The Offical Natural Metal Finish Group Build III
    August 2010
Posted by Furyan on Tuesday, March 27, 2012 1:42 AM
Hey Doogs.. I have a question; your 1/48 P51 .. did you paint the wings a different colour to the fuselage? If so what colour plse?  I need to find a good bare metal silver for the body but stuffed if I can find a decent different silver for the wings as they were slightly different irl.  What did you do???
Last build: Tamiya's P-51D Mustang in big 1/32 - Lt Col J C Meyer and his blue nosed bastards. Never forgotten.
    June 2010
Posted by DoogsATX on Tuesday, March 27, 2012 2:28 AM
The wings were aluminum lacquer in real life - so yeah I used a different color (Alclad Dull Aluminum vs. Aluminum and Duraluminum on the fuselage). Next time around, I'm planning to use Tamiya AS-12 on the wings.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    June 2009
Posted by kermit on Tuesday, March 27, 2012 1:10 PM
Tadaaaa!Big Smile
Ok, pants down time... it is not an early cowling but it fits like a glove and quite frankly given the speed and pricetag i really don't mind it. I am back in the game and happy about that.
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    August 2010
Posted by Furyan on Tuesday, March 27, 2012 1:31 PM
DoogsATX
Thanks.. hmmm AS-12 is what Tamiya is saying to use on the fuselage, but the wings were a different colour slightly (they say use that item there as well). I might just give the wings an extra coating of darker prep then spray over with the AS12 (bare metal silver). Yeah yours do look a slightly different colour.  Hey also plse tell me the best way to get the curve on the blue nose colour.. did you use masking tape or putty???  Thanks again =)
Kemit: Good stuff, glad you got it sussed.
Posted by Gamera on Tuesday, March 27, 2012 7:39 PM
Richard: Wow, that was quick! Even if it's not the exact part -looks good to me. And btw nice new avatar Toast
Furyan: I think the aluminum lacquer they painted on the wings would be a little more grey and a little less metallic looking than than the actual aluminum parts of the plane.
    August 2010
Posted by Furyan on Tuesday, March 27, 2012 7:47 PM
yeah Ive filled the panel joins Doogs suggested so I think I might just give the wing tops an extra going over with 1/800 or 1000 grit paper and paint them bare metal silver like the body.
Just need to know how to get the blue nose curve done properly >_<
Posted by Gamera on Tuesday, March 27, 2012 8:05 PM
Furyan
Ok, duh- looking back Doogs already answered your question- sorry.
As to the nose, you can use a french curve to get the right shape, big problem will be to get both sides symmetrical. You might try tracing it out on a piece of paper and then using the paper to transfer the design to a piece of tape stuck to glass. Then flip the paper to get an opposite piece of tape for the other side of the nose. My two cents anyhow.
    June 2010
Posted by DoogsATX on Tuesday, March 27, 2012 8:43 PM
Furyan
Yeah I've got a pretty foolproof way to do it - I'll post later this evening after I've got the kids in bed and asleep.
    August 2010
Posted by Furyan on Tuesday, March 27, 2012 8:54 PM
Awesome, sweet, cheers Doog  Big Smile
    June 2010
Posted by DoogsATX on Tuesday, March 27, 2012 10:42 PM
Alright, here goes!
First up - masking the 352nd's blue nose. I agonized over how to do this for some time, so I totally feel your pain!
First - scan or copy/enlarge the profile in the instructions so they're 1/32 scale. Cut out just the nose. Doesn't have to be exact, because the main concern is the curve.
Second - put Tamiya tape on wax paper. Put cut out over Tamiya tape. Tape it down.
Third - with a decent pair of scissors, cut the curve. I've found it's a LOT easier to cut curves with scissors than with xactos.
Fourth - put mask on the plane.
Next - the wing/fuselage thing. Guess I should clarify - next time around I would/will use AS-12 for the wings and Alclad for the fuselage. After the various clears, Alclad Aluminum and Dull Aluminum look similar-ish...I think the lacquered wings need a different tonal quality. Hence the AS-12...
Posted by Gamera on Wednesday, March 28, 2012 8:19 AM
Thanks Doogs, next time I'm in such a situation I'll give this a whirl. Looks lots easier than mucking around with a french curve trying to find the correct shape.
    September 2009
Posted by B17Pilot on Wednesday, March 28, 2012 12:40 PM
I don't know what I did, but pulling up tape to mask for OD anti-glare panel and noticed this when a bit more tape came off than expected
I waited just over 24 hrs before masking that panel.  This is the only one that did this.  Huh?  Thought this stuff was suppose to be tough!
    August 2010
Posted by Furyan on Wednesday, March 28, 2012 1:33 PM
B17: Argh... should be easy to fix yeah?  I wait ages for  paint to dry before applying the mask. Never had a prob with Tamiya masking tape. Hope its sorted ok for you =)
Doogs: Outstanding mate, thanks so much, great idea. Will totally bookmark and print that post out and do what you suggested. Thanks again!
    August 2010
Posted by Furyan on Wednesday, March 28, 2012 1:55 PM
K sorry forgot to add, filled the wings last night. These may look over board but trust me they are now as smooth as a babies bottoms  =]
    August 2010
Posted by Furyan on Friday, March 30, 2012 2:22 AM
Ok for anyone that may want it in the future heres a 1/32scale profile (308mm long) of the Petie II.  Do what Doogs suggested a few posts back re the blue nose curve, by far the best suggestion Ive read.
(expand for printing)
Posted by Gamera on Friday, March 30, 2012 2:04 PM
B-17: Ouch! Yeah I've seen Alclad do that sometimes. It's rare but it does happen sometimes, I don't think it's much worse for peeling up than regular paint though. Did you wash your model before painting? I think that's my problem so I've tried to be more careful.
Cliff
    June 2009
Posted by kermit on Friday, March 30, 2012 2:15 PM
I agree with Gamera, you should be able to mask alclad without a problem. It usually comes down to surface prep that went wrong... Personally i always use demakeup pads with a touch of alcohol on them as well as the kind of disposable paper towels to clean your glasses before i hhit the booth with any model.
During assembly you handle the model alot so even with sprues that have been cleansed before commencing a build some grease and stuff will always be on the model if you take it into the booth without any cleaning.
Richard
Posted by Gamera on Friday, March 30, 2012 2:59 PM
And oh btw: great job Furyan- those ammo belts look fantastic!
    October 2010
Posted by Casper the Chihuahua on Friday, March 30, 2012 11:21 PM
I've shaded some different panels varying shades of grey to help break up the Alclad when that goes on. The exhaust will be done in Alclad magnesium so the shades should help the look of jet exhaust.
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    October 2010
Posted by Casper the Chihuahua on Saturday, March 31, 2012 9:42 PM
I decided to use the Alclad chrome just to make the surface 'pop' a bit. Alclad usually is a darker metallic than standard so I thought at this scale it helps to exaggerate the look of the jet and give it more. I've sprayed the chrome and when fully dry will mask off the rear and lay down the jet exhaust tones.
Cheers
    June 2009
Posted by kermit on Sunday, April 1, 2012 3:53 AM
Casper,
Your trumpy is coming along very nice and i really like your approach with the preshading for the exhausts and various panels. It will be a delight to follow your progress!Yes. Everytime i have tried an extreme high shine finish like chrome it didn't turn out for me this well but that is mostly due to my skills or lack thereofWink Looking great!
As for my trumpy cat....
Assembly was completed yesterday and i have already sprayed and post shaded the green tail.
I have secured the gun and ammo hatches on the port wing but used microscale's micro liquitape on the starboard ones so i can pose em open once finished. I really love this stuff; just like liquid post it notes in a bottleSmile
For masking off the engine and wheelbays i have used a wet kitchen towel technique which has worked tremendously nice for me in the past.
Next up, and as soon as i finish writing this i am going to take a deep breath and continue on to mask off the tail and preshade the fuselage and wings with thinned black acrylics. Wish me luckWinkYes
Richard
    April 2010
Posted by Theuns on Sunday, April 1, 2012 5:08 AM
Since there are two odd months left please sign me up for and old ESCI 1/72 F-104c Starfighter in Bare metal sceeme.
Theuns
    November 2003
Posted by halfpint33 on Sunday, April 1, 2012 7:32 AM
Having a hard time getting my canopy masked off.It's a 1/72 F84 tamiya kit.Tried bmf but couldn't hold my hand steady enough to cut the straight linesCrying  Gonna give cutting small strips of tamiya tape a shot.What I get for working in 72nd scale I guessBig Smile Really wanna get this build painted.
    October 2010
Posted by Casper the Chihuahua on Monday, April 2, 2012 2:09 AM
A Super Sabre with a super finish! Cool Such a great little kit, these high end Trumpeter 1/72 kits are certainly worth the money and are highly detailed.
I'm happy with the way the Alclad chrome/magnesium/jet exhaust came out. These decals are possibly the best I have ever worked with, settling down into the panel lines beautifully.
Cheers
Posted by Gamera on Monday, April 2, 2012 10:48 AM
Hey Casper- terrific!!! Cool
    June 2009
Posted by kermit on Monday, April 2, 2012 11:43 AM
Gamera
Ditto
And the Talon strikes again. It so delivers every single time i use it...
Hope you guys like her too. Hope to mask and spray the yellow wings tonightSmile
Richard
    December 2006
Posted by kbuzz01 on Monday, April 2, 2012 6:57 PM
Casper and Kermit - great work, guys!!  Toast Toast
Ken
animation6.gif image by kbuzz_photos
    September 2009
Posted by B17Pilot on Tuesday, April 3, 2012 1:30 PM
Gamera
Cliff
Yea I washed it down with Windex before painting.  Let it sit for more than 5 minutes before applying paint.  Always had good results doing that, with no problems till now.
    July 2008
Posted by vetteman42 on Tuesday, April 3, 2012 1:53 PM
Halfpint I have the same troubles with shaky hands even in 1/48, what works for me is a brand new blade in the hobby knife and I use a rocking motion instead of pulling the knife where I want to make a straight cut masking canopys. Only works with a brand new very sharp knife.
Theuns your F-104 is in and welcome back to the group.
B17 bummer about the paint lifting man. I think some paints are a bit less prone to lifting than others and surface prep is important for sure. However in some cases it is how you hold your mouth when painting and masking that does the trick it seems. I am sure you can fix the problem and end up with a nice finish.
Casper wow ! Another very nice build is added to the front page, and shiny too Cool Very well done sir YesYesToast That Trumpy did build up nice in your skilled hands.
Kermit oh my but you saved it being able to get the new cowl and are on the way to a stellar finish. That Talon is good stuff isnt it Big Smile Hey are you going to be able to remove the cowl to show off that engine ??
To all, I feel obligated to tell you why I havent been here as I should have been, or building much this past year, and to maybe offer a little advise to those of you who have kids around. We, my sister and I, have been battling drug addiction in the house, my 22 year old niece for a bit over a year now. Numerous trips to rehab have happened to no avail, she would get herself kicked out each time we sent her, and go right back to the drugs. I dont want to get into the ugly details of things that have happened, as it hasn't been pretty at all. Kind of like seeing what bad thing is going to happen next sorta thing. There have been 10 OD deaths here where we live from the first of the year alone so I know the problem is a serious one, not just in this house.
So my advise, please, if you have kids or grand kids or any kids around. Step back and watch them with your gut and not your heart, see what they are doing. And if something just doesn't feel right, no matter how small it seems find out what is going on with them. Don't make the mistake of thinking it cant or wont happen, because it just might.
Randy So many to build.......So little time
    June 2009
Posted by kermit on Tuesday, April 3, 2012 2:44 PM
Vetteman,
For what it's worth... I know all about the destruction that addiction brings to a family and i guess i can say on behalf of everybody that knows you on here symphatizes with you im sure and personally i hope that in time everything will turn out for the best. Ill be keeping an eye out for ya buddy!
B17
My apologies for assuming it must have been something like cleaning... Stuff like this happens sometimes and it is very annoying to say the least. I hope a retry will solve everything for youYes
Halfpint
I must say that i totally missed your post but as i understand it you have trouble masking canopies? Vettemans tip on the sharp blade is certainly golden. And most canopies have raised edges. Just go as slow as any shakyness on your part requires and use those edges as guides while you make your cut.
Contrary to most i actually enjoy masking canopies while enjoying a dvd or some music. Patience, a sharp blade and a state of zen like concentration is the name of the game here... Oh and if you have trouble seeing the edges under the masking tape, try raising it to a lamp; it will show em very clearly.
Richard
P.s.: I kinda scr*wed up the yellow wings last night so i sanded the gritty sandpaper like finish i had and resprayed tonight. Looks like it went better now but i sprayed enamel so im not touching it for 24 hours... Yellow paint sucks...
