1/24 FW-190 WIP- THE MUMMY
    October 2009
Posted by krow113 on Friday, September 3, 2010 10:06 AM
Jmodeler & Wnut -Thanks for the interest. I added channels to the lgear covers and lined up the mounting holes . I also added quite a number of parts to the gear bay as well. The legs were slugged with .125" welding rod ,removing the springs . You can see the re-inforcement around the gear bay as well. The Verlinden resin kit is great it adds a lot of crisp detail to the cockpit and other areas, and fits really well.
Thank you ,Krow113
    May 2005
Posted by hughes2682 on Friday, September 3, 2010 11:26 AM
You drilled holes in the landing covers to match the bolts?  Oh man!  I love that attention to detail.  The CP looks like it has been lived in but, not trashed.  This is some top notch work sir.
Cheers
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
    October 2009
Posted by krow113 on Friday, September 3, 2010 12:17 PM
Thanks Dave. I'm looking at some airbrush work on this today.
Thank you ,Krow113
    October 2009
Posted by krow113 on Friday, September 3, 2010 2:56 PM
The killer D-9 takes on some color ,prop in RLM 70 and spinner gloss black ,camo grey/white mix for the color.
And the camo on the rudder ,with control surfaces painted.
Thank you ,Krow113
    October 2009
Posted by krow113 on Tuesday, September 7, 2010 12:01 PM
Ongoing cpit details .Eduard seat belts ,paint flaking off , and placards from them as well.
Thank you ,Krow113
    October 2009
Posted by krow113 on Wednesday, September 8, 2010 6:12 PM
The alien space chopper aligns it's 500mm stellar cannon on planet earth, to finally eliminate the universal scourge , humanity .
No ,really its the cockpit tub/engine power pod connection ,wanted to make this as soon as poss to get a good bond.
..........................unt zee happy heaadrest visits zee enchanted control zurfass forezt
Thank you ,Krow113
    October 2009
Posted by krow113 on Thursday, September 9, 2010 2:08 PM
Wing work goin ' on , Trumpeter parts are pretty good .I see a lot of comment on the fiddly p/e parts for these kits ,no sign of trouble here yet.I am hoping to get the wings assembled today for drying. Loo roll to support and protect the gear.
Now to the Bobber wip for a minor setback..................
Thank you ,Krow113
    October 2009
Posted by krow113 on Thursday, September 9, 2010 11:26 PM
Engine wiring while the wings dry..................
Thank you ,Krow113
    October 2009
Posted by krow113 on Friday, September 10, 2010 11:11 AM
The Deadly Dora wings on , well ,wing assy anyway..............................
Thank you ,Krow113
    October 2009
Posted by krow113 on Saturday, September 11, 2010 7:07 PM
Engine wiring/plumbing ongoing, I wont pic every wire but every hour I will take pix.
Thank you ,Krow113
    October 2009
Posted by krow113 on Saturday, September 11, 2010 10:46 PM
..........................................................................ongoing.......................................................
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, September 12, 2010 3:05 AM
...........................................................................ongoing.........................................................
Thank you ,Krow113
Posted by hutchdh on Sunday, September 12, 2010 8:47 AM
Wow...definitely a difference between someone like you (an artist) and someone like me (a recreational amateur modeler).  Outstanding work
Hutch
 On the Bench: 1:48 HobbyBoss Ta152-C; 1:48 & 1:72 Hasegawa F-104G NATO Bavaria
In queue: 1:48 Academy F-4B & a TBD Eric Hartmann bird
Recently completed: 1:32 Trumpeter P-51B
    October 2009
Posted by krow113 on Sunday, September 12, 2010 11:26 AM
hdh- thank you and stay tuned....................
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, September 12, 2010 5:01 PM
Went to test fit today and found a few issues,a lot of thinning in the engine area around the top of the engine mounts.Exhaust proving to be the bugbear,ended up cutting them off and then things went a lot better.You can see alot in the top and through the bottom, D-9's were'nt paneled in the top of the gear bay. Wound up with all parts there and fitting well, gonna try tyo finish the wiring/plumbing today.
Thank you ,Krow113
    April 2008
Posted by Von Alfalfa on Sunday, September 12, 2010 5:09 PM
Wow! looking awesome!
I love how it looks the engine, beautiful!
    October 2009
Posted by krow113 on Sunday, September 12, 2010 6:57 PM
Von Alf-Thank you heres some more ,its way out of hand but gettin' done.
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, September 12, 2010 9:13 PM
More test fitting ,looks good ,no issues. Gun cover detail to be completed.
Thank you ,Krow113
    October 2009
Posted by krow113 on Monday, September 13, 2010 12:54 AM
A few loose wires and some ignition tubes to go.................
Thank you ,Krow113
    October 2009
Posted by krow113 on Monday, September 13, 2010 11:52 PM
Here is the rear fuselage with tail wheel and rudder ,also the antennawire ,I'll try this and see if it works.I carved a groove in the two fuse halves for the wire.The tail wheel is pinned.
The front of the fuse clearanced and painted.
Thank you ,Krow113
    October 2009
Posted by jetmodeler on Tuesday, September 14, 2010 6:11 AM
Looks better and better everytime I see it. I really like how the engine is turning out.Toast
    October 2009
Posted by krow113 on Tuesday, September 14, 2010 11:06 AM
Jmod-Thanks todays pix will be of the finished engine/cpit pod.
Thank you ,Krow113
    October 2009
Posted by krow113 on Tuesday, September 14, 2010 3:33 PM
Ignition wire tube ,lay out on hex ,drilled wire holes and mounts,then sand to correct round shape....
On the engine.........
Lap belts in place........
Thank you ,Krow113
    October 2009
Posted by krow113 on Tuesday, September 14, 2010 10:25 PM
Ignition wires finished as well as the plumbing.
Thank you ,Krow113
    October 2009
Posted by krow113 on Wednesday, September 15, 2010 1:52 AM
Engine touched up and painted, this will do with a very few details to go.............
Thank you ,Krow113
    October 2009
Posted by krow113 on Thursday, September 16, 2010 9:49 PM
Some work on the guns,a wipe with graphite dust should do these.
Thank you ,Krow113
    October 2009
Posted by krow113 on Friday, September 17, 2010 5:48 PM
Model meeting tonight , then all this will be in the fuselage forever!
Thank you ,Krow113
    April 2005
Posted by wing_nut on Friday, September 17, 2010 6:20 PM
That really looks nice Krow.
Marc
    October 2009
Posted by krow113 on Saturday, September 18, 2010 10:50 PM
Wnut- Thank you . Todays work on the ip mounting and gun cowl fitting. Gun cowl is very thin and the top of the guns is flattened out to get this fit.....
Thank you ,Krow113
    October 2009
Posted by jetmodeler on Sunday, September 19, 2010 8:11 AM
Looks great so far.
I have a question. Are you going to leave the engine closed?
