UH-1E from an F + B or C?
    September 2015
Posted by Aaronw on Thursday, April 16, 2009 7:08 PM
Any shots of the rotor brake? Is that something you would notice on a model or is it something you would only see by opening up the cowling?
    January 2007
Posted by rotorwash on Thursday, April 16, 2009 7:36 PM
Aaron,
  I'm sure Supercobra will be along with a much better photo, but here is a UH-1E with the twin M-60 TAT 101 turret mounted under the nose.  Look directly below the roof mounted pitot tube and on the right side of the roof instrument panel. That handle is for the rotor brake.
    Ray
Photobucket" border="0" />
    June 2003
Posted by supercobra on Thursday, April 16, 2009 7:47 PM
The brake itself is on the transmission (looks like a disk brake) and you would only see it with the cowl open.  However, the handle and master cylinder is on the cockpit roof:
    September 2015
Posted by Aaronw on Friday, April 17, 2009 12:39 PM
Ok, so if I have read all this right, an E can be made by simply adding a winch and a brake lever to a B or C (as appropriate) with the exception of a few rare cases that combined bits from the B & C?
The same applies to the UH-1L, TH-1L, and HH-1K?
 rotorwash wrote:
Here's what most Echo's look like.  Note roof mounted pitot, left handed fuel filler, 540 rotor head, Particle separator and rescue hoist.  No armemant installed on this one, but the TK-2 kit was used on most Vietnam UH-1E's:
If that is the case then, I could do the one in this pic with a UH-1C kit, a winch and the Cobra Company 540 rotor? Would UH-1E "slicks" like the photo be appropriate or were they normally gunships?
Did the USMC use the nose mounted grenade launcher as is done on the Revell "Huey Hog", I seem to recall that kit has all kinds of inaccuracies for a UH-1E. I'm thinking about grabbing one of the Hobby Boss UH-1 kits for the weapons, just wondering if the GL would be appropriate for the E or if I should save it for a C. Doing the E as a slick would at least eliminate the issue of making a correct weapons mount for it.
    September 2015
Posted by Aaronw on Friday, April 17, 2009 12:44 PM
Also anyone have a good shot of the winch? I have a couple available to me, but not sure if any will work or if I'd need to make something.
I have MM USMC green, would that be the color to use or are the USMC helos OD like the Army ones?
Oh, and thanks. I did not expect to see so much info, but it is nice to have it.
    January 2007
Posted by rotorwash on Friday, April 17, 2009 1:17 PM
Aaron,
  Yep, basically if you want a accurate E in 1/72 scale add the winch and rotor brake to either the italeri B or C kit with a 540 rotor for the C.  You could also steal a 540 rotor from a 1/72 cobra kit as long as it had the sqare-tipped old style blades and was from a model with 44ft rotors.
   In 1/48, you could either get the UH-1C update set from Cobra Company and do a C-based Echo or just get a UH-1D/H rotor and cut 2 scale feet off each blade and add blade counterweights.  The Huey Hog is basically a B with a 540 rotor.  Hey, you could build the infamous 540 B straight from the box!  The only isssue with making a B-based acho other than the rotor would be the late style particle filter.  All B-based Echos I have seen had the bell mouth intake instead.  You could graft the bell mouth intake from the older Monogram/Fijimi UH-1B kit.  That's really about all those kits are good for anyway.  Oh and whatever you build remove the nose mounted FM antennas from the nose as no Marine Echo I've seen had em.  For a B-based Echo don't forget to leave off the roof mounted pitot and make a nose mounted one as well.
As far as armament, you really need the TK-2 kit used by the Marines to be accurate.  currently, that is unavailable in any scale that I am aware of.  Also, as far as I know no Marine Huey ever carried the M-5 40mm grenade launcher on the nose.  The TAT 101 turret would look cool though, but alas there is no plastic available for this either to my knowledge. If there was any chance that the Marines ever flew with Army weapons, it would be the 20 UH-1B's we've been discussing above.  Never seen a pic, so can't really comment there, but even then they probably had Marine weapons if they were not configured as slicks
UH-1E slicks are perfectly legit for Vietnam as you can clearly see in the book link posted by Supercobra above.
