Tamiya 1:48 Wildcat F4F-3 Conversion (Complete)
    August 2013
Posted by Jay Jay on Sunday, September 3, 2017 9:02 AM
There are not enough superlatives to adequately describe this F-4.  All I can muster is WOW.
    June 2013
Posted by bvallot on Wednesday, September 6, 2017 11:12 PM
Thanks everyone. Rooster, I realize you're kindly pulling my leg...but if you should at all be looking for something specific just shoot me a message. We can work something out. I'm about to start reaching a point here real soon where I'm running out of room to keep these reasonably around the house. The new ones are eventually going to need homes LOL. All the planes I build are for my son. I grew up watching my dad paint marsh and bayou scenes and ducks (as we're duck hunters) and taxidermy to boot. It all seemed too cool that lurking underneath the surface my dad wasn't too bad an artist alongside being a working man and it was all of this that made me stop and think a little harder about what I was looking at throughout the day. I started doing model aircraft when I graduated from college because of a 1:72 F-15 my father mostly put together himself as I was 8. As I caught the bug for it I saw the opportunity to hopefully provide my son with something to look up to. The last of these men that fought in this war are dying. I felt it was important that my son take an interest in this part of our history as their sacrafices have literally paved the way to afford the way of life we enjoy today.
I had planned to post the completed pictures tonight but after a long day, I'm a little too tired to do it now so I'll bang it out in the morning. Again, thanks guys.
On the bench:
Tamiya F4U-1  Kenneth Walsh
    June 2013
Posted by bvallot on Thursday, September 7, 2017 12:12 PM
Complete. =]
Very happy to see this bad boy back to life. I absolutely feel better about this one versus that first one but there is about 6 years of experience between them. She's still far from perfect. I still struggle with AM canopies fitting precisely onto the dash. I can eventually get it there, but it just takes more work than I feel it ought to for something that should seem to just happen a little easier. I see so many others here on the forum lick out these clean and sharp canopy/windscreens. I like mine to reflect a little dust and grime and usage, but in terms of construction I just don't feel I'm quite there yet. Maybe I'm over thinking it. Anyhow, I redid the windscreen to help it sit down a little better but really it was the Eduard PE that wasn't cooperating with me as it needed. Just goes to show you how tricky that stuff can be. After some CA and some shaping, I did my best to help this appear as it looks on the real Wildcat. There's a few other little things here and there, but it's not worth harping on. I am very happy with the outcome, and if this happens to be the last -3 I ever get to build then I suppose I can live with that.
Last few add-ons...
Among the last fiddly parts to go on were the antenna whips underneath the fuselage. Here is a pretty match up to a fairly recognizable photo of O'Hare and Thach. You can see the three antennas and another object with a fairing that seems to operate as a transmitter of some sort. The HobbyBoss kit represents this but it is a little small. I cut this piece off and buffed it up a little with some scratchbuilding. The back three are located at the 6 o'clock position but the most forward whip is at about the 6:30 spot. I lucked out and happened to find a pic of a -3 that was trimmed back enough in flight revealing it's belly and the whip was just faint enough for the film to capture it...in the 6:30 position. I wanted to build an operational Wildcat that was ready to roll off so I included these antennas. You'll note that I've attached them on access panels. I do not know for sure that this is correct. I could not find a direct example of precisely where they hook up. So I used a little what might make sense and went for it. I wanted to make that point for those out there wanting an accurate reference. I'd hate to steer you wrong. =]
 Untitled by Britt Vallot, on Flickr
I never heard from the guys at Beech18 so I did my best to make a mock up of what's happening here with the cowl flap actuators. Sort of speaks for itself. Naturally, almost none of this is visible but I don't care. =D I'm happy it's there!
The pitot tube I considered using from the HB kit broke while sanding. Didn't break my heart at all. I already wanted to build my own stronger version that was going to kick its ass anyhow. This is 0.8mm brass tube with stretched sprue passed through it until the thickest part fits nice and flush at the end. I leave an appropriate amount of length and sand it into shape. A drop of Tamiya ETC allows for a snip of plastic rod to add the little fin on top. Much stronger!!
One thing I kept noticing on the wartime -3s from '42 was this extra box and hosing on the right side of the prop reduction box. I never could identify it, but it seems to be auxillary venting from the spark plug line...my best guess based on location and hook ups. You can see it here pretty well with a photo-op between O'Hare and Thach. Anybody out there that might happen to know exactly what it is, then I'm all ears. =]
Here's how mine came out with a little scratching. Now she's ready to crank!
