1/24 FW-190 WIP- THE MUMMY
    September 2007
Posted by SuppressionFire on Saturday, February 19, 2011 7:34 AM
krow113,
Excellent WIP's! The 'loose cannons' is a good idea that I will use in the future.
The small arrows & marks are reminders to correct seam flaws or to add parts? Either way I am getting to the point where 'reminders' marked on the plastic is necessary during construction.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    February 2011
Posted by Reasoned on Saturday, February 19, 2011 8:31 AM
Very detailed Yes... now this does fly... right? Big Smile
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    October 2009
Posted by krow113 on Saturday, February 19, 2011 11:57 AM
Sfire -Thank you for your continued interest/comments. The marks are as you surmised,there are a lot of minor probs with this kit , best to mark them off so as not to forget to address them.I have a serious collection of over 400 pix and a good record of the corrections/additions for this kit.
Reasoned- Thanks for comin' on board,all comments welcome.
What were you guys doin' diggin ' around on the second page? This forum moves very fast ,like armor,tough to keep this on page one.....
Thank you ,Krow113
    October 2009
Posted by krow113 on Saturday, February 19, 2011 9:28 PM
One way to keep it on page one is to post progress photos,here are the exhaust inserted into the fuse end and aligned ,glued.
And some landing gear details,the spring actuator and attachment of the retractor leg. The kit instructions, and models I have seen, show these in upside down, something to watch for. I believe these are the right way with the microswitch in front.
Adding on here the' mount to nowhere' is now mounted to the front of the gear bay . And the structure added to stiffen the wingspar/gearbay.
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, February 20, 2011 3:06 PM
Worked all morning to correct the Eduard seat belt kit. The shoulder belts looked a little long , so I whipped out my handy 1/24 scale ruler , the shoulder belts scaled at 6' long! After a lotta cursing and paint flaking off ,the belts are useable. Not good Eduardo.....
Heres a long one with the shortened ,and then the two useable's
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, February 20, 2011 9:45 PM
Last for today is the top panel glued in place ,fit is great , I'll let this dry and cut in the new panel line.
4422
Thank you ,Krow113
    October 2009
Posted by krow113 on Tuesday, February 22, 2011 1:34 AM
Top panel glued in nicely ,tonight the lower .
4436
Thank you ,Krow113
    October 2009
Posted by krow113 on Wednesday, February 23, 2011 11:52 AM
Panel line filled with .020 styrene...
Sanding stick in play , black marker to watch the fuse...
Sanding sticks to finish , I was lucky ,rivit detail preserved.
Continuing...
And with dymo tape in place,I did scribe the lines ,however the bottom panel split so I re-glued that.There is also a lot of reshaping needed in the front of the fuse, it already looks a lot better with the straight hinge lines.
4436
Thank you ,Krow113
    October 2009
Posted by krow113 on Friday, February 25, 2011 1:29 AM
For today the guns adjusted to the correct position , and the cover in place, up next the wing fuse mating.
4530
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, February 27, 2011 9:55 PM
Fuselage and wing mated ,I'll let this dry awhile...
4600
Thank you ,Krow113
    February 2011
Posted by Reasoned on Sunday, February 27, 2011 10:27 PM
Looking fantastic Krow, what a ton of work.
    October 2009
Posted by jetmodeler on Monday, February 28, 2011 6:25 AM
I haven't posted in this thread in a while. I see I've missed a good bit.
Good to see it's got its wings.
    October 2009
Posted by krow113 on Wednesday, March 2, 2011 12:08 AM
Reasoned , Jmodeler- Thanks and keep watchin'!
Not really anything new, but the exceptional fit of the kit is evident here as I work on the joining...
...over zealous sanding resulted in a gap on the bottom ,I filled it with cyano and will address it later...
4679
Thank you ,Krow113
    October 2009
Posted by krow113 on Thursday, March 3, 2011 1:48 PM
Today ,tryna get the rear wings on and redoing the armor plate behind the seat. The Verlinden supplied p/e is not far enough back to fill the space to the hatch cover. .o1o" brass ,detailed with an MDC rivit tool.
Verlinden on the left...
And the model at this point...
4742
Thank you ,Krow113
    October 2009
Posted by krow113 on Wednesday, March 16, 2011 3:39 AM
Blew a little primer on the wing/fuse connection ,the fit possible is excellent.
5053
Thank you ,Krow113
    January 2009
Posted by fermis on Wednesday, March 16, 2011 9:04 AM
Can't wait to see this bird in color!