For UH-1L, TH-1L and HH-1K info go here (read beyond the initial rotorhead discussion):
/forums/785871/ShowPost.aspx
For more on the Echo go here:
/forums/804031/ShowPost.aspx
Hope that helps,
       Ray
    September 2015
Posted by Aaronw on Friday, April 17, 2009 4:46 PM
When you said "beyond the initial rotorhead discussion" I was a bit confused, I thought everything in here was rotorhead discussion. However I see you literally meant discussion about rotorheads. Smile [:)]
    January 2007
Posted by rotorwash on Friday, April 17, 2009 5:42 PM
Yep, we kinda hijacked Mel's thread and went a little crazy (but crazy in a good way)Big Smile [:D]
   Ray
    January 2007
Posted by rotorwash on Friday, April 17, 2009 5:52 PM
Randy,
  This is what I get for not going back and reading old posts.  I was just looking through the thread I posted above on Navy Hueys and I found this reply from Steve Hornberger, who flew UH-1E, UH-1L's, TH-1L's, UH-1N's and who know what else.  Anyway, it speaks to the fate of the UH-1B's that entered Marine service and I thought it deserved being repeated here:
Hey Ray,
Yes, I flew the E operationally and the UH-1L/Th-1L and E as an instructor in HT-18.
There may be semanics here, but the Marines got a load of UH-1B's (20) from the Army in 1966 and 67 to fill a shortfall of ordered UH-1E's.  The B was marginal for the marines due to no rotorbreak which is needed for shipboard use (I forgot to mention the rotorbreak in my above comments).  The loaners were mostly used in the states for training but some got to VN.  Thats why you'll see some of those counterwieghts on Marine birds.  They may be painted Marine green but they were your standard B underneigth.  All the surviving B's were eventually returned to the Army.
From my understanding very few UH-1L's were produced and all went to the HAL squadrons who needed the bigger engine.  There were a few airframe casualties in VN but all the rest went back to the training command to soldier on.  My "numbers" include UH-1Es, UH-1Ls and TH-1Ls.  I know of no HH-1Ks there, but then a K is nothing but an L.  That was a time that the Marines were moving to the UH-1N so they were getting rid of the E.  There was no lack of airframes for HT-18.
The Marines had several HH-1Ks as SAR birds also, but again if you need a K and only T/UH-1Ls are available..voila, you have an HH-1K.  I could be wrong about the K if it included special Electical components for MEDEVAC equipment.
Regards
Steve"
Posted by Melgyver on Friday, April 17, 2009 10:51 PM
Not my thread!  Aaronw started this, I just contributed to the confusion!  Heh, heh!
Clear Left!
Mel
    January 2007
Posted by rotorwash on Friday, April 17, 2009 11:04 PM
  And your doing it again, Mel!   I was referring to the reference Aaron made about my reference to the UH-1C rotorhead thread you started so long ago.  I can't believe you could be confused by such a simple reference to a reference about a reference!
(the above said with a wide grin on my face lest you actually think I'm upset)
Posted by Melgyver on Saturday, April 18, 2009 10:29 PM
Ray,
Of course I'm doing it again!  I can't remember last week!  CRS!  Heh, heh!
Clear Left!
Mel
Posted by Melgyver on Tuesday, April 21, 2009 9:10 PM
Guys,
I was looking for something esle and found this list I didn't know I had.  It's a list of the Helicopters that were assigned to the 174th AHC.  Notice 8 are listed as UH-1B's.  There are pictures on our Web page of a couple of these birds but they are called "C's" and look just like Charlie models except lacking the FOD screens.  It doesn't appear that they have the extended collective levers either.  Confused, heck I stay that way now days!  So they have to be the "infamous" UH-1B-540's".   I talked to a buddy of mine yesterday and he said they had a few too in the 20th ARA.
Check out the two pictures towards the end of Dick's page.  Hueys "424" and "425"  http://www.174ahc.org/oham-01.htm
Clear Left!
Mel
    January 2007
Posted by rotorwash on Tuesday, April 21, 2009 10:31 PM
Mel,
   Here's the info I have from the VHPA Gold Book with all the 174th helos listed. On this list the only UH-1B flew only 10 hours in the unit.  All the 65 birds are listed as C's. Talk about confusing.
   I looked at the photos and those birds and they look like C's to me.  I even see the weapons brace on the M-3 armed bird.  The bell mouth intake is the only thing that might have made someone think those were B's.  At the end of this post is a pic of one of the 2/20th ARA birds you were talking about from 65.  You can see all the UH-1C features including the left handed fuel filler, but it has the bell mouth intake and nose mounted FM antennas as well.
  I'm wondering if something like we have been talking about with the Echo didn't happen with the first C's. You know, they were on the line to be built as B's but ended up coming out as C's.  kinda like the second production batch of Echos switched from B-based frames to C-based frames in the middle of the production run.  Just a guess.  Anyway, the plot thickens.
