Hello!
It's been a long time, but I'm movin' on with the project.
Brizio, it's probably going to brak your heart , but I already started carefully breaking my first truck apart, to be rebuilt, as written in the original post.
The problem I had from day one - almost - and I couldn't remedy this as I originally built my truck, was the bad hood to cab fit. The hood didn't want to close properly. The first reason for this is obvious after you look at this foto:
What I did was to cut the entire top out of the hood and substitute a new, straight one out of styrene sheet. Of course it's not that easy, after you find out the top isn't entirely flat, it's slightly curved. To get this curve I glued a strenghtening brace under the hood, this brace also helps to make the hood stiffer. Here's what I got:
While building the hood I read through lots of reference material and here comes the big surprise - this truck is almost no Mack at all. It rides on a stolen Freightliner chassis, and to top it off, the cab is incorrect too. That's why it has no Mack logos on it. I'll describe the modifications I'm going to do here as I work on them, for now only an outline:
-Hood - add Mack logos
-Cab - narrow thecab by 4-5 mm, redo the exhaust stack braces, redo the mirrors
-Sleeperbox - stretch to enlarge it.
-Frame - where the real fun begins - build new front frame portions, new crossmembers.
-Rear suspension - install Mack camelback suspension
By the way - the kit engine is a Cummins, should be beige and I think I'm going to keep it.
Now let's see how it turns out. Thanks for reading, have a nice day
Pawel
