Japanese Group Build Part III
Posted by Gamera on Saturday, August 23, 2014 3:37 PM
WW: Thanks!
Wayne: Looks good!
Jack: LOL, no big deal - I thought 'ringleader' was pretty hilarious! So you do want to be the 'muscle?' Stick out tongue
    September 2011
Posted by falconmod on Monday, August 25, 2014 7:23 AM
I only got the LG added to my plane this weekend.  at least one step closer to being able to weather the bottom.
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
Posted by Gamera on Monday, August 25, 2014 10:49 AM
Falcon: Looks good to me, everything all neat and even. Were the landing gear bays natural metal or are you covering them with translucent blue-green for the aotake?
Didn't get much done here, painted the pitot tube and extendable steps aluminum and hated it. So I airbrushed them primer and then hit them with Alclad... a pile of work for three tiny pieces the size of a piece of paper clip wire.
    July 2004
Posted by stikpusher on Tuesday, August 26, 2014 12:28 AM
More beautiful work here guys. Well I figured that I had better get my hiney in gear and start my build before this becomes another GB that I watch go by without successful completion.... or even starting... Embarrassed So tonite I began...Propeller
For my kit choice, I am building AFV Club's 1/350 IJN Submarine I-19
Step 1 is adding the crane to the foredeck and retractable boom mast to the after deck, as well as some sort of cylindrical container that goes under the sail/conning tower.
Step 2 was adding the bow diving planes
Step 3 was adding the deck to the bow and a capstan- infortunately my tweezers launched the kit part into oblivion, so I scratched a new one from some styrene rod
Step 4 was adding the capstan, screw guards, and upper rudder & guard to the stern
I did skip adding the PE parts to the bow and crane for tonite. I figured that launching the bow capstan was a bad omen for more tweezer work tonite...StormHmm
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Gamera on Tuesday, August 26, 2014 8:37 AM
SP: Very nice, you're making fine progress! The capstan looks perfect!
    July 2004
Posted by stikpusher on Wednesday, August 27, 2014 12:08 AM
Thanks G! Thank goodness that the capstan was an easy piece to replicate and replace and that there was another to use as a guide for doing so...Black Eye
Well today was another session in between steps of another couple of projects. And I pretty much finished all the building today except for adding the PE and a couple of parts not glued in place to ease painting. Oh yeah, I am holding off in building the float plane as that is a little beast with lots of PE options. So here we go with today's steps.
Step 5, the aft diving planes, lower rudder and prop shafts. I left off the screws until after painting. This area was really delicate.
Step 6, the pressure hull and stand- I dont know why they included the pressure hull as once the upper and lower hulls are joined you can not see it because the limber holes are molded recessed, not open, A bit of over engineering here again
Step 7 is building the Float Plane, which as I said above I skipped for now. Step 8 was the beginning of the sail/conning tower
Step 9 is the completion of teh sail/conning tower. I left the upper portion loose to aid in painting the wood deck in there. I also left off the twin mount 25mm AA gun for painting purposes.
Step 10 was adding the guards around the bow diving planes and the float plane catapult
so here is the upper hull placed on the lower hull and conning tower placed on the hull.
I just need to add the PE, and then I can start painting. So far, so good, lost bow capstan notwithstanding.
       - Plankton
LSM
Posted by Gamera on Wednesday, August 27, 2014 8:41 AM
Wow, she's coming right along SP. I've always liked AFV Club armour (despite the zillion injection pin marks) but never tried building any of their ships or aircraft. Looks like a really well engineered and detailed kit.
    July 2004
Posted by stikpusher on Wednesday, August 27, 2014 10:54 AM
Oh AFV's armor is gorgeous. As is this kit. But yes, very intricate and fragile. And well engineered and detailed. She is a beauty for sure. This thing is pretty big too- as big as a modern sub and way bigger than a Type VII U-boat.
       - Plankton
LSM
Posted by Gamera on Wednesday, August 27, 2014 1:43 PM
Ummmmmm, might have to pick up one for myself...Whistling
    July 2004
Posted by stikpusher on Wednesday, August 27, 2014 2:08 PM
Well if youre feeling realy rich and bold you can get the Academy 1/350 USS Indianapolis that comes with PE, Wood Decks, Brass guns, and the AFV Club I-58 kit. The I-58 is the sub that sank USS Indianapolis on her ill fated final voyage.