    Ray
Information on helicopter in 174 AHC
174 AHC
(UIC Code = WC42AA)
Begin Finish Total
Purch. in in Hours
Tail Date Unit Begin Unit Finish in
Model Number MMYY YYMM Hours YYMM Hours Unit
UH-1D 63-12983 1164 6708 1193 6801 1754 561
UH-1D 64-13555 0265 6708 1508 6709 1740 232
UH-1D 64-13822 1065 6707 1677 6708 1875 198
UH-1D 64-13870 1165 6610 372 6704 970 598
UH-1D 64-13885 1165 6709 1605 6712 2041 436
UH-1C 64-14109 0865 6812 663 6907 1102 439
UH-1M 64-14140 1065 7009 1428 7112 2239 811
UH-1C 64-14157 1165 6805 812 7002 1815 1003
UH-1C 64-14162 1165 6705 567 6705 599 32
UH-1C 64-14170 1165 6909 2034 7103 3072 1038
UH-1C 65-09423 0166 6610 237 6705 470 233
UH-1C 65-09424 0166 6610 304 6705 533 229
UH-1C 65-09425 0166 6610 239 6702 348 109
UH-1C 65-09426 0166 6610 173 6801 927 754
UH-1C 65-09428 0166 6610 194 6801 616 422
UH-1C 65-09429 0166 6610 211 6804 941 730
UH-1C 65-09430 0166 6610 212 6705 518 306
UH-1B 65-09431 0166 6610 84 6610 94 10
UH-1C 65-09432 0166 6610 229 6705 397 168
UH-1C 65-09470 0266 7101 2202 7112 2605 403
UH-1C 65-09484 0366 6703 393 6705 572 179
UH-1C 65-09504 0366 6808 907 6808 908 1
UH-1C 65-09507 0466 7008 2465 7102 2987 522
UH-1M 65-09540 0566 7008 1192 7112 1976 784
UH-1C 65-09555 0566 7005 1708 7011 2030 322
UH-1C 65-09557 0566 6706 462 6710 706 244
UH-1D 65-09605 0166 6610 186 6612 334 148
UH-1D 65-09619 0166 6610 215 6610 309 94
UH-1D 65-09621 0166 6610 402 6802 1945 1543
UH-1D 65-09638 0166 6610 518 6705 1116 598
UH-1D 65-09639 0166 6610 478 6802 2124 1646
UH-1D 65-09640 0166 6610 333 6802 1941 1608
UH-1D 65-09641 0166 6610 402 6804 2289 1887
UH-1D 65-09642 0166 6610 366 6807 1866 1500
UH-1D 65-09643 0166 6610 386 6705 987 601
UH-1D 65-09644 0166 6610 412 6712 1766 1354
UH-1D 65-09646 0166 6610 372 6804 2092 1720
UH-1D 65-09647 0166 6610 299 6707 1103 804
UH-1D 65-09648 0166 6610 478 6801 2088 1610
UH-1H 65-09679 0266 7105 3669 7112 4161 492
UH-1D 65-09906 0566 6610 80 6807 1927 1847
UH-1D 65-09910 0566 6708 527 6806 1469 942
UH-1D 65-09911 0666 6610 140 6804 2049 1909
UH-1D 65-09933 0666 6610 128 6611 128 0
UH-1D 65-09938 0666 6610 119 6702 607 488
UH-1D 65-09939 0666 6610 90 6804 1201 1111
UH-1D 65-09946 0666 6610 52 6709 1167 1115
UH-1D 65-09952 0666 6610 82 6801 1759 1677
UH-1H 65-10020 0766 6812 1652 6902 1893 241
UH-1D 65-12863 0966 6611 0 6712 1472 1472
UH-1D 65-12872 0966 6703 97 6805 1621 1524
UH-1D 65-12874 0966 6703 256 6703 352 96
UH-1C 66-00590 0966 6811 1280 7004 2314 1034
UH-1C 66-00621 1066 7005 1700 7012 2087 387
UH-1C 66-00645 1066 6910 1170 7101 1912 742
UH-1C 66-00646 1066 6809 1111 7006 2429 1318
UH-1C 66-00662 1166 7004 1194 7004 1274 80
UH-1M 66-00722 0167 7103 1305 7112 1596 291
UH-1D 66-00864 1066 6707 690 6805 2014 1324
UH-1D 66-00874 1066 6703 101 6802 1356 1255
UH-1D 66-00888 1166 6710 846 6808 2051 1205
UH-1H 66-00993 1266 6903 1030 6907 1571 541
UH-1D 66-01016 1266 6710 780 6805 1804 1024
UH-1H 66-01022 1266 6905 656 7010 2107 1451
UH-1C 66-15040 0267 6908 1313 7004 1787 474
UH-1C 66-15045 0367 7003 1920 7011 2490 570
UH-1C 66-15060 0367 6806 420 6910 912 492
UH-1M 66-15089 0467 7103 1857 7112 2198 341
UH-1C 66-15092 0467 7102 2073 7103 2098 25
UH-1C 66-15094 0467 7101 1254 7103 1321 67
UH-1C 66-15098 0467 6905 706 7006 1407 701
UH-1C 66-15105 0467 6707 0 6801 536 536
UH-1C 66-15106 0467 6707 0 6801 559 559
UH-1C 66-15137 0567 6707 0 7003 1778 1778
UH-1C 66-15138 0567 6707 0 6804 561 561
UH-1C 66-15161 0667 7012 1494 7102 1612 118
