Hi Richard!
The IP locates against a raised molding that's located just aft of the fuselage locating pin on the top of the hull, just aft of the turret area. Install the IP before you install the pit if it's not too late!
The molded IP is fine as it is if you feel like painting it. The decal is just a teensy bit out of register with the molded detail, but doesn't look bad with use of enough decal solvent.
Keep in mind when joining the fuse halves:
You have 4 bulkheads and the IP to fit into their slots when joining the fuse. Not real tough, but dry fit a couple times to be sure of alignment.
Pay attention to the fit of the louvered door in the nose. Dryfit it! You may have to choose where to glue first as it may leave a big gap to one side.
Also, Daywalker sent me actual pics showing the mooring cable molded on the port fuse half. It runs down and ends on the foreward part of the hull just ahead of the nose gear. There is no molding of the cable on the bottom of the starboard fuse half. You should just nip off the bottom of the cable and blend it into the hull. No one is ever gonna see it anyway.....but if you leave it as is, It can be seen and looks dumb.
I have some pics that will be up in a little while.