       - Plankton
LSM
Posted by Gamera on Thursday, August 28, 2014 8:35 AM
stikpusher
Hmmm, interesting idea- wonder if I can find a 1/350 Robert Shaw??? Wink
Actually I'd thought about picking up the same kit there of the I-19. On September 15, 1942 she launched a six torpedo spread at the USS Wasp hitting her with three and crippling her. Of the three errant torpedoes one hit and sunk the destroyer USS O'Brien and one hit the USS North Carolina killing five of her crew and injuring 23. The USS NC is museum is a couple of hours away from where I live and I've been on her almost a dozen times now so that adds a lot to my interest in the I-19. Still don't have a model of the USS NC though- battleships seem a lot of work to get looking good.
    October 2008
Posted by bsyamato on Monday, September 1, 2014 10:26 AM
I there Propeller
Great works on the Zero's and george finished John and Bob YesYesYes
So many updates Here guys Indifferent i returned today from holidaysbut have some trouble in the workbench to return soon on modelling.
Heres the finished pictures of the hasegawa Sonia i finished about three weeks ago Embarrassed
First pictures are took at dawn and sunset.. after regular pictures
more pictures here, two pages
http://s405.photobucket.com/user/bsyamato/library/modellismo/00%20WW2%20vol%203/Ki-51%20Sonia%20hasegawa%2072/Finished?sort=3&page=1
I hope you like it Smile
Asap will continue on the kurogane car
    April 2006
Posted by waynec on Monday, September 1, 2014 12:21 PM
that turned out really nice. i like the dawn pictures. reminds me of pearl harbor pre launch pictures.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Posted by Gamera on Monday, September 1, 2014 5:18 PM
Very nice work as usual Bsyamato!!! I too love those dawn/twilight photos! I'll get you posted when I get back on the desktop computer.
BTW: The Shiden is done, except for the stupid blasted radio ariel behind the cockpit-it's fell off about a dozen times so far and now I can't find it at all. Guess I'll have to make a new one...
    July 2004
Posted by stikpusher on Monday, September 1, 2014 6:40 PM
waynec
I was thinking the same thing...Hmm Very nice work BSY
Gamera, tough break on the antenna mast. But that should not be too difficult to scratch up a new one.
As for me, yesterday I airbrushed the lower hull with Tamiya Hull Red
and then today I spent a couple of hours today putting on the PE parts onto my I-19. Let's just say it was a less than pleasurable experience and many Censored were uttered...Whistling But I perservered
and afterwards it was time for the airbrush again... I airbrushed on a coat of Humbrol 1 Primer Gray
then a test fit & shots of the upper and lower hulls together
More to follow soon....
       - Plankton
LSM
    September 2011
Posted by falconmod on Tuesday, September 2, 2014 6:43 AM
I got some weathering done this weekend, yaa hoo!
Sorry for the fuzzy second picture.
John
Posted by Gamera on Tuesday, September 2, 2014 8:07 AM
SP: I see what you mean about a PE headache, looks good though!
John: Nice work, almost there now!
    July 2004
Posted by stikpusher on Tuesday, September 2, 2014 10:50 AM
Yes, the PE does look good once it's on and under a coat of primer. I can not fault AFV for their results, but dang that was a trying task. Well now I am up to final paint scheme for it. Everybody likes to depict I-19 as she looked when she sank the Wasp, but I stumbled across a few tidbits of information over the past couple of days and I am leaning towards them now. I-19 was involved peripherally with the Pearl Harbor attack, sailing ahead of the carrier strike group and on the morning of the attack being in position to act as a radio beacon between the fleet and Oahu for returning aircraft. After her duties were done that morning the subs were cut loose to hunt and strike on their own in the waters surrounding Hawaii. A week or so later, she was one of several subs ordered to do the same off of the US West Coast. Arriving in California waters in the latter part of December she stalked and attempted to sink several merchant ships but most of her torpedoes missed. On Christmas, she did succeed in torpedoing a freighter just off Point Fermin that had to be beached nearby at Fort MacArthur to prevent her sinking. Her final task of the sortie to the West Coast was to have been participation in a bombardment of selected locations along with several other I-boats, but  most of the other submarines assigned to this task had exhausted their fuel reserves at the scheduled time of the action and so the mission was cancelled. Since all these incidents occurred locally to where I live, I like the tie in to the subject. I can see Pt Fermin and Ft MacArthur from the beach near where I live. For her time on these operations I-19 was painted Black with Black stained wood decks.