UH-1C 66-15162 0667 6803 153 6904 830 677
UH-1C 66-15165 0667 6712 172 6807 743 571
UH-1C 66-15169 0667 7101 2399 7103 2433 34
UH-1M 66-15190 0767 7103 2198 7112 2639 441
UH-1C 66-15201 0867 6803 168 6804 300 132
UH-1C 66-15221 0967 6806 300 6810 570 270
UH-1C 66-15224 0967 6806 305 6902 906 601
UH-1M 66-15242 1167 7103 1556 7112 1981 425
UH-1D 66-16080 0267 6704 1 6801 957 956
UH-1D 66-16100 0267 6804 791 6806 913 122
UH-1H 66-16155 0367 6902 662 6907 1208 546
UH-1H 66-16186 0367 6908 2132 7112 3345 1213
UH-1D 66-16201 0367 6804 516 6805 660 144
UH-1D 66-16235 0467 6706 0 6707 278 278
UH-1H 66-16406 0567 7107 2168 7111 2496 328
UH-1H 66-16511 0667 6903 1211 6903 1335 124
UH-1H 66-16589 0667 6812 495 6902 712 217
UH-1H 66-16651 0767 7103 2641 7110 3334 693
UH-1H 66-16811 0967 6805 277 6811 806 529
UH-1D 66-16863 0967 6802 13 6805 498 485
UH-1D 66-16867 0967 6802 8 6805 359 351
UH-1H 66-16954 1067 6809 360 6905 1122 762
UH-1H 66-17017 1167 6903 255 6904 516 261
UH-1H 66-17036 1167 6901 99 7011 2355 2256
UH-1H 67-17036 7011 0 7011 0 0
UH-1H 67-17191 0168 7012 2615 7103 3069 454
UH-1D 67-17193 0168 6802 0 6805 534 534
UH-1D 67-17203 0168 6802 0 6802 82 82
UH-1D 67-17209 0168 6802 0 6805 438 438
UH-1D 67-17281 0268 6803 0 6804 112 112
UH-1D 67-17282 0268 6803 0 6804 219 219
UH-1H 67-17359 0368 7008 1734 7102 2341 607
UH-1H 67-17410 0468 6805 2 7103 2334 2332
UH-1H 67-17419 0468 6805 1 6904 1233 1232
UH-1H 67-17421 0468 6805 2 6904 1379 1377
UH-1H 67-17428 0468 6805 0 6903 938 938
UH-1H 67-17430 0468 6805 1 7010 3195 3194
UH-1H 67-17444 0468 6805 1 6808 289 288
UH-1H 67-17445 0468 6806 2 7012 2989 2987
UH-1H 67-17471 0468 6805 0 7104 3368 3368
UH-1H 67-17503 0568 6806 0 7101 2278 2278
UH-1H 67-17512 0568 6806 2 6904 1213 1211
UH-1H 67-17519 0568 6806 2 6901 959 957
UH-1H 67-17521 0568 7105 2739 7111 3278 539
UH-1H 67-17530 0568 6806 2 6808 335 333
UH-1H 67-17540 0568 6806 0 7106 3240 3240
UH-1H 67-17543 0568 6806 2 7011 3091 3089
UH-1H 67-17550 0568 6806 2 6904 1286 1284
UH-1H 67-17566 0668 6807 0 6811 619 619
UH-1H 67-17588 0668 6807 0 7004 2160 2160
UH-1H 67-17718 0868 6809 0 7007 2483 2483
UH-1H 67-17753 0968 6810 0 6905 573 573
UH-1H 68-15215 1268 6901 0 7102 2045 2045
UH-1H 68-15223 1268 6901 0 7104 2833 2833
UH-1H 68-15403 0269 7012 799 7102 856 57
UH-1H 68-15458 0369 7011 1411 7112 2413 1002
UH-1H 68-15463 0369 6904 0 7101 2233 2233
UH-1H 68-15529 0469 6905 0 6905 127 127
UH-1H 68-15531 0469 6905 0 6905 105 105
UH-1H 68-15639 0569 6906 0 7103 2137 2137
UH-1H 68-15644 0569 6906 0 7010 1853 1853
UH-1H 68-15661 0569 6906 0 6910 676 676
UH-1H 68-15671 0569 6906 0 7102 2005 2005
UH-1H 68-15676 0569 6906 0 7112 2763 2763
UH-1H 68-15677 0569 6906 0 7010 1614 1614
UH-1H 68-15680 0569 6906 0 7011 1861 1861
UH-1H 68-16122 0869 7105 1154 7112 1825 671
UH-1H 68-16180 0869 7101 2125 7102 2197 72
UH-1H 68-16225 0969 6910 0 7004 603 603
UH-1H 68-16340 1069 6911 0 7112 1709 1709
UH-1H 68-16573 1269 7105 203 7111 824 621
UH-1H 68-17566 6808 0 6808 0 0
UH-1H 69-15200 0370 7004 2 7007 439 437
UH-1H 69-15284 0470 7005 0 7102 1057 1057
UH-1H 69-15423 0670 7006 0 7112 1650 1650
UH-1H 69-15516 0770 7008 0 7112 1389 1389
UH-1H 69-15533 0770 7102 506 7107 925 419
UH-1H 69-15651 7105 0 7105 0 0
UH-1H 69-15730 1070 7011 0 7112 1211 1211
UH-1H 69-15759 1070 7107 505 7107 579 74
UH-1H 69-15763 1070 7011 0 7111 1197 1197
UH-1H 69-15767 1070 7012 0 7104 515 515
UH-1H 69-15768 1070 7105 433 7111 1180 747
