First Annual Berny Memorial Group Build
    November 2010
Posted by Son Of Medicine Man on Thursday, November 15, 2012 10:58 PM
Bockscar
Okay:
Here's Ken's resin bay:
I think that third photo is the ECS bay, and you can see all the panel screws it needs to keep it snug:
I'm not sure it's even the same bay, but I sure want to get a copy of that book by now for sure!
Dom
Yes, if you are doing an USAF F-4 Phantom, you need this book.  It has a picture, (in color) of every angle and part of every version of the F-4 that the Air Force flew.  And it also gives a lot of detailed information about each area.
Ken
    April 2012
Posted by Striker8241 on Friday, November 16, 2012 8:18 AM
Bockscar
Russ, Get some pieces of 1" dense blue insulating styrofoam, and you can shape them to help sand curved surfaces. I also use soft urethane foam for large contoured areas, the foam keeps the pressure very even on the surface - very usefull for cutting through rough putty patches back down to the surface. i have made dull points, inside curves for sanding curved surfaces, or strips for sanding a fixed piece, kind of like buffing a shoe with a shoe-shine cloth.
Also indispensible are those rubber sanding sticks that look like big black nail files, come in all different grits.
Of course i wrap the sandpaper around pencils, straws, or just make a tube out of it.
If you fold fine a small square of emery paper twice, the sharp corner (where the middle of the square was) is great for 'digging' into tight corners.
I guess when you get down to the 1000 grit or so you get pretty excited about painting! --errr, well, I used to in a former life anyways.....lol
Dom
Thanks, Dom! Some more great tips there, my friend. I'll be heading to the hardware store today.
As for getting excited about painting, I may have to pass the 6000 grit point before that happens... Big Smile.
Russ
    August 2009
Posted by Sparrowhyperion on Friday, November 16, 2012 10:04 AM
Hi Folks.  I finally felt alive enough to trot down to the basement to use my system today.  I am still hacking up a lung, but it's not as bad today.  I just got through reviewing the last few days posts and I see a lot of great work from everyone.  I can't do a lot yet.  Jeez, just the small of glue makes me want to....  Well, you get the idea.  Just a reminder.  If anyone still wants to get in the Secret Santa build, you should check out the thread soon.  I only have a couple of people so far and I would really like to get some more to make it worthwhile.
Dom, I agree with you about the sanding with Dremel tools.  I have one of the older models, abouty 12 years old, with the variable speeds.  But even at it's lowest, and with the finest grit I have for it, it melts styrene pretty quickly.  I'm on a budget so I have the Wifey pick me up those cheap generic emery boards.  They work great if you use the fine grit side.  I use them to kno0ck down flash and sprue burs.  Then I keep some testors sanding sheets around for use on large parts.  I also have some rat tail files, and sanding rods.  Different stuff for different jobs.
Well, I am off to the upper floor before my headache gets worse.  I'll check in periodically as much as I can.
Rich
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
Posted by Gamera on Friday, November 16, 2012 1:58 PM
Rich: Good to hear you're feeling a little better, hopefully recovery isn't too far away.
Btw: Would join the Secret Santa but I'm wrapped up in stuff here. Last thing I need to do is jump into anything else. Good luck and I hope you guys have fun with it!
    March 2010
Posted by Scorpiomikey on Friday, November 16, 2012 3:28 PM
Good to hear you're on the mend. Im in the same boat as Gam. Too much on, and i dont even have my model space set up yet. Hopefully by tommorow night that will change.
Heres where im at at the moment.
Once i get the flooring down, ill put 2 desks in there and have twice as much room as i had at the old place.  My only problem is if i want to spray i need to do it over the grass out in the yard. The landlord would bust a gasket if i got paint on the lovely white walls lol.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    February 2010
Posted by Bockscar on Friday, November 16, 2012 4:28 PM
Striker8241
Bockscar
Dom
Russ
Russ:
That is canopy/glass polishing grit., i have some on little mylar squares, I think to about 4000 grit. That is going to be one glass smooth finish Russ!
