100th Anniversary of WWI GB
    January 2014
Posted by Rob S. on Thursday, September 18, 2014 6:36 AM
Mike..thanks! Yes, the array of possibilities makes me want to do more Rolands too, LOL!! 'They' really did make interesting paint schemes compared to the British for sure. Option D, Koch's mount paint scheme black and white is going to be a stunner!!
______________________________________________________________________________
On the Bench: Nothing on the go ATM
Posted by Bish on Thursday, September 18, 2014 2:05 PM
John, I am really liking that. I am glad I picked that one as well, that scheme with the markings is really nice.
Guys, I have been following along, but the work is of such a high standard, I think I have run out of things to say without repeating what's been said. Especially the woodwork.
Just amazing.
    November 2008
Posted by plasticjunkie on Thursday, September 18, 2014 2:33 PM
Blue, Rider, Wnut, Rob, falcon....The quality of work here is just incredible. I slacked off a bit and you guys are doing a KILLER job.
Here's my small contribution so far:
Got some sanding done and getting the fuselage ready for that funky bright green this scheme takes. The nose is yellow and is taped up.
A good match is Testors Beret Green in the small bottle so need to get me that one to shoot the fuselage then will be able to apply the lozenge on the top of the lower wing and the rest of the under wing lozenge decals.
 GIFMaker.org_jy_Ayj_O
    September 2011
Posted by falconmod on Thursday, September 18, 2014 2:46 PM
Bish,
  Yes I really like how the dragon is turning out.   I think you will enjoy it as well, the decals went on real easy.    I have to add the radiator tube from the engine to the wing radiator as Eduard doesn't supply one.  Can't wait to put it in the done column. Toast
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
Posted by Bish on Thursday, September 18, 2014 2:54 PM
John, what are you using for that tube. I was looking at the kit before and made a point of checking out that area. Am I right in thinking it take hot water up to the wing where its cooled and then brings it back down to the engine.
Posted by Bish on Thursday, September 18, 2014 2:55 PM
Looking nice there PJ. I bet you guys are glad you don't have to paint those wings.
    November 2008
Posted by plasticjunkie on Friday, September 19, 2014 6:38 AM
LOL Bish. That would be quite a task even tough I had to mix my own paints to touch up one wingtip area that the decal came up short.
Years ago I was building a radio controlled Fokker E.V with an 80" wingspan and was planning on doing the lozenze with Humbrol enamels and a med. sized flat brush. That would have been one heck of a hair pulling experience. We moved out of state so I sold some of my things to de clutter so the plan never materialized.
    September 2011
Posted by falconmod on Friday, September 19, 2014 6:57 AM
Bish
Yes that is what it is used for.  there is also another one the is mostly vertical further back like in the center of the middle of the wing that goes from the radiator to somewhere on the back of the engine, but that one is impossible to add now, not to mention you could hardly see it at all. I'm using some Plasticstruct .080 rod for that tube.
John
Posted by Bish on Friday, September 19, 2014 12:34 PM
John, thanks for the clarification. Given there is two tubes, I would guess the one at the front takes up the hot water and the one at the back takes the cooled water back to the tank, that would make sense.
PJ, my step dad used to build RC aircraft and he did a German one with the lozenge scheme, I think it was a Bip but now idea what, and I am sure he painted the pattern on the wings.
    June 2010
Posted by rocker286 on Friday, September 19, 2014 1:20 PM
Hey everybody, I managed to do a bit more work on my Nieuport before I had to get ready for work: DSCF1586
4badges
    April 2005
Posted by wing_nut on Friday, September 19, 2014 6:50 PM
Rocker the Nieuport I looking greatly.
PJ that too is looking pretty special.  If I ever had the thought of hand painting the lozenge on an 80" wing... I would have moved too.  Even if I wasn't planning to.Whistling. But that would have been a sight to behold.
Marc
    October 2013
Posted by Big Blue on Friday, September 19, 2014 8:37 PM
People are putting up some fine looking builds here; it is great to see.  My Eindecker is going to be on hold for a little bit while I wait for some replacement decals from New Zealand.  I decided to attempt to repair the seam along the back of the fuselage, and doing so will require replacing a couple of decals.
I will continue to work on the engine, so may have an update or two in the interim, but other than that, progress will be a bit slow.  I'm going to have to live vicariously through your updates!
Blue
    April 2013
Posted by SchattenSpartan on Saturday, September 20, 2014 5:46 AM
Both the Nieuport and the Focker are looking great, guys!
    January 2014
Posted by Rob S. on Saturday, September 20, 2014 6:52 AM
I certainly echo the comments gents. Great work. I think I'm a 'lozenged' out about now, LOL!!
