OFFICAL NATURAL METAL FINISH GB IV 2012-2013
    August 2009
Posted by TREYZX10R on Tuesday, December 18, 2012 12:29 PM
Doogs yes the kit barrels are going to the bin for sure. I've been lurking on the thread for a while and saw your tutoral on the replacement technique,very useful thanks! Not sure what I'm using to replace them with yet tho,leaning toward some a/m just hate to do that all the time.
Spark did you forget to use the rich formatting? Not seeing the pics either
What color primer is best suited for the D the yellow or green Zinc?
    August 2009
Posted by TREYZX10R on Tuesday, December 18, 2012 9:29 PM
Office is a wrap,not a very accurate molding I might add. A lot of missing and misplaced components .Still trying to avoid resin replacements with this build so in it goes.
    July 2011
Posted by Spark84 on Tuesday, December 18, 2012 10:04 PM
OK, they should show up now on that post... i used the wrong link type. Oops
On the Bench: 1/72 Mono B-36 (...UGH)
Last finished: Revell Space Shuttles Enterprise (On SCA) and Columbia (built both for local aircraft museum)
In the Que:
    January 2012
Posted by Misty on Wednesday, December 19, 2012 5:02 AM
Yup they are there now, thats a colourful scheme, looks cool!
Posted by Gamera on Wednesday, December 19, 2012 8:36 AM
Spark: Cool! Always loved those diamond nose Mustangs but never built one. Super eye-catching model!
Trey: My Revell Promodeler P-47 has the same cockpit, wasn't too crazy about it but it works.
    August 2009
Posted by TREYZX10R on Wednesday, December 19, 2012 9:14 AM
Spark looks really sharp!
Cliff I hear ya ,really hated sticking with the kit supplied pit but trying real hard to stay away from the resin on this one. Keeps tempting me the more I look at it thoConfused
I'm still cleaning up the fuse and opening up tiny vents
Does anyone have a good detail picture of this area?Been searching for hours and coming up dry. Would be greatly appreciated
cheers Trey
    August 2009
Posted by TREYZX10R on Thursday, December 20, 2012 12:51 AM
B-17 in the stash gave up a turbo(more to come on that build later) and using the donated part I finished up the aft turbo vents.
 I also used some sheet styrene painted black to block light from passing thru the opened vents and installed the office.
Glued the fuse halves together
started working on the gun sight
after it sets up it will be time to decide what to do about the raised panel lines,not really wanting to rescribe this thing. Geuss it depends on how much detail I loose sanding the seams
    August 2009
Posted by TREYZX10R on Friday, December 21, 2012 4:55 PM
The wings next,opened the spent shell ports ,landing lights and ID light holes
Cleaned up the engine and firewall,opened the intakes and removed areas around the cylinder heads
Joined the wings and set the dehedral,its close but not exact
filled the minor gaps with green squadron putty
smoothed out the filler and painted a guide coat of thinned grey to highlight imperfections
I just had to touch up a few panel lines at the seams avoiding a major rescribe job.
Thinned MM enamel applied to get a uniform base before the NMF
canopy added
NMF is next,cheers Trey
    January 2012
Posted by Misty on Friday, December 21, 2012 6:32 PM
hurry up, dude, :-0 you only have 6 months to finish itDevil .
How the hell do you lot build em so fast? Toast
    August 2009
Posted by TREYZX10R on Friday, December 21, 2012 9:32 PM
lol I do'nt sleep much at all,btw is that a Tesi in your avatar?
    January 2012
Posted by Misty on Saturday, December 22, 2012 7:44 AM
sure is, nice little bike and a bit different to the norm.
PICT0066 by omgpainful, on Flickr
    August 2009
Posted by TREYZX10R on Saturday, December 22, 2012 9:03 PM
Sweet Tesi ,saw one in person at bike week in Daytona a few years back. Love the Bimota line,especially the old 2 strokers!
I'm going with Testors aluminum for the base of the NMF. First shot some Testors clear over the canopy to help seal down the mask and avoid 'creep'. Followed by a shot of the green interior color. Then the aluminum went on. I had to stop and fix some blems inspite of all the extra care I still missed a few spots. I then shot some Testors clear over the aluminum ,hopefully this will keep me from damaging the finish as I add some various tints to access panels and the anti glare areas.
The props almost ready to hang
Panel color modulation followed by Invasion stripes and anti glare next,cheers Trey
    January 2012
Posted by Misty on Sunday, December 23, 2012 3:45 AM
The testors spray looks like a really nice finish, ive never used testors. How resiliant is the finish against fingerprints and the like?
    September 2009
Posted by B17Pilot on Sunday, December 23, 2012 4:45 PM
Well my NMF painting is done! Had a couple of problem areas in the tail as well so that set me back a bit. I also got the squadron markings on. Now its decal time!