Dom
    February 2010
Posted by Bockscar on Friday, November 16, 2012 4:30 PM
ECS is the Environmental Control System, in layman's parlance it is the air-conditioning unit. There's a compressor mounted about the middle, in the resin it is standing straight up, in the photo above it is on its side.
    February 2010
Posted by Bockscar on Friday, November 16, 2012 5:17 PM
Sparrowhyperion
Rich
Well Rich:
Nice to hear from you, I hope you won't be wiped out for the holiday season.
I mentioned I have a beginner-appropriate kit to donate to the Secret-Santa Group Build, but I'll be a lot more Santa than Builder......lol....
Yeah, I think Mikey was the one that has mentioned experience melting styrene with a Dremel. I had used high power rotary tools and bits in the past, but only for bronze or aluminum, for buffing they are okay on acrylic or polyester resin/fibreglass applications.
I suppose if you have a real steady hand, Dremel could save time cutting styrene, but I'm handy with X-Acto in my old age. Besides, if you really mess up a very expensive and extremely rare OOP kit with a Dremel, you can't slit your wrists like with a good ole' XActo either.....Bang Head
Dom
    February 2010
Posted by Bockscar on Friday, November 16, 2012 5:19 PM
Scorpiomikey
Gosh Mikey, that's going to be real nice. Hey, is that real sunshine out the window? We haven't seen any of that for a long time. Got a tiny bit today, but heck, very gray and dismal up here for so long.
i guess it could be New Jersey, so I should stop whining.
Dom
    April 2012
Posted by Striker8241 on Friday, November 16, 2012 6:24 PM
Bockscar
Striker8241
Russ
Russ:
Dom
Ah well, I meant that as a joke, Dom. I don't expect to get that detailed! Big Smile
Russ
    March 2010
Posted by Scorpiomikey on Friday, November 16, 2012 6:37 PM
After a small amount of cursing and a little bit of blood. Heres the floor done.
Dad came and helped me. and as he was sliding a piece in it caught and ripped his knuckle open.
But its down. Gonna wait for it to settle a bit, got 7 more sheets to play with if i ever want to. Hopefully later tonight ill have at least part of my setup done.
Oh and thats not sunshine, its pretty gloomy here today, but the front room/office gets so much sunlight it doesnt matter.
My signature
    February 2010
Posted by Bockscar on Friday, November 16, 2012 8:05 PM
Striker8241
Bockscar
Striker8241
Russ
Russ:
Dom
Russ
Not that detailed? After all the detail you've put into that BUFF? Now you are really putting me on Russ!!!Big Smile
Gosh, i was really looking forward to all those shiny wrinkles!Whistling
Dom
    February 2010
Posted by Bockscar on Friday, November 16, 2012 8:12 PM
Scorpiomikey
Excellent choice for the floor colour Mikey, No one will ever notice all the blood spattered gore!Big Smile
Good thing you put down that plastic under sheet!
I hope your dad is okay, and won't curse you for the damage. I gotta tell you man, sure wish my dad was around to help out now and again......looking forward to the rest of the room.
Dom
    February 2010
Posted by Bockscar on Friday, November 16, 2012 9:05 PM
Okay gents,
I must say, this is Spooky, fantastic box art:
Dang she's beautiful.......
Dom
    November 2010
Posted by Son Of Medicine Man on Friday, November 16, 2012 9:06 PM
Hi Rich,
Good to hear from you again.  I am glad that you are getting better.  I also hope you make it back in time for Thanksgiving!
Ken
    November 2010
Posted by Son Of Medicine Man on Friday, November 16, 2012 9:09 PM
Scorpiomikey
That floor looks great Scorpio Mike!  I really like that color.
Ken
    August 2009
Posted by Sparrowhyperion on Friday, November 16, 2012 9:10 PM
At this rate, I'll be happy to be fully flight ready by Xmas.  As it is I had to sit out Marissa's Bday party, such as it was.  Lucky we don't have to drive to go to Deb's Mom's place for Turkey Day.  We live there now... lol
Son Of Medicine Man
Hi Rich,
Ken
    November 2010
Posted by Son Of Medicine Man on Friday, November 16, 2012 9:30 PM
Hi Everyone,
On the topic of using the Dremel, I use a cutting bit, at the slowest speed.  And when I cut, I go at a very slow pace and only cut out large areas.  Going at a slow pace is the key.  That way you can keep control of the tool.