UH-1H 69-15783 1070 7011 0 7102 300 300
UH-1H 69-15953 0171 7102 0 7112 685 685
UH-1H 69-15958 0171 7102 0 7111 715 715
UH-1H 69-16650 0171 7103 0 7111 530 530
UH-1H 69-16667 0171 7103 0 7103 108 108
UH-1H 69-16698 0171 7103 0 7111 725 725
UH-1H 69-16716 0271 7103 0 7106 306 306
UH-1H 70-15711 0371 7105 33 7112 342 309
Total helicopters = 167 Total number of hours = 142370
Photobucket
[img]http://Photobucket" border="0" />[/img]
    April 2009
Posted by Huey367 on Thursday, April 23, 2009 4:22 PM
A note about the Marines having B and C model Hueys. VMO-1 at New River had repainted Army B and C before the E models began to arrive in 1967. This was due to the first production models going to USMC units (VMO 3 and 6) in Vietnam. As we received the E's, we sent the B and C's back to the Army. The Marine Corps E model Hueys were a similar to the B and C's in shape, but a different animal. They were made to Navy / Marine Corps standards and none of the Marine or Navy Hueys were converted B or C models. Also, the USMC UH-1E had 2 staggered horizontal M-60 machine guns with a 19 shot 2.75 rocket pod of the ordance racks on either side of the Huey. We didn't like the 7 shot. The door gunners had M60s with various and homemade mounts.
Posted by grandadjohn on Thursday, April 23, 2009 6:01 PM
From the look of the yellow and red markings, I believe this is an early C model before they started putting on the particle seperators.
Wanted to add a note that a few B model gunships survived into the 70's and early 80's, We had a few in my Guard unit during that time period. Can't remember in some had the old M-22 (SS-11 missile system) installed
    January 2007
Posted by rotorwash on Thursday, April 23, 2009 6:41 PM
Welcome Huey 367!  You happen to have any pics or info on the Charlie models from the Army?  The B models are well documented here now, but I would really be interested in any info on Army C models that went to the Marines.  It is hard for me to believe the Army would have given up a Charlie during that time period as the Cobra was not yet fully fielded and the C model was the interim gunship.  I'll never say never, just hoping you might have a photo or a tail number.
The M-60/2.75 in rocket setup you mentioned is called the TK-2 system. It's mentioned and I believe I posted a photo early in this thread.  The Marine H-34's used the TK-1 system.  I'd LOVE to see any photos you have of ANY Marine Hueys from that time period!
   Thanks,
         Ray
    January 2007
Posted by rotorwash on Thursday, April 23, 2009 6:43 PM
Grandad,
  I totally agree.  In fact, I have yet to see an actual photo of something I'd call a 540 B even though I know they existed.  Any chance you have any photos of NG B's?  I'm supposedly building one for Jon for the NG Museum and I need some good ref shots.
     Ray
Posted by grandadjohn on Thursday, April 23, 2009 6:47 PM
I'll check Ray
    January 2007
Posted by rotorwash on Thursday, April 23, 2009 6:48 PM
Thanks Grandad!  I appreciate it.
  Ray
Posted by grandadjohn on Thursday, April 23, 2009 6:58 PM
Ray, found this one, others I can't make out enough detail to be sure, all are aerial like this one, need to dig a little deeper
    January 2007
Posted by rotorwash on Thursday, April 23, 2009 8:24 PM
Grandad,
  BEAUTIFUL!!!!!  That is a great shot.  If you find anymore of her please post em.  Here's her history from the VHPA Gold Book data.  Thought you might be interested.
    Ray
Information on helicopter 63-08721
Helicopter UH-1B 63-08721
Information on U.S. Army helicopter UH-1B tail number 63-08721
Date: 01/28/65
Accident case number: 0B299 Forced Landing without damage Accident
Number killed in accident = 0 . . Injured = 0 . . Passengers = 0
costing 0
Source(s) from which the incident was created or updated: Army Aviation Safety Center database.
Crew Members:
AC CW COSIMANO A
Date: 12/01/65
Accident case number: 0D326 Fatality Accident
costing 2844
Crew Members:
AC O3 KIBLING CA
CP O2 EVORS FL
CE E2 LINEHAM D
G E3 SPEARMAN S
The Army purchased this helicopter 0864
Total flight hours at this point: 00002124
Date: 08/13/67
Unit: 116 AHC
This was a Combat incident. This helicopter was REPAIRED IN THEATER
This was a Recon mission for Armed Escort , Other Aircraft.
While Enroute this helicopter was at Level Flight at UNK feet and 080 knots.
Not Reported
Helicopter took 1 hits from:
Small Arms/Automatic Weapons; Gun launched non-explosive ballistic projectiles less than 20 mm in size. (7.62MM)
The helicopter was hit in the Forward area
Systems damaged were: MAIN ROTOR SYS
The helicopter Continued Flight.
The aircraft continued and accomplished all mission objectives.
Original source(s) and document(s) from which the incident was created or updated: Survivability/Vulnerability Information Analysis Center Helicopter database. Also: LNOF, 73397, JSIDR (Lindenmuth Old Format Data Base. Joint Services Incident Damage Report. )
Total flight hours at this point: 00002280
Date: 09/20/67
Unit: 116 AHC
This was a Recon mission for Armed Recon
While Enroute this helicopter was at Level Flight at 0300 feet and 080 knots.
South Vietnam
Helicopter took 10 hits from:
The helicopter was hit in the Cockpit
Systems damaged were: PERSONNEL, STRUCTURE
Casualties = YES . .
Original source(s) and document(s) from which the incident was created or updated: Survivability/Vulnerability Information Analysis Center Helicopter database. Also: LNOF, 73710, JSIDR (Lindenmuth Old Format Data Base. Joint Services Incident Damage Report. )
Total flight hours at this point: 00002401
Date: 10/04/67
Unit: 116 AHC
for Close Air Support
While in Target Area this helicopter was Attacking at 0500 feet and 080 knots.
South Vietnam
The helicopter was hit in the Passenger Cargo Section
Original source(s) and document(s) from which the incident was created or updated: Survivability/Vulnerability Information Analysis Center Helicopter database. Also: LNOF, 73850, JSIDR (Lindenmuth Old Format Data Base. Joint Services Incident Damage Report. )
Total flight hours at this point: 00002451
Date: 11/21/67
Unit: 116 AHC
Unknown this helicopter was Unknown at UNK feet and UNK knots.
South Vietnam
Helicopter took 3 hits from:
Systems damaged were: FUEL SYS, MAIN ROTOR SYS, STRUCTURE, ENGINE
Original source(s) and document(s) from which the incident was created or updated: Survivability/Vulnerability Information Analysis Center Helicopter database. Also: LNOF, 74117, CRAFX (Lindenmuth Old Format Data Base. Crash Facts Message. )
Total flight hours at this point: 00002523
Date: 01/05/68
Unit: 116 AHC
While Enroute this helicopter was at Level Flight at 1000 feet and 080 knots.
South Vietnam
The helicopter was hit in the Right Side
Systems damaged were: UNK
Original source(s) and document(s) from which the incident was created or updated: Survivability/Vulnerability Information Analysis Center Helicopter database. Also: UH1P3, 00505 ()
Date: 01/14/68
Unit: 116 AHC
Unknown this helicopter was in Orbit at 0700 feet and 080 knots.
South Vietnam
The helicopter was hit in the Engine Compartment
Original source(s) and document(s) from which the incident was created or updated: Survivability/Vulnerability Information Analysis Center Helicopter database. Also: UH1P3, 01409 ()
Date: 01/16/68
Unit: 116 AHC
While in Target Area this helicopter was Attacking at 0300 feet and 080 knots.
South Vietnam
The helicopter was hit in the Tail Section
Original source(s) and document(s) from which the incident was created or updated: Survivability/Vulnerability Information Analysis Center Helicopter database. Also: UH1P3, 01605 ()
The following is Goldbook information on US Army helicopter UH-1B tail number 63-08721
It is provided here as an ESTIMATE of the history of this helicopter and is not intended to be the final authority.
This helicopter was purchased by the US Army in 0864.
Please provide any additional information on this helicopter to the VHPA.
DATE  FLT HRS    UIC      UNIT          AREA          POST          COUNTRY
6610 84 1994 WAX7AA 114 AVN CO AML VIETNAM RVN
6611 23 2017 WAX7AA 114 AVN CO AML VIETNAM RVN
6612 0 2017 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA SUPMACOM
6701 0 2017 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA AVCOM
6702 0 2017 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA AVCOM
6703 0 2017 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA AVCOM
6704 0 2017 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA AVCOM
6705 3 2020 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA AVCOM
6706 1 2021 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA AVCOM
6707 19 2040 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6708 84 2124 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6709 156 2280 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6710 121 2401 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6711 50 2451 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6712 72 2523 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6801 0 2523 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6802 90 2613 WC3GAA 116 ASLT HEL CO VIETNAM RVN
6803 29 2642 WCKGAA 20 TRANS CO VIETNAM RVN
6804 0 2642 WCKGAA 20 TRANS CO VIETNAM RVN
6805 0 2642 W0MUAA ARADMAC IN MAINT NAVAL AIR STN AVCOM
6806 0 2642 W0MUAA ARADMAC IN STORAGE NAVAL AIR STN AVCOM
6807 0 2642 W0MUAA ARADMAC IN STORAGE NAVAL AIR STN AVCOM
6808 0 2642 W0MUAA ARADMAC IN STORAGE NAVAL AIR STN AVCOM
6809 0 2642 W0MUAA ARADMAC IN MAINT NAVAL AIR STN AVCOM
6810 2 2644 W0MUAA ARADMAC 4TH ARMY NAVAL AIR STA AVCOM
6811 18 2662 W0MUAA ARADMAC IN MAINT NAVAL AIR STN AVCOM
6812 10 2672 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6901 19 2691 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6902 24 2715 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6903 27 2742 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6904 34 2776 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6905 38 2814 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6906 39 2853 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6907 34 2887 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6908 16 2903 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6909 21 2924 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6910 20 2944 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6911 19 2963 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
6912 15 2978 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7001 20 2998 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7002 15 3013 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7003 18 3031 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7004 7 3038 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7005 21 3059 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7006 15 3074 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7007 0 3074 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7008 0 3074 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7009 0 3074 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7010 24 3098 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7011 8 3106 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7012 15 3121 WAY2AA 1 AVN DET EUCOM GERMANY EUROPE
7101 14 3135 WAY2AA 1ST AVN DET GERMANY EUROPE
7102 7 3142 WAY2AA 1ST AVN DET GERMANY EUROPE
7103 20 3162 WAY2AA 1ST AVN DET GERMANY EUROPE
7104 17 3179 WAY2AA 1ST AVN DET GERMANY EUROPE
7105 5 3184 WGYYAA 350TH AVN CO GERMANY EUROPE
7106 15 3199 WGYYAA 350TH AVN CO GERMANY EUROPE
7107 19 3218 WGYYAA 350TH AVN CO GERMANY EUROPE
7108 6 3224 WGYYAA 350TH AVN CO GERMANY EUROPE
7109 0 3224 WGYYAA 350TH AVN CO GERMANY EUROPE
7110 0 3224 WGYYAA 350TH AVN CO GERMANY EUROPE
7111 2 3226 WGYYAA 350TH AVN CO GERMANY EUROPE
7112 2 3228 WGYYAA 350TH AVN CO GERMANY EUROPE
7201 0 3228 WGYYAA 350TH AVN CO GERMANY EUROPE
7202 1 3229 WGYYAA 350TH AVN CO GERMANY EUROPE
7203 0 3229 WGYYAA 350TH AVN CO GERMANY EUROPE
7204 0 3229 WGYYAA 350TH AVN CO GERMANY EUROPE
7205 0 3229 WGYYAA USA PAD GERMANY EUROPE
7206 1 3230 WGYYAA BEL HEL CO IN MAINT AMARILLO AVSCOM
7207 0 3230 W0Y6AA ARADMAC IN MAINT NAVAL AIR STN AVSCOM
