Hi guys, its been a while since I was here but I have been working. Here are some picures to prove it.
These four parts make up the Junkers Jumo 004 Engines.
Here you can see the second cockpit. As you can see the seat pad is a different color. That's because I didn't like the color of the first one and went out and bought some brown paint. I think the back seat looks better. As for the color mismatch that's ok because apart from these photos it will never be seen an cushions wear differently and by the time this aircraft was serviceable uniform parts were hard to come by. They would use whatever they had.
I filled the front wheel well with plumbers putty for ballast to keep the nose wheel on the ground. I hope its enough.
Model Master RLM 82 was used as the base for the wings.
Model Master RLM 81 Splinter pattern was then applied
Model Master RLM22 was applied to the bottom of the wings and the engine nacelles. Eventually the belly of the fuselage will also be black
Then came the realization I never cut out the wheel wells.
Here is the PE Wheel Well walls
Model Master RLM 76 was used for the base coat for the fuselage
For the fuselage camo pattern I used Model Master RLM 74. This process has been extremely tedious
I still have a long way to go before the camo pattern is done. As tedious as its been I have to say I like it a lot.
Till next time, Keep em flying!
