Made In USSR GB
Dre
    June 2007
Posted by Dre on Tuesday, November 20, 2012 1:28 PM
I hope that doesn't need nose weight!   Fantastic work as usual, Bsyamato.
    October 2008
Posted by bsyamato on Saturday, November 24, 2012 6:26 AM
Dre
...... totally forget to check for a needed weight!!!
Dre
    June 2007
Posted by Dre on Monday, November 26, 2012 9:04 AM
It occurred to me that this model belongs to this GB, not the others where I've been showing it.
This is almost finished-just a few more decals and the breakables to go before I load the missiles.
    October 2008
Posted by bsyamato on Monday, November 26, 2012 11:38 AM
the huge beast!!!!!
Dre you're right Embarrassed the Mig was need a weight on the nose.. even instructions shows; as i totally scratchbuild the cockpit i totally forget to check about ...
I resolved aniway, i make an hole on the back on the front fuselage ang inserted two long lead pieces and filled with PVA glue and fixed the problem Toast
Thanx for the advice in time!
Dre
    June 2007
Posted by Dre on Monday, November 26, 2012 11:44 AM
I wish I had mentioned it sooner so you wouldn't have had to fix it after the fact... glad you got it fixed though.
    October 2008
Posted by bsyamato on Tuesday, November 27, 2012 4:15 AM
fortunately the mess about the additional hole is not visible when all is close :D
    April 2006
Posted by waynec on Sunday, January 27, 2013 10:29 PM
another russian. this is an tamiya older kit. it is built as a syrian tank, golan heights OCT73. the syrians put sandbags over the fender mounted external fuel tanks. the rear brackets are for external fuel drums for extended operations, something not necessary in the syrian plans for northern israel. this is probably the most beat up, weathered vehicle i have done. it's dinged up with engine gray and metallic gray, washed with MMA black wash, and powder weathered on top of that. i may redo the sandbags. they look a little big but i used the tamiya plastic ones as a template. they are made of modeling clay, roughed up with a toothbrush and painted IDF khaki (irony). they were held on with wire but i haven't found any mesh the right size.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Dre
    June 2007
Posted by Dre on Monday, January 28, 2013 8:42 AM
That's right sharp, Wayne.   Beat up, grungy and ready for more- just the way armor ought to be.
I'll agree that a re-do on the sandbags may be in order- they do look a little funky.
Keep trying and I'm certain that you'll get them sorted out in time.
I watched a video the other day of a Syrian tank getting brewed up...  not very pretty.
    April 2006
Posted by waynec on Monday, January 28, 2013 1:26 PM
i didn't really like them either. halved the size of the sandbags. here are some closeups and 2 new glamor shots.
Dre
    June 2007
Posted by Dre on Monday, January 28, 2013 2:20 PM
Those new ones look much, much better although a couple look to be in danger of sliding off.
I'm terrible at making these things myself...
    October 2008
Posted by bsyamato on Saturday, February 2, 2013 4:37 AM
Wow, excellent tanks Waynec!
