Progress at last! It took a while to get started, but things are rolling along now with the ICM I-5 (early) that I'm building.
I got the fuselage populated and ready to go:
The seat was a bit strange and fiddly (for me at least). It started out as a mostly flat piece of styrene and the instructions had me "fold" it along two seams and glue it in the center to make the final part. It went easier after I applied a bit of solvent to the creases to soften them up. Anyone know what that black piece is at the bottom/front? Bomb sight maybe?
Anyway, here it is all buttoned up:
Next was the engine cowling and nose:
This piece was very challenging for me. It consisted of the nose part where the spinner goes, then I had to glue on the aft sections of each cowling. One of these cowlings is different from the others, but has the same part # and the difference is not called out in the instructions (it's the one on top). As you can see, this arrangement leaves some fun seams to clean up. Those grid lines are 1" square, so that gives you an idea of how tiny the parts are! My cheaters got a workout on this one.
I would have preferred that they made each cowling ONE part that was then glued onto the nose. Seems to me it would have been easier to manufacture and easier to build. Hi ho...
And here's the cowling installed on the fuselage along with the tail section and top machine guns.
See that little gap just behind the top cowling? The part that goes there was a bit short. I have to build that up and fill it before I get too much further. Lots of cleanup to do as well.
This kit includes two rudders, but I'm not sure what they are for since the instructions don't give any clues and my research was fruitless. I used the one that matches the box art. The other one is more pointy at the top of the rudder.
That's as far as I got this weekend. Next I'll glue up the lower wings and start the paint. During dry fitting, these parts didn't go together too well. There were big gaps and steps all over the place.
But hey, what fun would it be if everything just glued up perfect the first time. Not much I say!
--Jeff
