Posted by tigerman on Thursday, March 22, 2012 8:54 PM
PANZERWAFFE
Rob, it's perfect for this GB. Sophia and Gina! Yes, they're lovely. well done badge by Jack.
You still have time to get in, and since the build is smaller then normal, I will probably extend the deadline for the badge.
 Eric
    June 2010
Posted by DoogsATX on Friday, March 23, 2012 2:01 AM
And...I'm calling the Fiat done!
All in all, a joy of a build and one of the best times I've had at the bench in some time! Thanks, Eric, for the absolutely fantastic GB!
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by tigerman on Friday, March 23, 2012 2:33 AM
Doog, I'm glad for you and sad for us that you finished. Beautiful build and I'm sad not to get to see more. Thank you for sharing your wonderful build and please pick up the badge.
 Eric
    October 2008
Posted by bsyamato on Friday, March 23, 2012 5:03 AM
Magnific Centauro Doogs Toast some external picture under the sun and can easily exchanged for the real one Yes
Eric hoping in an extend GB endline Whistling
    April 2011
Posted by Italian Starfighter on Friday, March 23, 2012 6:08 AM
Wow Doogs............when do you think to make the test fly?Ciao Enrico.
P.S.:to achive good result with stretched sprue:you cut more exact more possible your sprue,then glue it (I use super glue)...when glue is cured  take a lighter and a 5-6 cm of distance from aerial make same fast passages with flame on.........the sprue will tight like a violino chord.....it's more simply to do then to explane ,especially for me with my bad english!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://img.photobucket.com/albums/v381/tigerman12/ThatsAmoreGBBadge.jpg
    June 2010
Posted by DoogsATX on Friday, March 23, 2012 10:08 AM
tigerman
Well, I'm not entirely out yet. Still got my figure of Capt. Ugo Drago to deal with. Got it from Ultracast the other day. Detail = phenomenal. Painting instructions = non-existent. Huh?
    June 2010
Posted by DoogsATX on Friday, March 23, 2012 10:10 AM
Italian Starfighter
Oh yeah, I use the "flame-tauting" technique, only I use either a cigarette or a just-extinguished match.
I was talking more about stretching the sprue in the first place. I'm always snapping it, or not pulling it right and getting thick rods rather than thin, wire-like stretches. So I was pretty thrilled when I got it right the first time.
Posted by tigerman on Friday, March 23, 2012 12:44 PM
bsyamato
I suppose I can extend it to the end of June. That would make 6 months. That's plenty of time wouldn't you think?
 Eric
    October 2008
Posted by bsyamato on Friday, March 23, 2012 1:16 PM
Sounds good Toast i can finish the veltro with less worry and considering to get some tank/veiche in 1/72 to add here Embarrassed , will get something with the next supply order
    April 2006
Posted by jgeratic on Friday, March 23, 2012 6:30 PM
Doogs - wow, your's went pretty quick on that final stretch to completion.  That dazzle camouflage is certainly unique and you managed to pull it off quite handsomely - super work!
According to Mollo's book on WW2 uniforms, the Italian flight suit consisted of a brown leather helmet and the suit depended on the season.  Winter one was lined and was a brownish olive-green material while the summer was made of white linen.  Both were manufactured as one and two-piece versions.  I've also seen photos where the helmet appears white, so that too was likely some light weight cloth material.
Rob - thanks for those compliments.
I've cobbled together the two figures I will be using for the vignette (adding a third one made it appear too crowded).  Both heads and three of the original hands were replaced.
regards
Jack
    June 2010
Posted by DoogsATX on Saturday, March 24, 2012 2:18 AM
Thanks Jack! I've found a pic where someone painted the figure, and it definitely looks olive-ish.
Here's what I'm dealing with. Absolutely brilliant quality. I can't wait to mess it all up!
Here's the painted fig I'll be referencing:
    April 2006
Posted by jgeratic on Sunday, March 25, 2012 3:38 PM
Update...
Vallejo medium fleshtone sprayed on the faces.
LifeColor's paint set for Italian Army uniforms - found the blue for the coveralls looked way too bright and lively, so toned it down with some brown and sprayed both figures.  Continuing with the airbrush, mixed a couple lighter shades and sprayed from atop, using the airbrush like it were a light source.
