Ok,, here I am telling Rob more pics.. guess I should post a few too
I am finishing up the last remnants of the construction phase -
I tried a few ways to replicate the rear turret ports... none of which worked out the way I was hoping. So I punched out a couple of discs and glued in place.
It is very hard to see in the next photo, but I needed more than just a punched out disc.... I used white glue and dabbed the disc to give a bit of depth... while they are not quite "cone-like" they will pass as a reasonable facimile when completed.
Next were the smoke launchers. I was leery going into this part of assembly. NOT too thrilled with the way they looked even after filing down two edges (in hopes of making them look a bit more realistic) cleaning them up and drilling them out.
In any event,,,, I glued one on anyway, just to see how it looked.... and,,, I wasn't happy. Angles are all wrong, etc. etc. and the more I looked, the less I liked.....
So,, OFF WITH THEIR HEADS!,,,, kindly remove from the turret please.... but now, what to do? I thought about scratchbuilding them,, even started gathering pics, info and in-house materials I would need. I then came to my senses and decided against it...
I added very rudimentary lifting hooks to the turret corners. This photo, which is crappy, is the first application of (again) white glue.... I subsequently added a few more smaller dabs over the first.... for what they are worth, they don't look all that bad (didn't take any finished pics of them). After painting they will show up much better, I hope.
And one last little thing for today (hell, they are all little things with this build).... the headlights were way too tall,, among other things. I dry fitted and knew I had to do something. So, I lopped off a section of the stem and re-glued the two pieces which will be cleaned up a bit.
Well, that's it for now.....
Hope you enjoy and all comments welcome.......... OH, have a nice holiday weekend too (cannot believe summer is coming to a close).
Bill
