Here's another update on my Invader. I added another missing detail on the right side of the fuselage which is a small hatch door, hinges and the door handle. The vertical lines were scribed and the hinges and handle are stretched sprue cut to size then glued with slow CA applied with a toothpick.
before...........
and after........
The engines were painted metallic silver and given a black wash to pop details.
Engines and canopy are in place and secured
I recently read on one of the threads here in FSM about the wonders of "Perfect Plastic Putty" made by Deluxe Materials in the UK. This stuff is fantastic. It spreads very easily and sands extra smooth with super fine sticks producing an ultra fine surface.
I ran a Q Tip moistened with rubbing alcohol over the seams to check for defects. The alcohol lets you see while wet and glossy if any imperfections are visible. I then applied the Perfect Plastic Putty product over the suspected areas and let it dry over night. The directions said 20 minutes but bedtime was close.
The putty doesn't shrink and sands very easily with little pressure on the sanding stick. It took care of a couple of dips at the joins. Any missing lines were restored with the UMM Scriber, another life saver.
I even discovered a small dip on one of the tanks but the plastic putty took care of it.
Just when I think I'm getting ready for paint, I discover another missing detail. More to come.