    January 2014
Posted by Rob S. on Saturday, September 20, 2014 8:41 PM
An update to my progress on the Roland:
Upper wing done..here's the rib taping and Balkenkruez (both sides are done):
Rad and compass detail:
I installed all wing supports on the top wing and will work with it this way for a change. I usually try to fit the top wing onto the structures, so, this time I will try it this way:
I pre-attached all of the rigging lines on the top wing before installing on the struts. Way easier to work with for sure. Thanks to WNW perfect engineering, the wing just really dropped into place:
Ready to start attaching rigging lines:
You can see I completed the landing gear rigging. Went well with the turnbuckles pre-placed:
This will be done soon! MTF
    January 2014
Posted by Rob S. on Sunday, September 21, 2014 4:42 PM
I seem to be hogging the updates, LOL, but, I got more:
Rigging tightened up marvelously with the pre-positioning of the lines and the even more spectacular turnbuckles:
Prop detail, cell phone cam can't focus well on fine details:
Nose added and detailed with hairspray weathering:
Mounted..no glue required, friction fit very well and snuggled well into orifice:
Rad lines and upper wing reservoir:
Wheel detail:
She is done. I will post my final posed pics later. I am working on a display base for the Montreal International Model Meet on 4 Oct. Here's a shot of her done, but, will take more complete pics soon.
Posted by Bish on Sunday, September 21, 2014 5:01 PM
That is just amazing Rob, just beautiful. I can't get over the look of the wood and the wings make it one eye catcher.
I have to ask, what's with the colour of the tires. I would have said you have forgot to paint them, but I know you haven't missed something like that.
Can't wait to see this on the base, and I believe this is the first completed build in the GB.
Posted by Bish on Sunday, September 21, 2014 5:03 PM
rocker, that's looking good.
Blue, I hope they arrive soon, really looking forward to seeing more of that build.
    January 2014
Posted by Rob S. on Sunday, September 21, 2014 5:07 PM
Hey Bish, thanks so much. Just simple Sky Gray on the tires. WnW's plastic is EXACTLY that colour for sure, when you spray it on, it doesn't look like anything is happening. I've never done a base before, just doing it for the show. MTF.
    January 2014
Posted by Rob S. on Sunday, September 21, 2014 5:14 PM
Bish...Doug (rigidrider) was first to finish with his sexy black and white DVII about a week ago, I believe.
    February 2006
Posted by ruddratt on Sunday, September 21, 2014 5:27 PM
PJ - the D.VII is looking real nice!  That lozenge can be a pain in the you-know-what to apply, but man, it really adds some pop to these birds and sets them apart from anything else. Good stuff!
rocker - I'm enjoying watching the Nieuport come together.  I've got a Roden 1/48 version of that bird and have been eyeing it more than usual seeing your build progress.  Keep up the great work!
Rob - my hat's off to you sir!  That is a build anyone would be proud to display and it's really set the bar high.  The woodwork, the subtle shading, and the attention to detail - just,  WOW!  Bow Down
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    January 2014
Posted by Rob S. on Sunday, September 21, 2014 5:57 PM
Thanks Mike. It was fun..can't wait to dive into another WnW this winter. I need to get more technical with my wooden biplane props, though. Too 'stripy' on this one, but, will work on the next one that much harder.
    April 2005
Posted by wing_nut on Sunday, September 21, 2014 6:47 PM
WOW Rob it really doesn't get better than that.  A real eye popper for sure.
Marc
    February 2005
Posted by 65ss on Sunday, September 21, 2014 7:32 PM
Rob - That really looks great!
Rocker- The Nieuport looks good.
John - That plane looks great!
Dale
    January 2014
Posted by Rob S. on Sunday, September 21, 2014 8:06 PM
I dunno, want to post final pics but Photobucket is acting stupid, again!! Will try tomorrow.
    June 2010
Posted by rocker286 on Sunday, September 21, 2014 10:16 PM
Wow folks, just wow. Everyone's builds are looking fantastic! Watching everyone's progress is like visiting a miniature aircraft factory. This is really an awesome GB. I finally had a weekend to wind down after a pretty busy month, and I spent that wind down time putting decals on my Nieuport! DSCF1589 Ruddratt, hopefully this will provide you with further motivation to open up that 1/48 Nieuport you've got!
4badges
    January 2013
Posted by jibber on Monday, September 22, 2014 7:17 AM
Rob what a beautiful build, I can't even say what I like the most its done so much care. I looked at closeups of every part and thats a piece of art my friend. Terry
    January 2014
Posted by Rob S. on Monday, September 22, 2014 8:42 AM
Thanks Terry...WnW deserves the credit for such superior products!!
Posted by Bish on Monday, September 22, 2014 12:40 PM
Rob Sherman
Yes, of course he did, how could I forget.
Thanks for the info on the tires.
Mike, in David's absence, could you add the completed builds to your roster.
    January 2014
Posted by Rob S. on Monday, September 22, 2014 3:57 PM
Well, seems PB is cooperating so I can post my better finished pics of the Roland..apologize for inundating the blog with so much stuff!!
And, the final shot, for the show in Oct:
