50th Anniversary Vietnam War Group Build
Posted by Bish on Monday, August 4, 2014 3:54 PM
Nice to see this off and running. I hope to be joining you guys in about 4 kits time, but will defiantly be following along.
    December 2008
Posted by New Hampshire on Monday, August 4, 2014 5:33 PM
In a few minutes I will start taking pics of for the kick off of my build.  I will probably have a running WIP build in the armor section and cross post the link (assuming that is OK) since it will probably be easier and get more traffic in the armor forum.
Brian
    July 2004
Posted by stikpusher on Monday, August 4, 2014 5:36 PM
Yes, crossovers are allowed NH. No problem with you posting here and there.
Oh we have some good stuff already! Hogs and Puff!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2008
Posted by New Hampshire on Monday, August 4, 2014 7:51 PM
To quote Shang Tsung from the movie Mortal Kombat....."It has begun" Big Smile
http://cs.finescale.com/fsm/modeling_subjects/f/3/t/161419.aspx
Brian
Posted by MKelley on Monday, August 4, 2014 9:10 PM
B_One Fixer I see the MM III badge did I miss something?
    October 2004
Posted by ygmodeler4 on Monday, August 4, 2014 9:56 PM
MKelley, the Monogram Mafia III gb is happening right now...B1 is an absolute beast an finished his two builds already...I'm pretty sure there's still time to jump into the gb, Stik is hosting that one as well..
-Josiah
    April 2014
Posted by B_one fixer on Tuesday, August 5, 2014 2:52 AM
LoL Thanks YG, MKelley like YG said I finished up my second build for the group today. But there is still plenty of time to jump in.
    January 2011
Posted by Tal Afar Dave on Tuesday, August 5, 2014 8:06 PM
.....and the winner of the speed round is.......B-1 Fixer!!!  Great job on the Eagles, BTW.
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    January 2011
Posted by Tal Afar Dave on Friday, August 8, 2014 7:26 PM
Dang, B-1.....off to the races again?????? I didn't know that Cobra made a resin set for the Huey Hog...will have to research that!  Looking good so far, Speedy!!
    October 2004
Posted by ygmodeler4 on Monday, August 11, 2014 10:02 AM
Everyone's builds are looking good so far.
I have a question...in terms of lowest flying in a close air support role, which would most likely fly the lowest during an attack, the A-37 or A-1? Also, if anybody knows off the top of their head, is there a "lowest" altitude they recall reading/hearing/knowing about during one of such attacks? Also, I read a book about FAC's in vietnam but he was in an observation plane...would the way they coordinated the attacks be about the same if it was an FAC on the ground?
I'm gonna be doing research into this eventually but right now I'm swamped with pre-semester readings and work so I thought I'd ask here first...and yes...this does pertain to something I'm thinking about doing for this gb
-Josiah
    October 2004
Posted by ygmodeler4 on Monday, August 11, 2014 12:45 PM
Found an official source that said napalm drops from an A-1E were often done at 50ft....anybody know if the same would hold true with an A-1J?
-Josiah
    July 2004
Posted by stikpusher on Monday, August 11, 2014 3:10 PM
I am sure the parameters for all versions of A-1s while dropping Napalm would be the same. The performance of the aircraft and ordnance would not be altered.
As far as whether the A-1 or A-37 came in lower and slower, I would wager it to be the A-1. I have seen A-37s in operation and the operate about the same as an A-10, which is also low, slow and pretty damn impressive to watch in action when putting ordnance on target.
Ground based FACs are going to often co ordinate with and thru airborne FACs, but one does not need the other to operate. While the airborne FAC has the advantage of putting a smoke rocket on target to mark whatever he has found to use that as a reference point to the other aviators, the ground based one does not have that sort of ability. Although he can use smoke grenades, or terrain features easily identified from the air as visual refence points to talk in an air strike.
Look up Combat Controller Teams (Air Force) or ANGLICO (Marine Corps) to get more information on how those two types did their jobs in Vietnam
       - Plankton
LSM
    May 2009
Posted by Pawel on Tuesday, August 12, 2014 3:52 PM
Dave - thanks a lot!
B_one fixer - good luck with that Huey, it will be a challenge!