Very nice work Krow!Yes
    March 2010
Posted by Hercmech on Wednesday, March 16, 2011 10:14 AM
Looking good. Can't wait to see her all dressed up.
13151015
    October 2009
Posted by krow113 on Friday, April 1, 2011 12:49 PM
Fermy , Hmech - Thanks for the comments , I have completed the Mutation Situation in the auto forum and have been eyeballing this wip ,with an eye towards a High Speed Run to the finish.
And an overall shot at this point...
5688
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, April 10, 2011 10:16 PM
Cowl on and cannons from .083 s/s tubing ,ends filled with solder , to be drilled.
5974
Thank you ,Krow113
Posted by VanceCrozier on Monday, April 11, 2011 9:15 PM
That's some great work Krow - how did I miss this one?? Yes
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    January 2007
Posted by Pavlvs on Tuesday, April 12, 2011 11:30 PM
Really beautiful work so far.  What a shame to cover up all of that magnificent engine detail.  I'm glad you intend to cut out the engine covers to show that beautiful engine.YesToast
Deus in minutiae est. Fr. Pavlvs
On the Bench: 1:200 Titanic; 1:16 CSA Parrott rifle and Limber
On Deck: 1/200 Arizona.
Recently Completed: 1/72 Gato (as USS Silversides)
    October 2009
Posted by krow113 on Saturday, April 16, 2011 10:51 PM
V.C. - Pav - Thanks for the comments and keep watchin' as I (krow113)  drive forward with this wip.
The original idea for the model was a diorama for Black 12 ,a plane surrendered as shown in this pic:
Bein' a tad naive regarding figs at the time , I thought I would have no problem finding some  to replicate the pic, I found this one :
But was unable to find any suitable fig for the GI ,I thought I was hooped , I tried the 1/24 Tamiya pit crews ,no joy except for a hat to use on the German pilot ,that can be seen in the pix as a blue item.
I saw a fig kit I never knew existed ,I only saw it once and bid on it on ebay and got it!
Now I can replicate the moment of surrender ,as I had originally planned ,here is the sit rep today:
As you will see the main parts of the figs are assembled and they are in primer, this is a really good thing for me.
6392
Thank you ,Krow113
    February 2011
Posted by Reasoned on Sunday, April 17, 2011 7:59 AM
Love the build Krow and  the theme of the diorama makes it even more interesting.
    October 2009
Posted by krow113 on Monday, April 18, 2011 5:21 PM
Rned -Thanks for the comp. I am working through the tedious details with regard to ommissions and or additions and or corrections!
Looking at the wings and reading reviews I see that the manufacturer used an incorrect drawing of the aircraft plan view, the original artist drew the panel lines in curves, Trump made their panel lines curved as well, prolly one a simple phone call, during kit design, would have helped!
Here is the top with the three curved lines :
And the bottom with two curved lines and a curved panel which I will leave:
This will be as well as : Adding the flap actuator to the flap , gun panel cover completion , proper landing gear indicators , replacing the small panel at the back of the wing root to straddle the panel line , all needed to bring the wing into line with the numerous reference drawings I am using.
Thank you ,Krow113
    October 2009
Posted by krow113 on Sunday, April 24, 2011 10:10 PM
So everything is filled in and new panel additions made from .015" plastic sheet .
6810
Thank you ,Krow113
    October 2009
Posted by krow113 on Wednesday, April 27, 2011 12:42 AM
The entire model has been re-scribed ,a 6 hour job. I also detailed the gun panels a little more ,and some fig work.
6897
Thank you ,Krow113
    October 2009
Posted by jetmodeler on Wednesday, April 27, 2011 6:03 AM
Looks great so far.
I had no idea either that there was a 1/24 GI. Learn something new everyday.Big Smile
    October 2009
Posted by krow113 on Wednesday, April 27, 2011 2:18 PM
Jmodeler -Thanks - I reckon yer lookin' at the only one! The only GI I could find in 1/24.
Thank you ,Krow113
    October 2009
Posted by krow113 on Tuesday, May 24, 2011 12:19 AM
Grinding away at the fuse/wing details ,I added screws ,bolts ,washers , .010" brass rod 'hinges' ,Archer weld beads , and re-scribed a lotta lines and re-rivited a lotta rivits. This has taken a lot of time but has added a lot of details. I am lookin' at paint fairly soon , black/brown pre-shading to start.
7692
Thank you ,Krow113
    October 2009
Posted by jetmodeler on Tuesday, May 24, 2011 6:06 AM
Nice to see somemore progress on this one.
Looks good. Can't wait to see some paint.Big Smile
