Bomber GB ' 18 - '19
    April 2010
Posted by Theuns on Wednesday, July 4, 2018 9:27 AM
The fit of the nose section is not great, it is to narrow for the fuselage so I had to cut it open and insert a filler piece.
 IMG_20180704_091619 by Theunis van Vuuren, on Flickr
The rest of the fot sofar it looks good.
 IMG_20180704_093648 by Theunis van Vuuren, on Flickr
Theuns
    September 2017
Posted by Sailing_Dutchman on Friday, July 6, 2018 11:07 PM
I have hit a bit of a snag, this is my first aircraft and I can not figure out how to fill the wing roots. Does anyone have any tips? Any help would be much appreciated.
    July 2014
Posted by modelcrazy on Friday, July 6, 2018 11:25 PM
SD, depending on the width of the gap you can do several things. For big gaps some members will fill the area with streached sprue and glue it in with plastic glue or CA. Thinner gaps can be filled with putty. There are several types avaliable. I like Perfect Plastic Putty however it is water based and very easy to remove with water, but you can remove too much this way. Another product I use a lot is Mr Surfacer 500 or Mr Disolved Putty. Both are liquid of sorts and can be sanded or removed with Denatured Alcohol. I like to wet sand the seam with the alcohol and something like 1000 grit sandpaper. 2 cents
Steve
    July 2014
Posted by modelcrazy on Friday, July 6, 2018 11:33 PM
BTW Theuns and Bish, The Badger is not working out like I wanted. The seams are being dificult, the paint isn't my best and I lost intrestet in it. I think I'll put it aside and pick the Nell back up. I have renewed intrest in it because of the Prince Of Wales build I'm formulating in my wee little head. The Nell and a Betty would make intresting stable mates if you will, with the POW.
The Badger will likely show up on the next shelf of doom build once I get back into it.
Steve
    April 2010
Posted by Theuns on Sunday, July 8, 2018 12:27 AM
I know that feeling of sa model fighting you all the way Steve...
I am waiting for my decals to arive and now I hear that the post office is on strike - again. So as per usual they will chuck all the parcles and post in the street. I hope my decals will come through before the go this route.
Here in SA the entire postal service is a hitt and miss affair, sometines you get mail, sometimes not.
Theuns
    July 2014
Posted by modelcrazy on Sunday, July 8, 2018 6:15 AM
And I complain about our Postal Service because I get a package a day or two later than they said. I have nothing to complain about. Tongue Tied
Steve
    April 2010
Posted by Theuns on Monday, July 9, 2018 1:17 AM
Some guys here that order parcles from overseas are saying that after 6 months they still get nothing, even though the tracking system shows that it was delivered to SA a week at most from send date. Pitty is that like with most things here the state run institutions (medical, security, schooling ,univercity) we will have to go private run, hassle it that only 16% of the population can afford it, like hospital ect.....I am not one of the 16% :-(
The post office has taken over the payment to a few million people of social grants because the agency that was supose to do so is so corrupt that the courts stoped them doing so. Low and behold this past week people didnt get their grants, the post office had to go hand out food parcles to try make up for the "inconvienience"
My fokls are also on that grant system so I know how badly the running of even the most basic of services have gone to naught , really sad.
So we take our chances here and hope for the best.
Maybe I will be lucky and my decals do not get trashed.  Well they are in the system already, before the strike started so I cant do anything about that anyway but wait and see.
Rant mode off :-)
In the meantime I am slowly making headway on the Panther, I am almost ready to prime. Will post soe pix later
Theuns
Posted by Bish on Monday, July 9, 2018 2:35 AM
Theuns, nice work on the Panther, the pit came out well. Nice fix on that gap.
Posted by Bish on Monday, July 9, 2018 2:36 AM
Steve, pity about the badger, but hope to see it back at some point.
Posted by Bish on Monday, July 9, 2018 2:39 AM
Dutch, wing roots can be a pain, especially if there is much detail arouind the area. I have only had to deal with fairly small gaps which i fill with filler, i now use Perfect Plastic Putty. I normally use an old scalpel blade, preferably one that still has its point, so i can get it just into the gap.
Posted by Bish on Monday, July 9, 2018 2:41 AM
Blimey, like Steve, i don't think i have anything to complain about with out post office.
Reading what you said, that would explain why the part i ordered from S Africa last year took so long to get here. Hope your decals make it safe and sound.
