Official Ho229 Group Build
    June 2009
Posted by kermit on Friday, December 31, 2010 12:30 PM
Zip it!Could this be H2(29)N...??Zip it!
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
Posted by VanceCrozier on Friday, December 31, 2010 12:41 PM
kermit
Yes, very likely. It only seems to affect those who have been exposed to styrene...
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    April 2005
Posted by Thunderbolt379 on Friday, December 31, 2010 5:01 PM
Manny, the long antenna in that location is probably intended to be a Morane aerial, which IIRC was an IFF system, standard fit on 109s and 190s, so a fair bet for service inclusion...
Completing my Avia S-199 for IDF II hopefully today (and launching three builds as host!), touching the 229 is getting closer...
Cheers, Mike/TB379
http://worldinminiature.blogspot.com/
Posted by Anonymous on Friday, December 31, 2010 5:21 PM
Thunderbolt379
Cheers, Mike/TB379
Correct, the IFF was a lte-war addition seen primarily on 109 G-10's, G-14's and K-4's...as seen here both the direction finder loop and the IFF was fairly standard fare on late war a/c----in this case a G-10...My guess is that placement of the DF loop on top would make more sense...
Posted by traveller on Saturday, January 1, 2011 8:45 AM
Hi, just a quick question, when is it running to? I am waiting for some Japanese decals to arrive, but it seems someone has stolen my thunder...... Oh well, I may consider the Italian airforce, or Soviet airforce, who knows?Sleep Time for bed, its about 23DegC here now!! not minus stupid degrees!!!!
Posted by Anonymous on Saturday, January 1, 2011 10:17 AM
traveller
Interesting...you could also opt for a finnish, Italian, Romanian or Hungarian scheme---although technically all of these countries were on the Alled side late in the war...however, since the wing is speculation one could hypotesize that at some point maybe the countries reverted back to the Axis...
    December 2006
Posted by Jester75 on Sunday, January 2, 2011 10:27 PM
Ok, looks like mine is going to be painted yellow and called the flying banana. there is some major warpage on the wings, has anyone else experienced this with the Dragon kit?? Still racking my head trying to figure out how to solve this.
Eric
Posted by traveller on Monday, January 3, 2011 12:25 AM
Jester75
Funny you should mention this, I have had a big fight with my wings. I ended up dunking them in hot water and bend them into shape, I hope!!!!! I should have called in Bender to helpStick out tongue
    December 2006
Posted by Jester75 on Monday, January 3, 2011 3:04 PM
Here is a crappy pic of the offending wing...
I have had two books sitting on it all night and they havent taken any of the bow out. Going to hit it with some hot water and see what it does.
Eric
Posted by VanceCrozier on Monday, January 3, 2011 3:13 PM
Jester75
yikes - that is a wicked wing warp... Yeah, I'm thinking the hot water is probably the best option. Maybe follow that up with some of Manny's non-slip yellow on the lower half... Wink
Posted by Anonymous on Monday, January 3, 2011 3:51 PM
I'm not seeing it...
    September 2015
Posted by Aaronw on Monday, January 3, 2011 9:02 PM
Ok, now that I've found this again (I've been searching the GB forum), I'm just about ready to get started on mine. I picked up the 1/72 Revell kit which looks quite nice.
    December 2006
Posted by Jester75 on Monday, January 3, 2011 10:04 PM
Well, I sucessfully straightened out the banana, I mean wing. I laid the two halves flat side down on a large piece of glass and using a hair dryer on low, heated up the styrene. I then kept them in the position with the weight of the book on them for several hours to allow the plastic to cool. Looks good so far. Going to let them sit over nigiht and check and see if the curve comes back in the morning.
Eric
    January 2003
Posted by p38jl on Tuesday, January 4, 2011 7:51 AM
Herr Field Marshall...
Reporting in...
Progress has been made.. Cockpit done, details added. Fuselage completed,, wings on... Pics tonight..
[Photobucket]
    January 2003
Posted by p38jl on Tuesday, January 4, 2011 8:57 PM
ok,, i got some progress,, here are some WIP pics..
my belts n buckles are bit heavy handed.. but the canopy will be closed so.... hopefully,, it wont noticed to bad..