Some panels are diferent shades, but I went with a light variation so they might not show up in the pictures.
    August 2009
Posted by TREYZX10R on Sunday, December 23, 2012 6:42 PM
Talentless ,not so well!
Looks spot on B-17pilot,nice results!
Had an EPIC fail on the NMF. Masked up some panels to spray some different shades of aluminum and the clear pulled away from the base. So I grabbed some really strong tape and started using it to 'pull' the remainder of the clear away.
then wet sanded everything with 1000 grit,loosing a little detail but its better than binning it at this point.
Then sprayed it semi gloss black to check for flaws . I'm going to try Tamiya ts-30 silver leaf as I've had good results in the past with it.
If that does'nt work I'm returning it to kit form. Gee I'm so glad I got back into this hobby to relax.
    January 2012
Posted by Misty on Sunday, December 23, 2012 8:13 PM
TREYZX10R
That sucks bad Sad keep your pecker up, im sure the ts30 will be better. Right Hug
    July 2012
Posted by DJinFlorida on Tuesday, December 25, 2012 9:05 PM
Those are some colorful birds you have there, Spark.
Hang in there Trey, they can't all be that bad. Right?
I just finished putting the decals on the Mustang.
All that is left now is some touch up, a clear coat, and the canopy.
-DJ
On the bench: 1/48 Avenger, 1/72 P40B
On daughter's bench: 1/72 ID4 Attacker
On wife's bench: 1/48 P40B
In the stash:  1/48 P-51D Mustang , 1/72 F4F-4 Wildcat, 1/48 Huey Hog
    January 2012
Posted by Misty on Wednesday, December 26, 2012 5:04 AM
Nice one dj, what metal spray is that and what clear coat r u using
Posted by Gamera on Wednesday, December 26, 2012 8:12 AM
Wow DJ, looking good! Love how those nose checkerboard decals came out, one thing I'm not very good at all.
    July 2011
Posted by Spark84 on Wednesday, December 26, 2012 4:47 PM
Thanks for all the praise on my blue diamond mustangs, i love the color scheme as well!
I'm also looking for a good clear coat, any suggestions?
In the Que:
    July 2012
Posted by DJinFlorida on Wednesday, December 26, 2012 6:47 PM
Talentless - Thanks!  I used Model Master Metalizer Lacquer Aluminum Plate.  I'm going to use Future to seal the decals and see how it looks.  I may put Testors Dullcote to take down the shine.
Gamera - Thanks!  those decals were tough.  There are a couple of spots that didn't sit well, but the seams look good.
-DJ
    August 2009
Posted by TREYZX10R on Wednesday, December 26, 2012 10:48 PM
Talentless thanks I'm trying to stay positive.
DJ that is looking sweet. Awesome job on the NMF.
Well I have made a partial recovery to were I wanted to be. I shot tamiya ts-30 first followed by Model Master aluminum plate metalizer. Then I buffed everything out by hand and shot automotive 2part urethane clear thinned about 30% over the whole thing. I'm not going to attempt to mask and spray the invasion stripes,just too worried everything will pull up again! I tried using the kit supplied ones but ruined them putting them on,totally my fault. So 'elsie ' will have to live without her belly stripes,oh well.
Decals are Aero Master and are working great
Monster Prop is ready to hang
    July 2011
Posted by Spark84 on Wednesday, December 26, 2012 11:16 PM
...And... They're done!
In the Que:
Posted by Gamera on Wednesday, December 26, 2012 11:23 PM
Trey: She looks good to me! I wouldn't have noticed the missing stripes if you hadn't told us about them.
Spark: Wow, love those diamond nose Mustangs! Really sharp work there!
    August 2009
Posted by TREYZX10R on Thursday, December 27, 2012 8:53 AM
Spark a pair of beauties for sure,very nicely done Sir!
Cliff thanks appreciate that!
    August 2009
Posted by TREYZX10R on Friday, December 28, 2012 5:34 PM
I'm calling it done
Added some gunsight details
I used watercolor mixed with Formula'560' canopy glue for the id lights after drilling them slightly
also used the same canopy glue for the clear position lights
I used aluminum tubing for the exhaust and punched out disc for the pressure valve that goes in the outlet
cheers Trey
    January 2012
Posted by Misty on Friday, December 28, 2012 6:50 PM
looks damn good to me !!
    August 2009
Posted by TREYZX10R on Friday, December 28, 2012 8:53 PM
Talentless thanks!
and a big thanks to Bigfoot01 who took the time to point out that the gear angle needed a tweak!
the fix,looks a lot better thanks John
    July 2012
Posted by DJinFlorida on Friday, December 28, 2012 9:12 PM
Very nice work Trey!
-DJ
    August 2009
Posted by TREYZX10R on Saturday, December 29, 2012 12:32 PM
Thanks DJ!
