1/48 Monogram B-17G Flying Fortress
    January 2012
Posted by Ninetalis on Friday, January 27, 2012 5:04 AM
I haven't been following this build, but damn... I've missed A LOT of nice stuff
I'm gonna start following this build!
Really, Great work!
Regards Ninetalis.
    June 2005
Posted by Lancair IV on Friday, January 27, 2012 7:28 AM
Thanks everyone.  She's far from perfect nor do I plan on making her perfect.
Last night I sealed the decals with a coat of future floor wax.  Dull coat tomorrow after everything has completely dried.  Then the fun begins with turning her from a hanger queen into a war machine!
Cheers
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Saturday, January 28, 2012 3:20 PM
Dull Coat applied
Started weathering the flaps.  Bottom flap in untouched, Top flap started.
Cheers
Rob Byrnes
Novi, Mi
    December 2011
Posted by Luft Modeler on Saturday, January 28, 2012 3:35 PM
Lancair IV
Cheers
You say its not perfect but it looks damn good!
    October 2008
Posted by bsyamato on Saturday, January 28, 2012 3:38 PM
Great updates lancair Yes wishing to see the finished cutaway Stick out tongue
    June 2005
Posted by Lancair IV on Saturday, January 28, 2012 5:10 PM
MOUNT N RIDE
Rob Byrnes
Novi, Mi
    January 2009
Posted by fermis on Saturday, January 28, 2012 5:45 PM
Copycat!!!
Looks great buddy, can't wait to see it "on the table"!!!Toast
    June 2005
Posted by Lancair IV on Sunday, January 29, 2012 7:45 PM
When did you build that Fermis.  Last night?  lol.  Are you bringing that to SEMEX in March?
I spent the day weathering today.
Thanks for looking
Rob Byrnes
Novi, Mi
    January 2012
Posted by silver69 on Sunday, January 29, 2012 8:15 PM
Can't wait to see it with the masking removed.
This build is spectacular!
    February 2011
Posted by RotorHead10 on Sunday, January 29, 2012 9:35 PM
Rob, I have been following this buid for a while now. Well Done! Even though your methods borderline on insanity you serve the modeling community well and are an inspiration to model builders everywhere. I personnaly have picked up a thing or two from this build. Sometimes I wonder if in fact you are actually a oroverbial "Indian in the Cupbaord" 1/48 scale airframe mechanic. Again, great work as I am looking forward to your furure builds... Chris
http://i301.photobucket.com/albums/nn48/MikeTheModeller/GB_Badges/Phantom2011_1.jpg
    January 2009
Posted by fermis on Monday, January 30, 2012 6:58 AM
Lancair IV
HAHA...no, that was last spring-ish. Not sure about SEMMEX this year, I'm going to a show in Indy(???) with a buddy from Swanny's March 10.
Just checked their site....March 24th....I may just make it out there, if for nothing more than to hit the vendor room and check out your plane! My 17 was a commission job, so it's long gone now!
    June 2005
Posted by Lancair IV on Monday, January 30, 2012 8:51 PM
Installed the engines and motors today hoping to make a final test before the cowls are glud on.  Well, I really screwed up this time.  Engine #1 will not turn over.  #2, #3, & #4 are fine as well as all the lights and sound.  As it turns out, I used a little too much CA and the shaft is frozen.  Go figure.  Hopefully I can get a hold of Clyde and see if he sell me a new one.  Last I heard, he was not in business any more......  Stay Tuned.......
Rob Byrnes
Novi, Mi
    December 2010
Posted by Heavens Eagle on Monday, January 30, 2012 11:40 PM
I might be able to add some helpful to this.  Years ago in college, folks had a bad habit of doing a nasty practical joke.  Putting super glue into the tumblers of our dorm locks.  The easiest and fastest way to "unglue" the lock was to spray WD-40 into the lock.  In this case maybe just take a drop and work it into the glued area to soak.  With a little patience it might break it loose then just work with it a little.
Another thing about super glue is that heat and cold can tend to make it degrade.  The cold not so much.  Heat depends.  Enough to where it is a little warmer than you want to hold can do the job.  Also CA is a bit on the brittle side.
    June 2011
Posted by MrRabbit on Tuesday, January 31, 2012 12:32 AM
If heavens eagles idea doesnt work and you cant find a replacement,  maybe heavily weather the engine, scrape away some plastic to simulate flak damage and feather the prop?
    December 2011
Posted by Luft Modeler on Tuesday, January 31, 2012 1:26 AM
A combo of some ca remover and then soaking the whole electric motor in container full of wd40 can do the trick. Let it soak for a couple hours or more, pat it dry and then use electrical spray cleaner to remove the wd40 from it. Is it a brushless motor or standard?