I took some liberties with the wiring...[View:/themes/fsm/utility/Photobucket:550:0]
[Photobucket]
    January 2003
Posted by p38jl on Tuesday, January 4, 2011 9:01 PM
oops.. prematurely posted...[View:/themes/fsm/utility/Photobucket:550:0]
[View:/themes/fsm/utility/Photobucket:550:0][View:/themes/fsm/utility/Photobucket:550:0]
[Photobucket]
    December 2006
Posted by Jester75 on Tuesday, January 4, 2011 9:11 PM
Lookin good!!
Eric
    January 2003
Posted by p38jl on Tuesday, January 4, 2011 9:16 PM
I do have the fuselage together and the wings on now.. just no pics to prove to the Field Marshall...Dunce
[Photobucket]
Posted by Anonymous on Tuesday, January 4, 2011 9:28 PM
'bout time...Vance could learn a little about progress from some of you more motivated MOJO's...
I'm digging the air-to-air rockets on the NF version...
Posted by Anonymous on Tuesday, January 4, 2011 9:33 PM
Someone asked me about the "saw" pattern in a PM---here's what it looks like on a 109...colors are RLM 74, 75 and 76:
"Saw" pattern and "scalloped" leading edge:
    October 2008
Posted by oddmanrush on Wednesday, January 5, 2011 9:14 AM
Nice lookin' 109's Manny. That saw pattern is pretty neat, never seen or heard of it before. How about that scalloped edge, what did you mask it with? Silly putty?
Jon
My Blog: The Combat Workshop
Posted by Anonymous on Wednesday, January 5, 2011 11:39 AM
oddmanrush
Two things:
1) Your new avatar gives me an uneasy feeling...
2) To answer your question: Tamiya masking tape pre-cut with the "scallop" pattern...putty will not give you that hard of an edge...those saw patterns are real; I have refs that show many examples of 109's using them on the horizontal surfaces...same with the scalloped leading edge, although sometimes this was done in soft-edge:
    October 2008
Posted by oddmanrush on Wednesday, January 5, 2011 11:57 AM
Manstein's revenge
Two things:
Why is that? Perhaps you met a cat similar to the one in my avatar back in the fateful winter of '42-'43? Conjuring up memories of a lunch that didn't agree with you...
Its very nice work none the less. You seem to have references for everything. I'd love to see your library. Mine isn't very expansive yet, much like my stash but I'm working on it.
Jon
    June 2009
Posted by kermit on Wednesday, January 5, 2011 12:13 PM
Manny,
Fantastic 109 you are showing there? What kit was that? I want it!!Stick out tongue
Well folks,.... I am calling this flying banana done:
I did have some wing warpage but only the top half. I straightened it out by just gluing it to the bottom half and it corrected itself...thank our fuhrer...
As you can see from the pics i had some booboo issues... I had to fiddle and mess with the windscreen so much that it totally fogged up and well...it aint pretty.
On top of that i held the ring arial in my tweezers yesterday ending up shooting it to the cold plains of Siberia, nowhere to be found so i fashioned myself one from some sprue and wire. Lastly i just broke off half of the pitot tube while prepping for these pics... Will have to stretch some sprue to correct that. Nothing too problematic though and i must say that i am still very pleased with the results myself. Hope you guys like my 229 as well.
Manny thanks for hosting this one; i had the greatest fun doing both of the Ho's (...)Stick out tongue
Richard
    October 2008
Posted by oddmanrush on Wednesday, January 5, 2011 12:23 PM
Richard, very nice work there! Sorry to hear about your tiny misfortunes but you turned out a good looking Ho for sure!
Jon
    January 2003
Posted by p38jl on Wednesday, January 5, 2011 12:27 PM
Hey Frogman!! looks good!Yes
( try oozing some Future in/on your canopy wind screen,, it might lessen your fogginess)
[Photobucket]
    December 2006
Posted by Jester75 on Wednesday, January 5, 2011 12:39 PM
Nice work kermit! Looks like you got everything lined up nicely. I have decided button mine up completely and just have quick go at it.
Eric
Posted by Anonymous on Wednesday, January 5, 2011 12:46 PM
Nicely done, Oberst Kermit...other than the crazed windscreen and some silvering issues with the decals I think you really pulled off a winner!
I suppose you get the GB Badge times 2...Maybe now some of our "less-inspired" MOJO's will get to work...
    January 2003
Posted by p38jl on Wednesday, January 5, 2011 12:52 PM
<----- inspired Mojo..!
[Photobucket]
Posted by Gamera on Wednesday, January 5, 2011 7:07 PM
Wow, Kermit despite your issues she looks sharp! Love how the splinter camo and the engines came out. Cool
