Hey Guys.
Well, after a few false starts, and a long losing argument with an uncooperative Mig 29, I have started a build. Not the MIG. I just could not get the fit right on the fuselage.
So without further ado.. I will be doing a 1/48 Scalecraft/ESCI F86F Sabre. This kit will be OOB, except I think I may need to replace the decals.
Some work began today.
First, here is an image of the little bugger in it's box.
The very plain vanilla instructions.
Now the troublesome decals. (You can't see it too well, but I think something spilled on the decals before I got the kit. I had to use liquid decal film to salvage at least the instrument panel decals, which is good becaue without the decals, it's just a plain plastic panel.
Here is the obligatory "In the Box" shot of the virgin kit.... Well sort of Virgin anyways..
It's a pretty basic kit. But has some decent external detail, and is designed well. It was one of my eBay finds last year, and for the price, I can live with the nasty decals. Here are some in progress shots of the initial first assembly steps. Basically decaled the panels and pre-assembled the seat prior to detail painting.
I did get the decal to flatten out eventually. Old decals don't adhere as well. A second coat of Micro-Sol did the trick though. Here is the main instrument panel.
I had the same issue here with the decal, with the same solution. Now for a shot of the pilots seat pre-assembled prior to painting.
As you can see in the image, my 18 pounds of stupid cat decided to donate some fur to the seat... If he does it again, it's Flowbee time for sure...
I will probably be doing more work on her later. I need to let the decals finish setting up, and the seat completely cure, then I start painting. While I am waiting, I have to go through my decal sheets and see if I still have an F86F of any kind. If not, it's back to eBay.. lol
