Hi Tony,
I made quite a bit of progress on the 55 Cameo.
I'm using the wheels and tires that came on the 66 Nova. Since the axles are smaller on the truck, I had to make adapters out of sprue.
And here's after the adapters were installed.
Got the engine mounted in the frame and the wheels mounted.
Got the grille done. I used an alcohol and flat black paint wash to fillin the grille with an old ink refill needle. It took about 5 times filling and letting the alcohol to evaporate out and then wiping off the residue from the grille but it turned out good. :)
I test fitted the body to make sure the wheels didn't stick out. (Body is prepped for it's second coat of paint).
Also, here is a photo I printed to use as wood for the bed. I ordered some scale channel that I'm going to paint to same color as the body that will be laid over this.
Here's a side view of the wheels and engine.
Thanks for looking.
Eric