       - Plankton
LSM
Posted by Gamera on Tuesday, September 2, 2014 12:09 PM
Sounds pretty cool SP, looking forward to seeing her in black on black.
    April 2006
Posted by waynec on Tuesday, September 2, 2014 6:42 PM
while i'm working on the JGSDF Type 87 (indy tracks) and the Type 82 6x6 i started goofing with a 1/72 TYPE 61. will post pictures later.
    October 2008
Posted by bsyamato on Wednesday, September 3, 2014 3:58 AM
Thanx for comments guys Bow Down
Stik cool sub you're building, wishing to get an I-400 in future
Good paint Job John
Waynec wishing to see soon the type 61 pictures , i love 1/72 armour Cool
Posted by Gamera on Wednesday, September 3, 2014 6:56 PM
Bsyamato: Sorry it took me a little bit there but you're now up on the finished page. I liked the dawn/twilight photo though you can't see as much so I used it, if you'd rather have another let me know and I'll swap it out.
Wayne: That Type 61 sounds pretty cool too, did you want me to put that down as well?
    July 2004
Posted by stikpusher on Thursday, September 4, 2014 3:09 PM
I am glad that you guys are liking this. This is how it is looking so far with a base coat of Tamiya Flat Black on the upper hull
and placed on the lower hull
just for you guys to get an idea of the size of this thing, here it is compared with a 1/350 Type VIIC U-Boat
and compared with a 1/350 Flight II 688/Los Angeles Class SSN Attack Sub
She is a big boat, especially by WWII standards...Surprise
       - Plankton
LSM
Posted by Gamera on Thursday, September 4, 2014 5:54 PM
She looks good in black SP, seems like all WWII subs would have been painted like that for a little extra stealth at night.
And really wow, I knew they were large boats but not almost as big as a modern attack sub!
    April 2006
Posted by waynec on Thursday, September 4, 2014 6:36 PM
Gamera
hey GAMERA i'm sure to get the TYPE 82 6x6 and 1/72 TYPE 61 done. on the SPAA as soon as i get focused on indy track i will work on that. just annoying. OTOH ww1 presentation is done and club newsletter is going well.
as some of you know i have gotten into 1/72. here is latest.
didn't like open fenders so blanked them in.
    April 2006
Posted by waynec on Saturday, September 6, 2014 5:30 PM
TYPE 61 is primed and ready to basecoat JGSDF GREEN. i will finish getting TYPE 82 ready and primed hopefully on Sunday and basecoat both at the same time. 6 wheels are finished so it's upper and lower hull. haven't decided how open this will be. i may have it completely buttoned up as i have a second one in the stash and my friend is going to cast a couple of driver figures from the JGSDF LAV for me.
Posted by Gamera on Saturday, September 6, 2014 6:03 PM
Hey Wayne, looking good so far! Amazing they can squeeze that much detail into 1/72nd!
    February 2014
Posted by silentbob33 on Saturday, September 6, 2014 6:57 PM
I'm out of it for a week and I miss all the awesome work going on.  The sub looks great so far SP. And I'll second Gamera's comment, I had to go back and check the scale on the box for that tank
On my bench: Academy 1/35 UH-60L Black Hawk
    July 2014
Posted by modelcrazy on Saturday, September 6, 2014 9:46 PM
I know you are getting close to the end, however I'm starting a 1/35 Tamiya type 97 Chi Ha for the World at War GB, Can I join up with it?
Steve
    April 2006
Posted by waynec on Sunday, September 7, 2014 9:38 AM
silentbob33
i agree. the sub is looking quite menacing. 1/72 has some interesting possibilities for dioramas too. change of plans. my frau and i are heading to GREAT SAND DUNES NATIONAL PARK for a couple of hikes and i have a lecture on the russia/ukraine situation tuesday morning so no bemch time for a couple of days. have a local contest in october so i best be about it eh?