    December 2010
Posted by Heavens Eagle on Tuesday, January 31, 2012 2:46 AM
As a watchmaker and someone that worked for over 20 years in electronics, LESS is better.  Soaking the whole motor can damage windings and that is not a good thing.  Also if you are good with small stuff it might be possible to disassemble the motor partly.  I have done so before, but then again I am used to working on parts a quarter the size of a pin head. HmmWow
Another thing is that CA removers tend to have acetone or some solvent such as that.  Motor windings are usually made with fine copper wire that has lacquer for the insulator.  Acetone and lacquer don't mix.  If I remember from the movie where all the electronics were tested, the motors are maybe only about 1/4 inch in diameter.  VERY SMALL!   Again, the best way is just a little of your solvent choice right where the CA ended up.
Just thought, Freeze spray might be possible.  Have also heard that putting CA in the freezer can tend to make it break down.  A small pin vice on the shaft to hold it and gently work it afterwards might be a help too.  The freezing shouldn't hurt the motor.  Just be sure to dry it off.  Hairdryer.
    December 2011
Posted by Luft Modeler on Tuesday, January 31, 2012 3:21 AM
I didnt say soak the motor in ca remover, soak it in wd40. Wd40 has been used for a long long long time for electronic motors and other devices. Followed by then cleaning out with electronic parts spray cleaner. I have rebuilt and built brand new electric motors, brushed and brushless motors. CA remover would be applied on a qtip and lightly scrub the superglue off of the shaft where it has been glued to the bearing which should loosen up the bond. Soaking in WD40 to then clean out the motor followed by rinsing out excess lubricant with electronic parts cleaner.
    January 2011
Posted by LWW1 on Tuesday, January 31, 2012 5:22 AM
A different thought is that these little motors are from the "old" pagers.  Should be able to find on for cheap and take apart for the motor that makes the pager vibrate.  I would be sure Clyde will help out as would figure he would have some extras.
Appreciate the look and more to follow,
On the bench: P-61
On Deck: Super Wing Series P-51
In the hole: BF/ME 109 - Converting to carrier based w/Folding wings
    June 2005
Posted by Lancair IV on Wednesday, February 1, 2012 8:06 PM
Thanks for all the feed back and ideas.  I have not heard back from Clyde yet, and I'm trying to find an old pager.  Either way, I will have 4 running engines.
This picture is the underside of new motor without the cowling that has just been replaced by the ground crew after a catastrophic engine failure.  Still a long way to go.....
Cheers
Rob Byrnes
Novi, Mi
    January 2011
Posted by LWW1 on Thursday, February 2, 2012 8:35 AM
Found this site that may work.
https://catalog.precisionmicrodrives.com
Have all types of small motors.  Hopefully there is some information on the ones you have to match with.  Best of luck!
Lance
On the bench: P-61
    June 2005
Posted by Lancair IV on Saturday, February 4, 2012 9:10 AM
Update - - - - - - - - - Clyde came thru.  He is sending me his last 5.0mm motor.  Unfortunately, he is no longer producing kits.  I should have it by the end of this week.......  Time to start the base while I wait.
Cheers
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Monday, February 6, 2012 8:14 PM
She's on the gear.  I use a piece of plexiglass to make sure the flats of the tires are all aligned.
The brass inserts on the bottom of the tires are the electrical connections for the lights and engines.  The brake lines are the wires leading into the engine nacelles.  I'll detail those tomorrow.
Cheers
Rob Byrnes
Novi, Mi
    December 2011
Posted by Luft Modeler on Monday, February 6, 2012 8:32 PM
This build looks amazing, the detail is superb!!!
    June 2005
Posted by Lancair IV on Tuesday, February 7, 2012 8:56 PM
Main Gear details
Cheers
Rob Byrnes
Novi, Mi
    September 2011
Posted by Eighth Air Force Pilot on Wednesday, February 8, 2012 1:38 PM
Did you use the SAC metal landing gear?
"Speak softly and carry a big stick; you will go far," Theodore Roosevelt
 Currently on the bench:
  1. 1/48 Revell Germany Spitfire Mk.IX
  2. 1/48 Academy Spitfire Mk. XIVc
  3. 1/48 Tamiya Beaufigher TF Mk.X
  4. 1/48 Tamiya F-15C
  5. 1/48 Revell F-15E Strike Eagle
  6. 1-48 Revell B-17G
    June 2005
Posted by Lancair IV on Wednesday, February 8, 2012 7:24 PM
Yes.  I used Scale Aircraft Conversions on the mains and the tail is scratch built.
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Wednesday, February 15, 2012 9:02 PM
Finishing details going on now.  Nav Light check on the bottom after removing the elmers glue mask.  That worked great.
Lower Green Starboard Nav Light Off
Lower Green Starboard Light On
Lower Red Port Light Off
Lower Red Port Light On
IFF Off
IFF On
I'll make a video of the IFF Morse Code and post tomorrow.
Thanks for looking
Rob Byrnes
Novi, Mi
    January 2011
Posted by LWW1 on Wednesday, February 15, 2012 9:12 PM
This is really cool.  Love the lights.
On the bench: P-61
    October 2008
Posted by bsyamato on Thursday, February 16, 2012 12:59 PM
lights on Stick out tongue
    November 2011
Posted by Adaster on Thursday, February 16, 2012 1:08 PM
Man that is one nice fort!
Will
