Imai Golden Hind 1/70
    January 2015
Posted by rdiaz on Wednesday, January 28, 2015 2:18 AM
Thank you very much for the insight, jtilley. I've found brass pedestals with a keel slot that is 3,8 mm - just about right. I think Amati makes them. I have no Dremel nor money for one right now, but maybe I could use a small round file to make the hole before the hull halves are assembled together.
Philo426, I'm from Spain, so no Lowe's - but I'll keep looking Thanks a lot!
Posted by CapnMac82 on Wednesday, January 28, 2015 9:10 PM
Any second-had appliances places (especially ones that do repairs)?
Back before Dremel came in variable speed we would find plug-in sewing machine pedals to control them.  That, and a regular corded drill can get you closer than hand filing.
Oh, and your English is most commendable--far better than my Spanish.
    July 2010
Posted by docidle on Thursday, January 29, 2015 8:03 PM
Another option if I may intercede, is the method I am using on the Nina and Pinta. I drilled holes in the keel and then used screw/bolts for holding the model in place. Covering the nails are brass tubes that are the same width as the keel. I then cut the tubes to the desired height, slip them over and epoxy the top portion of the screw that will be inside the model.
The base is bass wood stained light. Since the Nina and Pinta were simple merchant ships, I chose a base that was simple so as to not take away from the models.
I have used brass pedestals on other models I have done when the scale is appropriate.  You can ruin the overall effect of a beautifully built model if the stand or pedestals are too large or too small.
You can also see that the keel cracked a bit just behind the forward hole, but a little green putty, sanding and repainting made it disappear.
Just my one cent.
Steve
    January 2015
Posted by rdiaz on Friday, January 30, 2015 1:08 AM
Great stuff, docidle! I'm also building the Pinta and finished Revell's Santa Maria a few weeks ago (my first ship model). Might experiment with mounting the Pinta this way...
The Constitution is 630mm long including bowsprit and spanker boom, so I think the 26/29 mm pedestals (with 3'8mm slots) will be fine.
