Back on the big FW for a while .Today I squared away the cpit and fuselage additions/corrections. I added the throttle lever and oxygen hose, touched up the paint ready to install.
On the fuse I scribed all the engine panel lines inside and out .They are as thin as paper now. The plan is to cut off the front panels at a later date to display the engine. I have a few parts left to install, gunsite pieces, canopy crank , exhaust pipes ,shoulder belts and back armor. I dipped the canopy parts in Future as well.
Here is the fuse inside:
Outside:
The lower line is a hinge , the kit has no line at all. this was added.
On the supercharger intake scoop the kit is very deceptive. There is a recessed area to drop the scoop into. This is incorrect,the scoop is rivited on top of the fuse skin. I got caught here and had to sand down the surrounding area to get the skin level to the scoop level. A proper fix would be to fill in the area and glue the kit scoop on top. It looks ok. I still have to add rivit detail at this point as well. I spent all day on this mostly, on the line scribing and seam cleanup. Good references wil help to get through the corrections ,there are lots to work on.
Seams look good...
