Those pitot tubes, man... No matter how careful I am... Another thing I hate about Hasegawa 48th F-4s are the stab mounting dimples. Those little-a** dimples are way to small, with very little area for the glue to hold. It seems those things will break if too much dust settle on the model while its sitting on the shelf.
Anyway, I finished both trunnion covers on the wings, & got the halves glued together. Just need to fill & sand. Also finished & painted the certerline tank. I finally got the technique down where you use liquid glue on the seams, & use the squeeze out as filler. Absolutely no visible seams after painting.
The scheme that I'm doing has colors that I've never used, either on an F-4, or at all, so I just put the parts on to get an idea what it going to look like.
I'm not going to use the 370 outbd tanks, so I filled in the holes with Evegreen .080" (2 mm for our metric friends) rod, which fit perfectly. Dab liquid glue to soften the plastic to fill in the gaps, sand & done.
![http://img.photobucket.com/albums/v26/ishthe47guy/Model%20Pics/VF-202%20F-4S/IMG_2995.jpg](http://img.photobucket.com/albums/v26/ishthe47guy/Model%20Pics/VF-202%20F-4S/IMG_2995.jpg)