    April 2010
Posted by Theuns on Monday, July 9, 2018 4:35 AM
What I do sometimes on wing fillets is to mask off either side of the area needing filling. Maybe a mm max then aply tamiya uutty and immidiately wipe off the excess with an earbud dipped in meth spitirs to form a nice round fillet, sometimes no after sanding is even needed.
Theuns
    September 2017
Posted by Sailing_Dutchman on Monday, July 9, 2018 6:11 AM
Thank you for the help, I ordered some PPP and Mr Disolved putty and will try those out when they arive.
    April 2010
Posted by Theuns on Monday, July 9, 2018 8:57 AM
I have used PPP before and almost nothing works better. However I have found that mine becomes dry in the tube neck no matter how much care I take to seal it well :-(
Theuns
Posted by Bish on Monday, July 9, 2018 9:05 AM
Theuns
Theuns
Same here and i am finding it really hard to squeeze up any of the softer stuff.
    April 2010
Posted by Theuns on Monday, July 9, 2018 10:18 AM
I use so little at a time that it becomes an issue. Pitty it is so expensive to loose more than 75% of a tube :-(
Theuns
Posted by Bish on Monday, July 9, 2018 10:22 AM
Ye, i know what you mean. I have taken to useing tweezers to get at the good stuff lower down.
    July 2014
Posted by modelcrazy on Monday, July 9, 2018 10:47 AM
I have the same problem. I wonder if reconstituting the harder stuff with water would work Huh? I'll have to give that a try.
BTW, don't worry about the Badger, it'll end up in the next Shelf of Doom GB. I do want to finish it one day.
I'm about to get back on the Nell though.
Steve
    October 2009
Posted by greentracker98 on Thursday, July 12, 2018 12:04 AM
Okay Herre's my Bomber start Finally!!
Jack Northrup's x/B-35
A.K.A. Ken                Making Modeling Great Again
    October 2009
Posted by greentracker98 on Thursday, July 12, 2018 12:30 AM
    April 2005
Posted by taxtp on Monday, July 16, 2018 8:15 PM
modelcrazy
I'm looking forward to it Steve :)
I'm just taking it one GB at a time.
Posted by Bish on Tuesday, July 17, 2018 1:59 AM
jack, got your hell diver added. My apologese, it completly slipped my mind.
    October 2009
Posted by JacknewbIII on Tuesday, July 17, 2018 2:03 AM
No problem Bish thank you!
    April 2010
Posted by Theuns on Tuesday, July 17, 2018 2:12 AM
Guys if I am offline for a bit dont worry, I have not bailed, just out of data ;-)
Will return soon and Bish will look after you for now.
Theuns
Posted by Bish on Tuesday, July 17, 2018 2:23 AM
Cheers for the heads up Theuns, i'll keep an extra eye out.
    February 2007
Posted by Lodni Kranazon on Tuesday, July 17, 2018 2:33 AM
If I'm not too late, I have an old 1/72 Frog A-20 Havoc that I would like to enter with. I was going to do it up in early North Africa RAF markings.
[Admiring Starbuck's space fighter] Cassiopeia: It's a perfect machine! Born to dance amongst the stars! Starbuck: Yeah, it's bumping into them that has me worried.
    April 2010
Posted by Theuns on Tuesday, July 17, 2018 11:33 AM
Welcome, I got you up the roster page with the havoc :-)
I have primed the F-9 and will try to get dome paint on be the weekend. On this trumpeter kit the rivet detail is rather heavy but hopefully under the gloss paint it will be better.
Theuns
    February 2007
Posted by Lodni Kranazon on Tuesday, July 17, 2018 2:08 PM
Thank you very much Theuns! Looking forward to seeing more of your F9F. Awesome work all! Also looking forward to seeing that XB-35 in progress - I have one in the stash.
    February 2007
Posted by Lodni Kranazon on Tuesday, July 17, 2018 3:22 PM
Going to shoot for something like this. The A-20C pictured was taken in Langley, Virginia. I think it was before delivery but the photo is staged. The boxing I actually have is the old 'Air Lines' that I purchased as a bagged kit.
Tags: A-20 , 1/72 , A-20C , Air Lines , Frog , Havoc , Langley
    February 2007
Posted by Lodni Kranazon on Wednesday, July 18, 2018 3:40 AM
I've heard it takes quite a bit of weight in the front to keep this thing down. Going to make some bulkheads and floors out of lead to help keep it from tail sitting!
