Some nice work going on there guys!
I had hoped to be a bit further ahead with the Tu-160 than what I am - hence the lack of posting. As well as being a relatively detailed kit (for 1/72) it's also proving pretty difficult to get accurate pics & info for areas like the wheel wells & what not, many pictures have equally contradicting versions....... I guess thats possibly down to the low rate (very) production these birds.
Any-hows, here is where I'm up to at the moment, cockpit, front landing gear, weapons bays, weapons, part done main gear bays & exhausts;
One weapons bay is going to remain empty;
While the other one is patiently waiting for a full load of Kh-55s, which I'm expecting decal to arrive soon so that I can wrap it up;
The Kh-55's were a bit on fiddly side, with three double folding fins on each;
& I've just started on the exhaust nozzles, which are well detailed & fitting six part jobs;
One issue with the nozzles was the seam which appears where the cross section of them reduces back down in size where they fit into the exhaust body. I tried re-scribing them before removing the seam, so that the recessed lines would remain, but found it pretty much on the impossible side, so unfortunately some detail has been lost - I may try & make up for it when painting them;
Just before finishing these pics, the postie arrived with some much waited for decals. These are from Begemot in Russia & are quite superb, there are two sets, one with the regular decals for whichever Blackjack takes your fancy (they are all named after famous Russian aviation geezers) & the other has a full set of very detailed stencils for everything including the weapons. Both of the sets come with detailed placement guides & accurate colour guides for the aircraft;
& here is the UK version of the Blackjack;
