A (little) bit of progress on the Blackjack;
The weapons bays & main landing gear bays are now fitted into the lower fuselage, I've used weld adhesive throughout here as the blended central section of the fuselage will have to bear the weight from the main gear as well as the extended wings;
The upright edges of all the bays has been painted to make masking easier when the time comes & the areas above the intakes have also been painted as would be difficult after the intakes are fitted;
The instructions suggest fitting the forward fuselage halves to their respective upper & lower main fuselage parts (as below) before joining the two complete halves together, but after a bit of studying I've decided to joint the completed forward section to the completed rear section - there just seems too much room for alignment problems in building in the suggested way;
The upper & lower forward fuselage parts are not that clever a fit, the upper section being about 2mm wider on each side than the lower;
I'm thinking about gluing some crap plastic locating tabs into the upper section in the hope that it will be pulled narrower when it's assembled. I had planned to make these quite robust, with plenty of surface area for strength, but looking at how close a fit the cockpit section is, there isn't much room to play about with (any suggestions on this one welcome?);
The canopy isn't that great a fit either, being narrower than the fuselage side by a noticeable amount, although I'm hoping that if I can get the "tab" arrangement sorted for the forward fuselage halves, that this should narrow the gap somewhat so that a minimum of work will have to be done sorting the canopy / fuselage joint;
The intake bodies are now built up & just need some sanding & finishing where the side panels meet the floor & roof;