Vignette base: Before applying the celluclay, I drilled and inserted about a dozen brass rods spaced around the outer edge - the paper mache product has a tendency to lift up when drying (this should help anchor it down).   Then sprinkled some Woodland Scenics sand and made some track imprints with the tankette model.   Followed this with some medium and course ballast.
regards,
Jack
Posted by tigerman on Sunday, March 25, 2012 6:33 PM
An update! I gave up spraying the camo and brushed on with various brushes. I tried to emulate the instructions, but that has never worked for me. I think it looks better from afar, but once the washes and weathering take place, I think it'll look better.
 Eric
    October 2008
Posted by bsyamato on Monday, March 26, 2012 5:37 AM
tigerman
An update! ...
LOL!!
Great updates guys YesYes
Posted by tigerman on Monday, March 26, 2012 11:44 AM
I haven't had too many of these. LOL I hope to crank out the weathering and finish this guy up in the next week or two.
 Eric
    March 2010
Posted by Nathan T on Monday, March 26, 2012 12:54 PM
Nice jobTigerman. camo looks real. Now that I've finished the 109 I can break out the veltro soon.
    April 2006
Posted by jgeratic on Monday, March 26, 2012 7:02 PM
Eric - I think the spinach camou looks good.  I agree, with weathering and what not it will all tie in nicely.   Will this be a Tunisian based Semovente?
Got both faces painted this afternoon, about three hours work.  Straight flat black on the helmets for now to better gauge the skin tones.   Blowing them up though I can  see some required touch ups.
regards,
Jack
Posted by tigerman on Monday, March 26, 2012 9:21 PM
Thanks guys.
Jack, it just says Ariete Division.and doesn't specify where.
Nice job on the heads.
 Eric
    October 2008
Posted by bsyamato on Tuesday, March 27, 2012 4:19 AM
Jack nice heads!! need to learn about.
only an update picture from me Sad
[View:/themes/fsm/utility/Photobucket:550:0]
Posted by tigerman on Wednesday, March 28, 2012 2:02 AM
I wonder if anyone here has some spare ,preferably transfers for my Semovente? My Tamiya ones shattered on me, so I'd prefer Italeri or someone else? thanks.
 Eric
    April 2006
Posted by jgeratic on Wednesday, March 28, 2012 4:22 AM
Eric - is it just the front and back license plates you need?  I don't have any ram's head nor those yellow triangle symbols.
regards,
Jack
Posted by VanceCrozier on Wednesday, March 28, 2012 6:59 AM
DoogsATX
http://i780.photobucket.com/albums/yy86/doogsatx/Aircraft/PCM%20Fiat%20G55%20Centauro/file-55.jpg
Beautiful job DoogsATX, I love that splinter-dazzle scheme. Cool
Great, now I'm telling myself I need something Italiano for the stash... Bang Head
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by tigerman on Wednesday, March 28, 2012 12:08 PM
jgeratic1
regards,
Jack
Yes Jack, just the front and rear license plates. The triangles would have been cool, as well as the rams heads, but the jerry-cans are in place of where those triangles would have went. I think a set of those by Model Victoria would cost in the mid-teens. A little steep for a few decals.
 Eric
    April 2006
Posted by jgeratic on Wednesday, March 28, 2012 12:23 PM
tigerman
I've got some left over from an Italeri Semovente.  Over 25 yrs old so tried dipping in water one of the German crosses.  Separated no problems and when I moved it around on the backing paper it did not break apart into pieces.
License plate number is 4473.  PM me a postal address and I'll send them on their way.
regards,
Jack
    October 2009
Posted by PANZERWAFFE on Wednesday, March 28, 2012 1:11 PM
Eric, looks like Jack has you covered but just in case I have these I can send you.  Just let me know Yes
I will need one set of the plates for a future build but there are 3 sets on here so just take your pick.  The ram heads I have no use for so they are yours if you like.  They are a bit larger then the Tamiya ones but were originally for an Italian M13/40 so they should work just fine.
Rob
Posted by tigerman on Wednesday, March 28, 2012 4:48 PM
Rob, PM coming.
 Eric
    October 2008
Posted by bsyamato on Saturday, March 31, 2012 3:06 PM
finally painted last cockpit details and added belts, now just waiting paint to dry and will glue the fusewlage soon.
painted belts with humbrol 94 (sand i think) and before to dry i pointed it with leather humbrol and mixed to have a color variance
Posted by tigerman on Saturday, March 31, 2012 8:47 PM
Got my decals today (thanks Rob), and laid down my gloss. Tomorrow, I will lay the decals and then gloss them.
Bsyamato, nice touches on the belts. You crazy air guys.
 Eric
Posted by tigerman on Sunday, April 1, 2012 6:55 PM
Decals on. They look good. Weathering maybe tomorrow.
 Eric
