Messerschmitt BF109 GB 2012
    June 2010
Posted by DoogsATX on Tuesday, February 7, 2012 6:40 PM
70 - the cowl fit's no picnic either. Easily the worst part of the kit IMO. Besides, that's one beauty of a mill...
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    March 2010
Posted by Nathan T on Tuesday, February 7, 2012 7:04 PM
Heck, you did such a great job on the engine, just leave the cowl off, make a base and do a maintenance dio or something, paint up the cowl and set it on the ground next to the airplane.
    July 2011
Posted by handiabled on Tuesday, February 7, 2012 7:13 PM
                    I gave up on my pos too,,,,,,cowls on forever and it mates up on top like @$%#,,  on the Trump kit the cowls make up most of the fuselage integrity in front,,, I gave up after hours of trying to get it to work open,,,,mabye on the next one,,,,,,,Sad
    November 2011
Posted by 70gtvert on Tuesday, February 7, 2012 7:20 PM
I thought of this and MAY try and pose it as one getting the weapons dialed in, lifted tail and flight crew, if I can find a set of blackbirds out there. Anyone have any clear photo's of the prop while this is being done? It has a pair of large discs mounted to the prop but the detail is to fuzzy to see what is notated on them.
    December 2010
Posted by Geof on Tuesday, February 7, 2012 11:46 PM
Ah cowl fit issues... Seems to be the norm! I'm gonna have some trouble too once I get there, I only want one panel open for mine, but given the design of the kit overall, this is going to be interesting. The kit was designed to have all panels open, to include lower cowl, or none. What I can't seem to figure out is the distinct difference in construction of the pit/engine assembly. On the closed version the pit firewall and engine are mounted as one. In the open version they are mounted separately with a different upper gun cover. We'll see how this goes soon! Just started the pit.
Photobucket
On the Bench: Tamiya's 1/48 A-10a Thunderbolt
In the Hangar:  Hmmm???
    November 2011
Posted by 70gtvert on Wednesday, February 8, 2012 12:08 PM
Funny how on one of the worst kits out there for a 109, the 1/24 Airfix 109 e3, e4, you can do a little grinding to get it all to fit open or closed. More than enough meat in the cowl pieces to grind down what has to be to get it to fit. Too bad so much detail is missing (wheel wells for example) or that it pretty much has a sink hole at every mounting pin point. Panel lines and rivets are a little heavy to but you can still build a pretty good kit. To think I pretty much pulled away from this kit for this Edwards. Airfix did send me replacement parts so that one is a go again when I'm ready for it.
You want to know what else I miss? Too bad, I'm telling anyways. Back around 1993 or 4 there was a rag out called Military Model Reviews. Guy did build ups of donated and purchased kits but without paint. Gave a breakdown on every step of the build. In the end he had about 6-8 categories he would rank it on using a 5 star rating as top. So many kits had shortcomings/design issues that more kits were coming in pretty poorly than not. Ultimate his sponsors quit donating kits and pulled their advertising and the thing went under. Still it was better than having nothing but glowing reports on-line for everything like you see now.
Bye the way, this is my summer kit work still in process. Now has everything from the firewall back in place. Just click or cut and paste it.
photostream
    June 2010
Posted by DoogsATX on Wednesday, February 8, 2012 12:47 PM
70gtvert
In fairness to the Eduard, I believe they're using a to-scale DB601. It's common in cowl on/off kits to offer a smaller-than-scale engine to make either position workable, since the plastic is out-of-scale thick. I know this is the case with ICM Spitfires, Zvezda's Bf 109F-2, etc. That's actually one of the really big deals about Tamiya's Spitfires and Mustang - the ultra-thin cowl pieces make a to-scale engine and cowl on/off workable.
One thing I wish Eduard had done differently...that Tamiya did spectacularly with the Spit and I think Cyber-Hobby does with their 109E-4, is to do the firewall-forward as literally its own kit that slots up with the rest of the airframe. I decided to do my Eduard E-7 closed up, and when that went awkward, I was stuck, since there was no way to re-open the fuselage to cram the engine in place.
    February 2011
Posted by randypandy831 on Wednesday, February 8, 2012 5:12 PM
snagged a revell G-10 today. will throw it in the GB also. not sure on markings.
this kit impresses me every time.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    July 2011
Posted by handiabled on Wednesday, February 8, 2012 6:40 PM
                          Herman and I made some progress,,,time for some Future  Smile
                                             Thanks for lookin!!
[View:/themes/fsm/utility/Photobucket:550:0]
    February 2011
Posted by randypandy831 on Wednesday, February 8, 2012 9:27 PM
got started on the revell kit.
hit the cockpit with XF-24 very close to RLM66
hit the wheel wells with XF-22 lightened with XF-2 to make RLM02
exhaust hit with MM metalizer burnt iron.
may go with White 11 markings or raf captured White 44.
    December 2010
Posted by Geof on Wednesday, February 8, 2012 11:16 PM
Hey handi... Looks good, but interesting paint scheme. What color is that tan? I'm not sure I've seen that variant before... Do tell!
Photobucket
    July 2011
Posted by handiabled on Thursday, February 9, 2012 7:18 AM
Geof
               Thanks Geof,,, what looks tan in the pic is actually RLM02,, my camera SUCKS!!!!!!
     Tha paint scheme is for the BF109F-4  Hauptmann Kurt Brandle III JG3  "UDET"    somewhere in early 42
the colors are a mix of rlm02, 70, 74, 04, and 76,,,,,  they just look like disney colors if I take the pics under the wrong light,,,,,or even the right light sometimes,,, mabye it's me not the camera,,  Bang Head
    April 2006
Posted by jgeratic on Thursday, February 9, 2012 3:22 PM
Only pic I could find of weapons maintenance involving some kind of equipment was this BoB era photo:
I have a couple other photos from the desert of an F series having it's tail jacked up and firing it's gun, but the only panels removed is a small one where the guns are located, so didn't bother scanning and posting.
Not much on google either but did find a rare colour one:
As for digital cameras, opinion is that it's their nature to distort colours.  Not only is it acceptable, but also expected that posted pics need to be photo-shopped in order to bring the image back to what you actually see in front of you.
regards,
Jack
    March 2010
Posted by Nathan T on Thursday, February 9, 2012 4:04 PM
I like that color pic of the engine change Jack, would make for a sweet dio...wonder where that was taking place? Balkan theater?
    November 2011
Posted by 70gtvert on Thursday, February 9, 2012 4:04 PM
Thanks. The one I have is in the Squadron 109 part 1 (through the E series). It has one with a pair of discs on the prop mount. I suspect they mounted it then test fired it and then review where the rounds fell in relation to the blades. It is just fuzzy enough to give you no idea as to what is printed on it. I suspect there are other shots to, such as you found (thanks by the way) and perhaps another with a clearer shot of what is printed on them. John.
    June 2010
Posted by DoogsATX on Thursday, February 9, 2012 4:06 PM
FYI - first review of Eduard's new 48th 109E-1:
http://www.hyperscale.com/2012/reviews/kits/eduard8261reviewbg_1.htm
    April 2006
Posted by jgeratic on Thursday, February 9, 2012 6:04 PM
Nathan - the colour photo setting, you are probably correct in guessing the Balkans.  One caption had it at Kresna Pass airfield in Bulgaria, 1941 while another one just stated in the desert somewhere.
Doogs - thx for the above review link.
regards,
Jack
    February 2011
Posted by randypandy831 on Thursday, February 9, 2012 6:38 PM
E-1.....i want
going to go with  Walter Oesau markings on the revell kit.
got some work done on both.
    July 2011
Posted by handiabled on Saturday, February 11, 2012 11:05 AM
                    Not trusting my judgement,, Herman consulted the other Germans living in the house,,,,,    Hmm
                    It appears they like the Future coat on it,,,,,   on to markings and weathering after it cures for another day or so,,,,,,,,,,,,,   Thanks for lookin,, Smile
    November 2011
Posted by 70gtvert on Saturday, February 11, 2012 1:42 PM
Lookin good Handi. I never saw a pattern like yours. Who's aircraft are you modeling?
Worked some more on my engine and cockpit. Decided that yes, I will leave it, the cowl, open (but boy do I sure wish it could have been engineered to close).
    December 2011
Posted by Luft Modeler on Saturday, February 11, 2012 2:04 PM
Nice work vert!! Like the hand crank!
Handi your 109 is looking great! Like the pattern on the wings!
    February 2011
Posted by Reasoned on Saturday, February 11, 2012 2:58 PM
70gtvert
http://carphotos.cardomain.com/ride_images/2/4983/3869/24956934021_large.jpg
Yes As stated before, it would be a crime to cover that up.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    July 2011
Posted by handiabled on Saturday, February 11, 2012 4:05 PM
70gtvert
Glad your leaving it open 70 ,,,, your doing a amazing job!! looks great!!   The paint scheme is for the BF109F-4 Hauptmann Kurt Brandle III JG3 "UDET" somewhere in early 42,,, at least thats what I'm trying for,,look forward to seeing yours come together,,,I think mine pales in comparison,,
PZL thanks for the kind words,,,,, look forward to your build comin together too!
This has been such a good BG I've decided to build anotherPropeller,,,,,,just haven't figured out what for sure,, mabye the Has 1/32 G,,,,,,,Hmm,,,oh well,,,,gotta finish this one first
    December 2011
Posted by Luft Modeler on Saturday, February 11, 2012 4:43 PM
I have decided to do a different 109 for this gruppe build..
Since I am a fan of the Emil model I will do the trop.. Its my favorite version so much so I did one many many many years ago. Though the model itself is MIA somewhere, it was my favorite. Going to get the Airfix 1/72 as to match my on going 1/72 models I am currently building.
Something about this just looks good:
    March 2010
Posted by Nathan T on Saturday, February 11, 2012 5:24 PM
Theres some sweet work goin on in here...bout time i post my progress on the G-10. Resin pit installed now along with wings and tail surfaces. Heres the shot just before the pit went in. Man these Hase kits just fall together...
    February 2011
Posted by randypandy831 on Saturday, February 11, 2012 6:16 PM
oh yes, they do.
    December 2010
Posted by Geof on Saturday, February 11, 2012 11:21 PM
The pit has begun... A few wires and some other minor mods. A decent start. Also, a pic of the finished DB601...
Photobucket Photobucket Photobucket
Photobucket
    June 2010
Posted by Hun Hunter on Sunday, February 12, 2012 1:11 AM
Hey 70, how is that kit,? I'm working on the FW 190 right now in that scale from Airfix and it had some major warping along the fuselage, and the cowling was a two day nightmare... and yet I'm still enjoying it. A LHS has the 109 for $32, so I think I'll pick it up in the next couple of weeks.
That engine looks fantastic, absolutely stunning, bravo.  That was the highlight of the 190, and my buddy just finished the Mustang in this line and the Merlin was a beauty. And yeah, I really, really wish more pieces were operable on my kit too. Still though, cheap.
There are some that call me... Nash
    July 2011
Posted by handiabled on Sunday, February 12, 2012 8:27 AM
Geof
                              Geof that looks mighty fine !!!  Comin together great! Here is a pic of the color scheme I'm basing on my 109,,I might have taken a few "artistic" twists to it but followed the same body lines where the colors are,,, I equivilate this Trump kit to my ex-wife,,, love at first sight and no one could tell me different,,,,realising this is going to be rough but trying to make the best of it and work thru it,,,and after it's over going,,, what was I thinking?
    September 2009
Posted by satch_ip on Sunday, February 12, 2012 9:05 AM
handiabled
 Geof:
Been there, done that, got the T-shirt...Wink
[View:/themes/fsm/utility/http://i1225.photobucket.com/albums/ee394/handiable/BF%20109F-4%202012%20BG/DSCI1413.jpg:550:0]
