Stik, looking like solid progress on the 109.
Is that the old Matchbox kit?
Lew, looking great with the yellow nose.
Progress Update
I've spent much of this week working on improving the pit of the big Stuka.
I added the seat hoop from plastic strip, after hacking the seat down to something that more closely resembes a real Stuka seat.
The frame behind the pilot's seat was molded with solid plastic in between the frames, which should not be there, so 15 minutes with a drill and file soon sorted that out.
The sidewalls also got some attention, adding detail, and correcting a few glaring problems.
The rebuilt section at the back replaced some completely spurious detail in the kit.
This is what it looked like before.
Whereas I only added a few bits to the starboard side of the pit.
Finally I jazzed up the IP with some plastic card and some MDC PE instrument bezels.
I also invested in some after market..
This is Eduards Jabo set for their 1/32 109, which is ideal for this build as it contains an SC250, and 4 SC 50s all with PE fins etc.
This is the MG 15 in the box..
...not exactly overwhelming, so I bought this..
Just check out the perforated barrel sleeve and PE sights!
Next stop painting the pit.
Karl