7208 0 3230 W0MCAA RED RIVER AD 5TH ARMY RED RIVER AD AMC
7209 0 3230 W0MCAA RED RIVER AD 5TH ARMY RED RIVER AD AMC
7210 0 3230 W0MCAA RED RIVER AD 5TH ARMY RED RIVER AD AMC
7211 0 3230 W0MCAA RED RIVER AD 5TH ARMY RED RIVER AD AMC
7212 0 3230 W0MCAA RED RIVER AD 5TH ARMY RED RIVER AD AMC
7301 0 3230 W0MCAA RED RIVER AD 5TH ARMY RED RIVER AD AMC
7302 0 3230 W0MCAA RED RIVER AD 5TH ARMY RED RIVER AD AMC
7303 0 3230 W0MUAA ARADMAC IN MAINT NAVAL AIR STN AVSCOM
7304 0 3230 W0MUAA ARADMAC IN MAINT NAVAL AIR STN AVSCOM
7305 0 3230 W0MUAA ARADMAC IN MAINT NAVAL AIR STN AVSCOM
7306 2 3232 W0MUAA ARADMAC IN MAINT NAVAL AIR STN AVSCOM
7307 19 3251 WPPVD0 NAT GUARD NAT GDZI
7308 6 3257 WPPVD0 NAT GUARD NAT GDZI
7309 26 3283 WPPVD0 NAT GUARD NAT GDZI
7310 20 3303 WPPVD0 NAT GUARD NAT GDZI
7311 6 3309 WQMAAA NAT GUARD NAT GDZI
7312 11 3320 WQMAAA NAT GUARD NAT GDZI
7401 1 3321 WQMAAA NAT GUARD NAT GDZI
7402 9 3330 WQMAAA NAT GUARD NAT GDZI
7403 0 3330 WQMAT0 NAT GUARD NAT GDZI
7404 0 3330 WQMAAA NAT GUARD NAT GDZI
7405 0 3330 WQMAAA NAT GUARD NAT GDZI
7406 26 3356 WQMAAA NAT GUARD NAT GDZI
7409 0 3377 WQMAAA NAT GUARD NAT GDZI
7410 4 3381 WQMAAA NAT GUARD NAT GDZI
7411 0 3381 WQMAAA NAT GUARD NAT GDZI
7412 0 3381 WQMAAA NAT GUARD NAT GDZI
7501 0 3381 WQMAAA NAT GUARD NAT GDZI
7502 1 3382 WQMAAA NAT GUARD NAT GDZI
7503 8 3390 WQMAAA NAT GUARD NAT GDZI
7504 0 3390 WQMAAA NAT GUARD NAT GDZI
7505 1 3391 WQMAAA NAT GUARD NAT GDZI
7506 1 3392 WQMAAA NAT GUARD NAT GDZI
7507 0 3392 WQMAAA NAT GUARD NAT GDZI
7508 14 3406 WQMAAA NAT GUARD NAT GDZI
7509 4 3410 WQMAAA NAT GUARD NAT GDZI
7510 0 3410 WQMAAA NAT GUARD NAT GDZI
7511 4 3414 WQMAAA NAT GUARD NAT GDZI
7512 5 3419 W7NUAA NAT GUARD NAT GDZI
Posted by grandadjohn on Thursday, April 23, 2009 9:43 PM
Thanks Ray, found this one one of my slides, you can make out the counterwieghts at the top of the photo
Posted by Hatter50 on Friday, April 24, 2009 6:52 AM
Hey Guys.....
Jumping in a bit late here but i didn't see anybody add the BN for the Collins UH-1E.......which is 153762.
Here are two photos of her on Okinawa:
She ended up her military career as a trainer at HT-18.  At some point sent to the boneyard and then recovered.
Regards
Steve
    September 2015
Posted by Aaronw on Friday, April 24, 2009 10:22 AM
With all this talk of B's with the 540 rotor, any early Cs with the earlier B style rotor? or Es with the B type rotor with the C modifications?
I've found with Italeri their mistakes can frequently be traced to a source, or maybe they were just sloppy when they made their C kit.
Posted by grandadjohn on Friday, April 24, 2009 10:39 AM
I don't think you'll find any early C's with B model rotors since they were designed to use the 540 rotor. B models had them for testing before the C's became available
Posted by Melgyver on Friday, April 24, 2009 3:13 PM
I concur with Grandadjohn.  It also appears any early B airframes that were converted to the C mods were later redesignated C's.   My data shows the same B tail numbers that are C's on Ray's list.
Clear Left!
Mel
    January 2007
Posted by rotorwash on Friday, April 24, 2009 5:39 PM
Been away from the computer for a day and look what happens!
Grandad,
  Thanks fro the UH-1B photo.  You wouldn't happen to have any of the OH-58 ther would you?  I'm building one of those now as well.
Steve,
  Thanks for the Echo pics.  Good to see some new shots.
Aaron,
   I agree with Grandad and Mel.  However, there is one instance I know of which you might call a C with a B rotor.  It really depends on how you define a Charlie model.  The Australian Navy had at least two birds with B model features but left handed fuel fillers.  Check it out: http://www.airliners.net/photo/Australia%20-%20Navy/Bell%20UH-1B%20Iroquois%20(204)/0610228/L/&width=1000&height=679&sok=&sort=&photo_nr=1&prev_id=0707231&next_id=0606518
Personally, I consider this a B model with a left handed fuel filler, but it is different.
    Ray
Posted by grandadjohn on Friday, April 24, 2009 6:32 PM
OH-58A
Only one I can find right now, may have some more, will check tomorrow, going to the ball game tonight
    September 2015
Posted by Aaronw on Friday, April 24, 2009 9:01 PM
Ok, sounds like Italeri just blew it on the C then, thanks.
