Good afternoon guys,
First off - thanks Tony ![Yes](/emoticons/emotion-21.gif)
A quick update: Somehow I managed to get both runs of Magic Tracks assembled, glued and fitted in 60 minutes which is VERY good going for me.
I've decide to go against my normal assembly & painting method of assembling the wheels, tracks and tools then painting them off the model - I'm going to assemble the whole thing and paint everything 'in-situ' as it's going to be nigh on impossible fitting magic tracks onto a Panzer III once the fenders are in place. Vinyl tracks and Friuls yes but obviously these will be staying put now.
One thing that has bugged me is that the front return rollers (the ones nearest the drive wheels) are slightly lower than the other two? I've measured them and they are just shy of a millimetre lower. Should this be so? I didn't notice until the tracks were on!
A few photos:
I have a ready made Magic Track assembly jig for Panzer III tracks. I make up the straight run that goes from 6 o'clock on the front road wheel to 6 o'clock on the back wheel then glue that solid and leave it separate. I then assemble the rest of the required number of links and put plenty of Tamiya Extra Thin Cement on the entire run, leaveve for 5 minutes then join front of the straight link to the long run , put the wheels in place on the straight run and loop the links over-cementing the other end up and positioning it all properly with a bit of sag. Be careful as when the cement fully dries it will contract and pull the links tighter so it's an idea to add an extra link. My run was really saggy but not following the cement fully drying as you can see!
![](http://i806.photobucket.com/albums/yy343/Hinksy1/SIG33240711001.jpg)
All fitted and looking good - this track run had a nice bit of sag imparted into it but look at it now it's dry!:
![](http://i806.photobucket.com/albums/yy343/Hinksy1/SIG33240711004.jpg)
Gun assembly completed and fitted to upper hull which has been dry fitted for the photos (the seam on the barrel needs a little more work at this point):
Seam sanded out a little bit more - it is all but invisible now:
That's it for now chaps - I reckon the basic assembly could be finished by this time next weekend! It's such a simple build!
That's okay as I really want to try some different weathering techniques out on her.
I'd love to hear any comments or critiques guys.
Have a great week everyone!
Ben
