First of all, sorry it took so long, it's been a long week at work.
detailfreak wrote: |
PSSTTOFF;i may just have to try that method of zimmerit.and the build is progressing quite nicely. |
Thanks detailfreak, it's pretty straight forward once you get it down, practice on some scrap first
Thunderbolt379 wrote: |
Hi psstoff995 --
The zim is looking very realistic! Squadron white has been my putty of choice for many years and it's great to see this kind of application. You have more guts than me, I could never bring myself to do the "smear and scrape" method, which is why I ended up going with Cavalier (which is looking good, and I hope to get back to the StuG IV before too much longer.)
Thanks- it was really just due to a cost issue, limited funds are the only thing keeping me from the convenience of those well detailed Cavalier sheets. They do look much nicer, my brother's used a set or two before- also they include some nicer raised detail for parts that aren't covered in zim- mine now have left over crusts of white putty lol
I'm curious as to why you filled the joint-line around the top of the fighting compartment -- was it molded too enthusiastically? Or was there an issue with fit? That division was a natural juncture in the armor, the roof would be removed to enable the engineers to crane out the gun for work. This is shown in photographs in Squadron's StuG III Walk Around book, and the IV was essentially the same superstructure.
Cheers,
Ah- in that case it's more my misunderstanding as opposed to an attempt at going for realism then. For one thing, the gap that was molded in, not sure if it was too enthusiastically portrayed or not, my real issue was, at least in scale- it looked to be too deep/created too much of a shadow for what I thought it would look like in 1/35- also when I glued the roof assembly down to the "turret" walls, the walls are essentially a four sided, kinda bent box shape, think of a half crushed cardboard box, no top or bottom, just sides- and the part was showing it's age with a bit of warpage, instead of trying to re-bend it, I just used the roof to help square it out, so the gap was also not even on all four sides, some were more in scale (for my taste) than others, figured I'd just fill the whole thing and try and replicate any gap with paint later.
That whole assembly is still not attached to the top half of the chassis, and test fitting is showing that it's still a little warped, what wont glue down flush will be filled with green putty as well, then maybe "zimm"ed over with the white. Thanks for checking it out- sorry for the late, lengthy reply lol
