Mike,, I am going to bet that your build turns out great, sinkholes or not.
Greg,, those tracks are awesome
As I mentioned before, the Nitto Pz III was a previous idea to incorporate into a scene with the Schwimmwagen (Nitto,,, same scale). I finished the Schwim just before the GB.
Here are some pics of this lil guy......
![](http://i951.photobucket.com/albums/ad354/babill1/76%20scale%20Schwimmwagen%20Part%201/P1092603.jpg?t=1313023221)
I changed out the convertible top with folded lead foil and StripStyrene .025" rod for the brackets. The kit supplied top just looked way too chincy even for me...
![](http://i951.photobucket.com/albums/ad354/babill1/76%20scale%20Schwimmwagen%20Part%201/P1092602.jpg?t=1313023296)
The shovel and oar were so crappy that I decided to just scratch build the brackets (for what they're worth in this scale). I also made my own side / grab rods which run between the front and back fenders. I also added a "firewall" / back behind the rear seats as this was wide open.
![](http://i951.photobucket.com/albums/ad354/babill1/76%20scale%20Schwimmwagen%20Part%201/P1092600.jpg?t=1313023174)
I hollowed out the exhaust pipes and measured and cut a piece of acetate as the kit did not include a windscreen. I didn't go so far as to add wipers though,,,, they would have probably been invisible anyway.
![](http://i951.photobucket.com/albums/ad354/babill1/76%20scale%20Schwimmwagen%20Part%201/P1092598.jpg?t=1313023564)
I also tossed in a few supply cartons that I made,,, not sure if they will be there in the end,,, at this time they are loose. I used some standard 35th scale ration carton templates and reduced them to scale. Printed on some brownish paper, cut out and glued.
![](http://i951.photobucket.com/albums/ad354/babill1/76%20scale%20Schwimmwagen%20Part%201/P1092597.jpg?t=1313023860)
A little acrylic airbrushing, highlights, dirt and crud, and pastels to finish and there it is,,,, 1.25" from nose to tail.
I don't often delve in this scale, but when I worked part time in a hobby shop (ages ago), I thought they were pretty cool and so very inexpensive..... I ended up buying a slew of them..... I snapped a couple of pics of that part / portion of my inventory -
Mostly Nitto,,, with a few Fujimi's tossed in too
![](http://i951.photobucket.com/albums/ad354/babill1/76th%20kits/76thkits001.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/76th%20kits/76thkits002.jpg)
They always offered more than just the main subject -
![](http://i951.photobucket.com/albums/ad354/babill1/76th%20kits/76thkits008.jpg)
I also found one of these old MPC kits.....
![](http://i951.photobucket.com/albums/ad354/babill1/76th%20kits/76thkits003.jpg)
So enough of this off-shoot nonsense,,,,,,,
I hope you liked the little detour from the regular broadcast station. We now return you to real builds in real scale...
