kg4kpg wrote: |
Well, a choice has to me made. I'm into this kit about 45 bucks now. I'm already going to have to modify the tail a little but the civilian plane has a different nose. I can try to scratch build it but I don't know if I really have the skill for it. I have someone who has a spare resin nose but he want's 30 bucks. Probably not a bad deal, just a lot to me. What to do??? |
We're building the same aircraft!
Here's what I know, and I'm starting with the Academy 1/72 -5A.
RedRoo and Quickboost both sell/sold a nose deck, but the QB has a hatch at the front and the RR I can't find. Mine at 1/72 is kind of small so I'm going to scratch it up.
Engines: big deal. I bought a B-25H-J for not $$ for the cowlings with all the exhaust pipes, plus engine face and prop. Haven't looked into the right props but I've got bags of the things, so let me know if you have more info. Big issue is that the kit cowling measured over the cowl flaps is 48 ", while the replacement R2600's are 58". If you look at pics it seems that the bottom of the cowl stayed aligned with the nacelle, but the top was raised by 10", meaning that the crankshaft center is about 5" higher. Major reshaping of the nacelles, esp. on top of the wing. Need ideas.
Vertical tail- SLAFCO seems to have come up with a one or two-off. I'll scratchbuild it as I cannot find a part. The horiz tail planes are probably bigger, but I cannot find info that sez so, so I don't care.
Decals are available from Draw in both scales. I plan to use Testors White and Ford Engine Red.
Water pickup I have no idea?
What do you know? I'd like to here any tips.
There's lots of pics on scalefirebombers.
www.youtube.com/watch?v=5X7wXiTvYzc
Bill