And here's a little walk around of the completed F4F-3A that O'Hare flew on his legendary MOH flight. The base is being borrowed from the Dauntless I built about a year back until I can pick up that block of cypress and make some more. I wanted to shoot her on a carrier deck. =P
One small thing to note I may have left out is the bowing along the cowling panel that covers the landing gear and undercarriage. It's on every Wildcat I've ever seen and I believe it's due to the gearing that swings 90º outward. I suppose it's possible that it pushes into this panel a bit and over time bows it outward. It does not appear to be manufactured this way as a means to vent air from this area behind the engine. If anyone out there can provide some insight into this I'm happy to learn what's actually going on here. In any event, I sanded this part razor this during construction and CAREFULLY convinced it outward away from the fuselage. It's a little thing that I think goes a long way in modeling the Wildcat. You'll see better in different views throughout the walk around. =]
Some cockpit views...a little tricky to get done with the lighting but I managed this.
And that pretty much wraps up this F4F-3A conversion. I doubt there's a cheaper way to do it. Most -3s did have the carb scoop on top so that would be one area where you didn't require any big changes to the cowl ring. Other than that, aquiring a HB kit as cheap as possible is probably one of the better options out there for modelers. The JPS conversion set was kind of a dud in this case and also hard to find, but it did provide some extras for those wanting to go the distance. But there's nothing on this cat that can't be scratched or provided by Eduard's PE to accomplish should that be desired. I hope you all enjoy and if there's any questions or thoughts to share then please drop them here.
(edit with new base)
Finally got around to making a base for this particular navy plane. Here's a few from that.
On the bench:
    January 2004
Posted by ChrisJH666 on Thursday, September 7, 2017 3:39 PM
Ok, seriously jealous of your modelling skills! That is one awesome Wildcat!
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
    January 2017
Posted by damouav on Thursday, September 7, 2017 4:21 PM
Simply Wow!
You have built a masterpiece, exceptional work. Very well done.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    February 2014
Posted by silentbob33 on Thursday, September 7, 2017 4:36 PM
Great job! It's hard to come up with any other words, this looks fantastic. Thanks for sharing it with us
On my bench: Academy 1/35 UH-60L Black Hawk
    March 2015
Posted by Toshi on Thursday, September 7, 2017 5:17 PM
This is the most comprehensive WIP that I've ever seen!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    September 2014
Posted by rooster513 on Friday, September 8, 2017 7:07 AM
This is one of the nicer builds I've seen Britt! All the details are really spot on. Thank you very much for all the work you put into the WIP and for sharing it all with us. Really great job on this!!
-Andy
    September 2016
Posted by ManCityFan on Friday, September 8, 2017 7:43 AM
Fantastic job!  You put a lot of extra effort into this build, and it shows.  This is fast becoming one of my favorite birds.  The history alone is impressive, but there is something about that fat body that appeals to me.  Thanks for sharing this WIP.  It was a joy to follow.
D
Dwayne or Dman or just D.  All comments are welcome on my builds.
    July 2003
Posted by ridleusmc on Friday, September 8, 2017 8:15 AM
That thing is freaking increadible.  I love all the detail that you've packed into it!  It's truly a GREAT model!
    March 2013
Posted by patrick206 on Friday, September 8, 2017 4:28 PM
Britt -
Worthy of any museum display, thanks for a great WIP and all of the photos. Excellent job.
Patrick
    December 2010
Posted by 1943Mike on Friday, September 8, 2017 11:08 PM
Bow DownToast
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    February 2012
Posted by lawdog114 on Monday, September 11, 2017 11:49 PM
I have no words........simply stunning. Thanks for the ride.
    May 2010
Posted by GeauxTigers on Tuesday, September 12, 2017 6:45 AM
Not only is this one of the best Wildcat builds that I have ever seen, the build report is also excellent. I not only learned a lot about the Wildcat, but also picked up plenty of great tips on weathering and scratch building. Very inspiring. Thank you for your effort. Scott
    June 2013
Posted by bvallot on Wednesday, September 20, 2017 9:06 PM
We've definitely got the nicest bunch of guys I imagine a forum can have. =] Many thanks to all of you. Really, it makes me happy to know that you all enjoyed it and to pay it forward all the tips and tricks I've picked up over the years or through my education. I just hope my wife lets me keep at this just a bit longer.
On the bench:
