Ma.K Group Build 8/2010-8/2011
    March 2007
Posted by MrSquid2U on Monday, November 15, 2010 8:47 PM
Fleshing out the cargo bed-
    March 2007
Posted by MrSquid2U on Tuesday, November 16, 2010 12:56 AM
I needed a "chassis" underneath to hang the suspension from. I also wanted more of that 'organic' look than an engineered look so I sculpted it.
    March 2007
Posted by MrSquid2U on Tuesday, November 16, 2010 1:55 PM
Knowing that a trademark of Ma.K. is mechanical representation even when it doesn't make engineering sense I'm setting about to have some on the suspension/drivetrain since the body is unusually devoid of such.
    March 2007
Posted by MrSquid2U on Tuesday, November 16, 2010 5:13 PM
The cargo bed needs some tie-downs. Could have just been like 'grab handles' but I wanted them recessed into the floor. Set about to make such. Needed an upper lip too so they could sit more flush.
    May 2004
Posted by modelbuilder on Tuesday, November 16, 2010 5:24 PM
Well Ive lurked in the shadows long enough, time to get in this thing. So here is what I am working. A WAVE/3Q Melusine. This is my first MaK. I dont have much done so far, mainly got the arm and leg segment together and ready to be filled with Milliput that I picked up at Hobby Lobby. I also picked up some metal rod. I am going to sculpt the joints. Wondering if I will have enough Milliput to fill the cavities and sculpt the joints. Speaking of which, should the joint between the upper leg and waist joint be sculpted or left as is.
    March 2007
Posted by MrSquid2U on Tuesday, November 16, 2010 5:30 PM
ModelBuilder,
 Be carefil with that Miliput! I had used it many times and actually liked it a lot. This time it never, ever, never, cured. But, I will say it was probably old in the box (from Hobby Lobby!) Just make sure it seems pliable and kneads easily, mixes well.Wink
 Unless they sell real small boxes that I've never seen- you'll have more than enough!
Welcome to the GB!Cool
    May 2010
Posted by Gunpla Master on Tuesday, November 16, 2010 7:19 PM
Dead Mr Squid, U'r killing me.  Are you a Model Maker for the Movies and slipped in on usToast
    May 2010
Posted by Gunpla Master on Tuesday, November 16, 2010 7:24 PM
MrSquid2U
ModelBuilder,
Ditto, ditto and did I say ditto.  You got way more than enough, use rubber gloves while you mix, helps a great deal, follow the instructions, you can add color if you like to the putty and no, you do not need to fill the torso area unless you just want to.  Glad to see you come out into the light ModelBuilder,  Ma.K's kill vampires.  lol  I for one am looking forward to this.
    May 2010
Posted by Gunpla Master on Tuesday, November 16, 2010 7:27 PM
I would just like to say thanks to all those who have and are apart of this GB, we have some of the most talented individuals I have had the pleasure to work with and know.  So again, to all you who have helped to make this a real GB thanks, now shoot me for all that mushy garble!  Clown
    March 2007
Posted by MrSquid2U on Tuesday, November 16, 2010 7:31 PM
Gunpla Master
Here, grab the blindfold and then up against the wall!Stick out tongue
I'd like to extend my thanks to you though. The involvement and tone set by the "host" of a GB can go miles in how folks feel as they participate.
Thanks for the cozy, friendly corner of this hobby in which we congregate!Yes
    March 2007
Posted by MrSquid2U on Wednesday, November 17, 2010 7:36 AM
And here are the four tie downs sunk into the bed and still operable.
    December 2007
Posted by Cosmic J on Wednesday, November 17, 2010 3:11 PM
Looking good, Mr Squid. I agree about the drivetrain - the MaK vehicles all seem to have a body consisting of smoothly curved, organic looking hulls, w/ hard angular mechanical looking engine parts sticking off them. Keep up the good work!
    December 2007
Posted by Cosmic J on Wednesday, November 17, 2010 3:21 PM
modelbuilder
Excellent, and good to see you! I've got a Mel in the stash, so I'm interested in seeing how this build goes.
Miliput usually does the trick, but recently I've switched over to Aves Apoxy Sculpt. It gives me a little less hassle than the Miliput did. Could be I just had a bad batch, but there you go.
You should easily have enough to fill the limbs - it takes less than it seems like it would. I would echo the sentiments about testing the Miliput before comiting it to the model - just mix up a small amount and form it into a marble, then see how (or if) it dries. You can also practice sculpting it while it's wet and carving it when it's dry.
For wire, I would recommend coreless solder - brass rod can be a bit too stiff. It flexes well enough to let you get the model in position w/o needing pliers or possibly damaging the kit parts.
Looking forward to your work.
    December 2007
Posted by Cosmic J on Wednesday, November 17, 2010 3:26 PM
Gunpla Master
LoL! You flatterer. Yes, we love you too. Big Smile
And thanks for starting this GB in the first place. I probably wouldn't have started this kit otherwise, and I've been rather enjoying it.
    March 2007
Posted by MrSquid2U on Wednesday, November 17, 2010 5:24 PM
Needing attachment points for the lower control arms came up with a platform that fits the backbone already in place. Added some weld beads since this is where the detailing will start coming out. No pre-planning here, just winging it!
    May 2010
Posted by Gunpla Master on Wednesday, November 17, 2010 7:57 PM
Tongue Tied Just winging it!!!!!!!!  Come on dude, you are a master and I sure would not call what you are doing winging it.  I am just in awe every time you post, which I might add is a glorious everyday.  I run to the computer to see what little trick you have pulled out of your hat next.  There are many here with your skills and I am enjoying your's right nowBow Down
What impresses me the most, this is not a kit, but a kit bash to build a specific Kow design, that is beyond just winging it Whistling
And the wheels were the bomb, can not wait to see this puppy setting on'em.  You know we have our ways of getting information from your brain, beware, be very aware Alien
    May 2010
Posted by Gunpla Master on Wednesday, November 17, 2010 8:00 PM
Cosmic J
 Gunpla Master:
Oh you got me feel'n all warm and fuzzyAngel.   And your right, even a sharp stick will make a frog hippy hop.Wink
    May 2010
Posted by Gunpla Master on Wednesday, November 17, 2010 8:21 PM
A shout out too all my missing buddies:
havoc, man where U @, miss my Island Ma.k'r and where is that Snake Eye @????????  Com'on back, we miss ya.Boo Hoo
Mad-Modeler, the last time I heard from you was 2 months ago and U took the bull by the horns announced a triple lindy, miss U buddy, just a single would be cool. Paradise
Ti4019. you tease, you post a Konrad start and then Houdini, would sure like to see ya post again friend, I want bite ya, well maybe a small bite Alien
Klik, wish you would stop by again too.Propeller
Alright enough butt kiss'in, look f/ea one of ya to report for duty ASAP!Super Angry
    January 2010
Posted by Klik on Wednesday, November 17, 2010 10:34 PM
Reporting for duty, Sir!
Oh, I been just lurking in the shadows, working on a kit here and there, and trying to finish up my Fireballs and Lunadiver.
Keeping up the good work y'allCaptain
oneyearwar1
The hardest part of flying isn't flying...it's landing.
    May 2004
Posted by modelbuilder on Thursday, November 18, 2010 10:31 AM
Klik
Ahhhh another shadow dweller. The shadows are dark and safe. We venture into the light only every so often.
    May 2004
Posted by modelbuilder on Thursday, November 18, 2010 4:46 PM
Well Ive encountered my first problem with this kit. Several of the parts that I filled with Milliput have dried hard but others seem to have not dried at all. Only thing I can think of to do is dig it out and try again. Any suggestions?
    March 2007
Posted by MrSquid2U on Thursday, November 18, 2010 5:04 PM
modelbuilder
DANG! Miliput strikes again?
That some of it dried hard almost suggests that you had other areas that weren't mixed well prior to application? If that is the case then you might carefully scrape away the bad areas and try a lil more as filler for those spots?
BUT- IMHO Miliput stories are seeming to grow and it did happen to me- so I'd scrape away what is tacky and carefully sand away what is dry. Then start over with another putty that you are comfortable with. Many people like Aves and I've had good luck with Squadron brand.
Let some other folks chime in and I hope you come up something and don't lose any enthusiasm for your build.
Good Luck Now!
    May 2004
Posted by modelbuilder on Thursday, November 18, 2010 8:23 PM
Well Ive got the Milliput scraped out of the the parts. It was strange, it was half dry and half not. Had almost taken on a sand texture. Gonna let the parts set over night then give it another try this weekend. Is there anything I can use to clean the residue thats lefts out of the parts?
    March 2007
Posted by MrSquid2U on Thursday, November 18, 2010 8:35 PM
If it's not cured at all you can vigorously wipe at it with 90% Isopropryl (sp?) alcohol and with a toothbrush too. If it's too dry for that you can just dig at it with something blunt and try not to gouge the plastic kit parts. The alcohol usually won't hurt the plastic at all if it does work on the putty. I've got a nylon "wheel" for my Dremel- think of a 'wire wheel' but with nylon bristles. As long as you don't overheat against the plastic it will remove gummy stuff (putty) without grinding into plastic. Last resort is scrape then sand.
No matter what it won't exactly be fun.Sad
    March 2007
Posted by MrSquid2U on Thursday, November 18, 2010 8:42 PM
Starting on the A-arms.
    May 2010
Posted by Gunpla Master on Friday, November 19, 2010 3:57 PM
Just keeps getting better. Toast
    May 2010
Posted by Gunpla Master on Saturday, November 20, 2010 6:29 PM
Crying No up-date from Squidward??????????today is a sad day w/o a post from U buddy.
    March 2007
Posted by MrSquid2U on Saturday, November 20, 2010 8:06 PM
Yeah, got sidetracked with "life". But, should have something for you soon.Wink
    March 2007
Posted by MrSquid2U on Saturday, November 20, 2010 9:01 PM
Further suspension progress.
    March 2007
Posted by MrSquid2U on Sunday, November 21, 2010 4:37 PM
Just in case anyone finds this interesting or helpful???
Working on fleshing out the suspension-
More details,
The A-arm supports start as styrene cut to width and then two different diameter holes hogged out by Dremel.
They sit upon two different ledges on the backbone- those center humps. Know where the hump came from- a lil gumball machine container cap. It's the red plastic piece visible there. It was simply pressed down into the Sculpy putty prior to baking. That caused the two ledges and only later as I was staring at em did I think to make a saddle mount for the A-Arms.
Here's what it takes for the upper control arm-
Here's some components for the driveshafts and CV joints. That's standard electrical shrink wrap tubing which mimics the CV covers.
After the "A-Arm platforms" are squared up I then bevel the outer edges to receive the tubing running the length which later accept the arms.
Once the tubing is in place I re-contour the pedastals.
From front to rear are a completed saddle mount, a roughed in one and then the rawest form- two squares waiting.
I hope that might help someone in a similar situation to attack their target!
FWIW