Now I've been away on a hiking trip for a few days and now I'm kicking off that scooter. Here's a basic photo:
I test fitted the hull halves and the fit is very nice. As can be seen the panel lines are sweet, too. What you can also see in the photo is a little resin from Pavla - the cockpit/front wheel bay part that you can compare to the kit part, still on the sprue below. The resin part has some nice switches on the side panels, and nice tubing in the wheel bay, and fits the fuselage halves drop-in. There's also the new ejection seat, with seat belts.
Now I have to start painting and detailing the cocpit - let's see how this turns out. Hope to see other builds start soon, good luck with them and have a nice day
Paweł
www.vietnam.net.pl
    July 2004
Posted by stikpusher on Tuesday, August 12, 2014 3:58 PM
Nice to see your Scooter here Pawel. As soon as I get my Gemini Spacecraft finished up in the next few days I will get my build here started.
       - Plankton
LSM
Posted by Bish on Tuesday, August 12, 2014 4:39 PM
Looking good there B_one.
And good to see another build under way. Its getting busy.
    July 2014
Posted by JASONS on Tuesday, August 12, 2014 10:23 PM
Going to start in the next day or so..
i60.tinypic.com/bjg488.jpg
Just got back into the hobby after a few years off. Had to create a new acct. but you can still see my old posts and some of my builds at this link:   http://cs.finescale.com/members/scigone/default.aspx
    July 2014
Posted by JASONS on Tuesday, August 12, 2014 10:25 PM
JASONS
 a>
    July 2004
Posted by stikpusher on Tuesday, August 12, 2014 11:49 PM
There is just not enough time in the day sometimes... too many projects...
       - Plankton
LSM
    October 2004
Posted by ygmodeler4 on Wednesday, August 13, 2014 12:08 AM
Stik, thanks so much for steering me in that direction...I've found what look to be a couple of great sources on ANGLICO that I'm gonna run with
-Josiah
    July 2004
Posted by stikpusher on Wednesday, August 13, 2014 3:18 PM
I am happy to have helped.
       - Plankton
LSM
    June 2014
Posted by Matt-Joachim on Friday, August 15, 2014 11:31 AM
I'm going to try my best to salvage my a-7a to keep it out of the boneyard, but here's where I'm at so far...
174.jpg.html
175.jpg.html
    May 2009
Posted by Pawel on Saturday, August 16, 2014 9:39 AM
Hello everybody!
I'm slowly movin' on with the scooter. Currently I'm painting the cockpit:
Thanks for looking, have a nice day
Paweł
www.vietnam.net.pl
    August 2014
Posted by sam33 on Saturday, August 16, 2014 11:17 AM
Hi all,
Battle of Hue
www.youtube.com/watch?v=jxNEiZhpinYFaithfully
Sam
    April 2014
Posted by B_one fixer on Saturday, August 16, 2014 3:46 PM
Is that the kit cokpit or AM ? either way its lookin good !
    May 2009
Posted by Pawel on Sunday, August 17, 2014 5:56 AM
B_one fixer - thanks a lot! That's a resin cockpit and ejection seat by Pavla, a Czech company.
How is your Huey progressing? Good luck with it and have a nice day
Paweł
www.vietnam.net.pl
Posted by MKelley on Sunday, August 17, 2014 11:58 AM
Here is a progress update on the AC-47
the standard box cover shot.
Cockpit area
I know it is a little blurry but, it is the best photo I have at this time.
Ready to install the interior guns etc.
The interior with the miniguns set, ammo boxes added, blast blankets attached and flare boxes installed.
    May 2009
Posted by Pawel on Sunday, August 17, 2014 12:17 PM
Ain't that a classic!
By the way: should the instrument dials be white?
Thanks for sharing, have a nice day
Paweł
www.vietnam.net.pl
    July 2004
Posted by stikpusher on Sunday, August 17, 2014 2:53 PM
Pawel
Very nice work so far on Puff!
Here is a shot of the IP,, black dials with white markings
       - Plankton
LSM
Posted by MKelley on Sunday, August 17, 2014 3:20 PM
Pawel, Stik, the instrument panel is a decal from the kit. I tried the usual paint the panel white then black. Scrape off the black to show the white. The detail was so thin that I was not able to get it to work. That is when I put the decal in there.