I agree that using a grinding wheel with the Dremel on plastic would be a bad idea.  The speed at the edge of the wheel would be much faster than the speed in close to the center (like the small diameter of the cutting bit).  So even at the slowest speed setting you would still have too much speed at the edge of a grinding wheel which would produce too much heat.
I did not get anything done last night because I had to work on a computer.  But the good news about that is I made some extra cash to spend!  Smile  And tonight was our local chapter's monthly IPMS meeting.  Another good time!
Ken
    February 2010
Posted by Bockscar on Friday, November 16, 2012 9:37 PM
Ahhhhhhh Sensei Ken San....yes.....sometimes, the sword must move slowly........
Good to hear you are making money, gosh knows you can't make a dime selling Twinkies anymore.....
How did the IPMS meeting go, see anything cool?
Ken,
Is this a Kadena Voodoo?
Dom
    November 2010
Posted by Son Of Medicine Man on Friday, November 16, 2012 9:59 PM
Bockscar
Dom
Big Smile  You totally crack me up Dom!  Big Smile
On the topic of our IPMS meeting, one member did bring in a DVD with still pictures of Iwo Jima during WWII.  It mostly was of P-51s.  They were all black and white.  There were some of B-29s.  Some crashes.  All in all, pretty interesting.
Another member brought in a 1/72 Special Hobby B-18 Bolo.  A very nice kit!  All engraved panel lines, lots of detail parts, and lots of detail!
Ken
    November 2010
Posted by Son Of Medicine Man on Friday, November 16, 2012 10:03 PM
Bockscar
Ken,
Dom
Yes Dom!! That is a "Cotton Picker" 15th Tactical Reconnaissance Squadron RF-101C!
Ken
    April 2012
Posted by Striker8241 on Saturday, November 17, 2012 8:24 AM
Bockscar
Dom
You want shiny wrinkles? I'll send you a picture of my face lol! Big Smile  On second thought, you probbly just ate...Ick!
Russ
    April 2012
Posted by Striker8241 on Saturday, November 17, 2012 8:28 AM
Sparrowhyperion
Rich
Hi, Rich,
Good to hear you're on the mend. Get plenty of rest and don't worry about modelling for awhile till you're better.
Russ
    February 2010
Posted by Bockscar on Saturday, November 17, 2012 2:43 PM
Gents:
Have a Happy Thanksgiving!
-and many more!
Dom
    March 2010
Posted by Scorpiomikey on Saturday, November 17, 2012 3:06 PM
Isnt thanksgiving next week?
My signature
    February 2010
Posted by Bockscar on Saturday, November 17, 2012 5:51 PM
My family got me a 1.5 gallon "depth charge"....lol....keg of beer for Thanksgiving.....
too bad you guys are too far away to join me.....BeerBeerBeerBeerBeerBeerBeer....I hope that was enough to go aroundBig Smile
    November 2010
Posted by Son Of Medicine Man on Saturday, November 17, 2012 7:25 PM
Scorpiomikey
For the United States this year it is November 22nd.
Ken
    November 2010
Bockscar
Why thank you Dom!  Yum, yum.  What flavor is that?
Ken
    April 2012
Posted by Striker8241 on Saturday, November 17, 2012 7:36 PM
Son Of Medicine Man
Bockscar
Ken
Ahh... beer flavor?  Big Smile
    February 2010
Posted by Bockscar on Saturday, November 17, 2012 7:38 PM
Ken:
That's a 'Lake of Bays Pale Ale' Ken....malty....lol
I like doing Thanksgiving twice a year......lol......
as a Canadian, I don't get Thursday or Friday off but
I have to say, I have a lot to give thanks for, so far.....Smile
Black Friday is catching on up here.....it was bound to happen.....Yes
Dom
